| windows dont work but sun roof does? | |
crstump Member
Name : Corey Age : 28 Location : carrollton ky Joined : 2012-02-22 Post Count : 92 Merit : 1
| Subject: windows dont work but sun roof does? Thu Apr 04, 2013 1:47 pm | |
| iv taken a look at the fuses and all that good stuff but the only fuse to the windows and the sun roof, but the sunroof works so idk what to do.
| Subject: Re: windows dont work but sun roof does? Fri Apr 05, 2013 2:06 am | |
| Check for a hot thermal breaker under the back seat. | |
crstump Member
| Subject: Re: windows dont work but sun roof does? Wed Apr 24, 2013 10:56 pm | |
| if thats the huge fuse lookin thing i already checked it, its good. my dad says if the driver side switch goes out it will cause the pasenger side switch to not work? summer weather is coming and im not the A/C type person. so this needs to be fixed asap.
| Subject: Re: windows dont work but sun roof does? Thu Apr 25, 2013 3:19 am | |
| Might be a break in the power wires in the driver side door jamb. | |
crstump Member
| Subject: Re: windows dont work but sun roof does? Thu Apr 25, 2013 7:47 pm | |
| ok so iv tested power goin to the window motors. there is power!!! exept when i hit the button goin down, after more and more testin for about, an hour, iv come to a conclusion that its the modular power window controler. when i try rolling window down and this unit makes a single "tick" noise, the light on the tester ( had it touching the blue wire to the window motor, it does the same with the brown wire if im recalling right ) barley even lights up then it makes another tick then light goes away, this happens within half a second. anyone ever had to replace this? damn electrical stuff dont want to buy it then not be the problem and cant return the part . the part number is 25614182. does any one know if the driver side modular goes out it will cause the passenger side not to work as well? and i also broke 2 of the 3 clip things that hold the bottom half of the door panel on, the plastic is all dry roted and very weak. | |
| Subject: Re: windows dont work but sun roof does? Fri Apr 26, 2013 7:44 am | |
| Corey, Did you look at the wire bundles in the rubber sleeve between the door and body as Albert suggested? Wire breaks are VERY COMMON there. _________________ 98 Riviera SC3800 All stock except gutted air box. 1970 Buick GS455 Stage1, TSP built 470BBB, 602HP/589TQ Best MPH, 116.06 MPH, Best ET, 11.54 https://www.youtube.com/watch?v=UHCda-t_Jls https://www.youtube.com/watch?v=sfT2tEO4XcU
| Subject: Re: windows dont work but sun roof does? Fri Apr 26, 2013 8:52 am | |
| As for those plastic hooks at door bottom, you can fabricate replacements out of sheet aluminum or sheet steel, make backing plates out of the same stuff, and epoxy and poprivet them into place. | |
| Subject: Re: windows dont work but sun roof does? Fri Apr 26, 2013 8:53 am | |
| - LARRY70GS wrote:
- Corey,
Did you look at the wire bundles in the rubber sleeve between the door and body as Albert suggested? Wire breaks are VERY COMMON there. X2 | |
crstump Member
| Subject: Re: windows dont work but sun roof does? Fri Apr 26, 2013 9:38 pm | |
| if the wires were broke power wouldnt get to the motor would it? and if its a ground wire broken what color would it be? im not very good at the electrical stuff, everyone iv talked to says it makes since that the modular is broken, but i do see what you guys are sayin, i have pulled the rubber over a lil and peaked in the cables looked like there in tacked but they can still be broke on the inside. on the modular system there is 4 metal tabs the plug into the wire, one is always hot, the second one is for the driver side down switch, the 3rd one is for driver side up, and the forth one is for passenger window switch up and down. | |
| Subject: Re: windows dont work but sun roof does? Sat Apr 27, 2013 8:17 am | |
| An intermittent short in the cables could fry the module.
So be sure to check the wiring before you replace the module. | |
crstump Member
| Subject: Re: windows dont work but sun roof does? Sun Apr 28, 2013 1:38 am | |
| git it fixed today, you was right there was a wire broken in the jam, but i did still have to replace the module, just went and got it from a local junk yard. | |
| Subject: Re: windows dont work but sun roof does? Sun Apr 28, 2013 7:32 am | |
| Glad you fixed it.
Does that yard have a riv with a white (not pearl) trunk lid, I am looking for one.... | |
joshuadalegrimes Addict
| Subject: Re: windows dont work but sun roof does? Sun Apr 28, 2013 1:01 pm | |
| wheres the local yard? if it has rivs i need to know lol | |
crstump Member
| Subject: Re: windows dont work but sun roof does? Sun Apr 28, 2013 3:41 pm | |
| no riv in this on, just pulled it off a 2 door grand am, but iv heard of a yard near me in ky louisville with a couple rivs, have not had the chance to check it out. | |
| Subject: Re: windows dont work but sun roof does? | |
