| | FAQ: 1995-1999 Buick Riviera TSB & Recall Database | |
| | Author | Message |
al_roethlisberger Junkie
| Subject: FAQ: 1995-1999 Buick Riviera TSB & Recall Database Fri Apr 12, 2013 12:17 pm | |
| I did a quick search here but didn't find any current list of all known TSB and recalls for the 1995-1999 Buick Riviera.
A lot of make/model specific boards often will try to have a list/FAQ of them for quick reference.
Is that something we've considered, or is there simply a better online source elsewhere these days that is easier to use?
Thanks, Al | |
| | | sniperdude Fanatic
Name : Mike Location : Chicago Joined : 2012-06-04 Post Count : 250 Merit : 18
| Subject: Re: FAQ: 1995-1999 Buick Riviera TSB & Recall Database Fri Apr 12, 2013 3:32 pm | |
| 95 TSBs
- 12-06-01-008A 09/27/2012 Vehicle - Engine And Sub Systems Flushing Info. (CANADA)
- 04-06-01-029G 09/27/2012 Vehicle - Engine And Sub-Systems Flushing Recommendations
- 05-03-10-020D 09/18/2012 Wheels/Tires - Use Of Nitrogen Gas In Tires
- 00-00-90-002K 09/14/2012 Tires - Information On Proper Tire Pressure
- 04-06-04-054E 08/06/2012 Engine - THIS BULLETIN HAS BEEN CANCELED
- 05-06-04-022I 07/19/2012 Fuel System - TOP TIER Detergent Gasoline Information (Canada)
- 04-06-04-047K 07/19/2012 Fuel System - TOP TIER Detergent Gasoline
- 00-03-10-006H 07/19/2012 Tires/Wheels - Information on Tire Radial Force Variation (RFV)
- 03-03-10-007G 07/13/2012 Tires/Wheels - OE Tire Shake/Vibration Information
- 05-03-08-002E 05/31/2012 Suspension - Shock Absorber/Strut Fluid Leak Information
- 03-07-29-004H 05/30/2012 M/T - Operating Characteristics Information
- 12-05-26-001 05/18/2012 Brakes - Resurfacing Park Brake Portion of Rear Brake Rotor
- 00-06-01-026D 05/02/2012 Engine - Intake Manifold Inspection/Replacement
- 06-08-51-005B 04/30/2012 Body - Hem Flange Sealer For Corrosion Protection
- 03-00-89-008F 04/24/2012 Body - Metal Body Panel Corrosion Protection
- 05-00-89-078C 04/19/2012 Fuel System - GM Fuel System Treatment PLUS(R) Info.
- 04-06-04-051C 04/19/2012 Fuel System - Fuel Injector Maintenance Cleaning
- 04-08-48-001D 04/17/2012 Body - Broken Rear Window Defogger Grid Detection
- 08-08-44-028A 04/11/2012 Audio - Inadvertent Steering Wheel Button Activation
- 06-08-44-015C 03/30/2012 Audio System - Noise When Using Portable Playback Unit
- 02-07-30-052H 03/26/2012 A/T - Fluid Oil Cooler Flow Test
- 12-03-10-001 03/23/2012 Tires/Wheels - Vibration Shortly After Tires Are Mounted on Rim
- 99-09-40-004B 03/15/2012 Restraints - Child Seat Top Tether Attachment Kits
- 12-02-32-002 02/21/2012 Power Steering - Fluid Leaks Due to Extreme Low Temps
- 02-08-42-001F 02/10/2012 Lighting - Lamp Polycarbonate Lens Damage Prevention
- 06-08-50-009G 02/03/2012 Restraints - Passenger Presence System Information
- 09-09-40-001B 01/13/2012 Restraints - Seat Belt Latching Issues/Warning Lights
- 06-08-64-001C 12/23/2011 Body - Side Window Chipping Information
- 10-08-50-003B 11/10/2011 Restraints - Driver/Passenger Seat Head Rest Information
- 00-06-01-012D 10/25/2011 Engine - Use of 'Surface Conditioning Disks'
- 00-00-89-027F 10/18/2011 Interior - Elimination Of Unwanted Odors
- 01-07-30-042G 09/22/2011 A/T - 2-3 Upshift or 3-2 Downshift Clunk Noise
- 01-08-51-003C 09/21/2011 Body - Application of Anti-Corrosion Materials
- 99-01-39-004D 08/10/2011 A/C - Musty Odors Emitted From (HVAC) System
- 10-08-45-001C 06/06/2011 Electrical - Information For Electrical Ground Repair
- 08-07-30-026A 05/17/2011 A/T - Slight Vehicle Movement In Park At Start Up
- 99-04-20-002G 05/06/2011 Drivetrain - Clunk Noise Shifting From PARK Into Gear
- 00-03-10-002F 04/21/2011 Wheels - Chrome Wheel Staining/Pitting/Corrosion
- 04-07-30-037E 04/07/2011 A/T - DEXRON(R)-VI Fluid Information
- 99-08-51-007E 03/17/2011 Wheels/Tires - Refinishing Aluminum Wheels
- 11-00-90-001 03/14/2011 Engine - GM Dexos 1(R) and Dexos 2(R) Oil Specifications
- 99-08-51-001B 03/01/2011 Body - Paint-Less Dent Repair Recommendations
- 06-08-43-003C 02/21/2011 Glass/Body - Windshield Wiper Performance
- 01-08-42-001H 01/05/2011 Lighting - Exterior Lamp Condensation and Replacement
- 05-03-07-009C 12/09/2010 Steering/Suspension - Wheel Alignment Specifications
- 09-06-03-004D 12/08/2010 Electrical - MIL ON/DTC's Set By Various Control Modules
- 08-07-30-035B 11/01/2010 A/T - Water Or Coolant Contamination Information
- 05-06-04-022G 10/27/2010 Fuel System - TOP TIER Detergent Gasoline (Canada)
- 00-08-48-005D 09/10/2010 Body - Vehicle Glass Distortion Information
- 04-08-50-006D 09/09/2010 Interior - Seat Cover Wrinkle/Crease/Burn Info
- 10-08-98-002 08/06/2010 Body - Drilling High Strength Steel Using CryoCobalt(R)
- 03-08-98-002B 06/30/2010 Body - Squeeze Type Resistance Spot Welding/Equipment
- 99-09-40-005F 06/23/2010 Restraints - Extender Availability For Seat Belt
- 06-03-10-010A 06/09/2010 Wheels - Changing Procedures/Precautions
- 10-00-89-010 05/27/2010 Locks - Key Code Security Rules and Information (CANADA)
- 05-03-10-003F 04/27/2010 Tires/Wheels - Low Tire/Leaking Cast Aluminum Wheels
- 04-03-10-001F 04/27/2010 Tires/Wheels - Tire Puncture Repair Procedures
- 10-08-110-001 03/30/2010 Interior - Proper Use of Floor Mats
- 08-08-64-011A 02/26/2010 Mirrors - Heated Mirrors, Defrosting Time
- 09-03-10-017 12/17/2009 Wheels/Tires - Replacement Wheel Weight Information
- 06-08-111-004B 09/25/2009 06-08-111-004B - BULLETIN CANCELLATION NOTIFICATION
- 09-08-48-006 09/18/2009 Body - Stain/Film On Windshield Glass Perimeter
- 99-08-64-016C 07/29/2009 Body - Maintaining Exterior Weatherstrip Appearance
- 07-06-01-016B 07/27/2009 Engine - Noise/Damage Oil Filter Application Importance
- 08-06-01-008A 07/27/2009 Engine - Drive Belt Misalignment Diagnostics
- 08-03-10-004A 07/24/2009 Wheels/Tires - Accessory Wheel And Tire Information
- 05-08-51-008C 06/22/2009 Body - Bumps or Rust Colored Spots in Paint
- 08-08-42-005B 06/18/2009 Lighting - Headlamp Warranty Replacement Guideline
- 08-03-10-005A 03/31/2009 Wheels/Tires - Chrome/Steel Valve Stem Cap Precautions
- 09-08-48-002A 03/19/2009 Body - Marks/Stains on Windshield When Wet
- 02-08-98-002C 02/03/2009 Body - Hem Flange Rust Repair Information
- 01-07-30-036H 01/29/2009 A/T Control - DTC P0756 Diagnostic Tips
- 05-03-10-005D 09/11/2008 Wheels/Tires - Upsized Wheel/Tire Characteristics
- 08-08-46-004 08/14/2008 OnStar(R) - Aftermarket Device Interference Information
- 08-08-44-026 08/11/2008 Audio System - Refurbishing Radio Faceplates/Knobs
- 02-06-03-008D 07/21/2008 Charging System - Low Voltage Display/Battery Discharged
- 05-06-02-001A 07/16/2008 Cooling System, A/C - Aluminum Heater Cores/Radiators
- 05-00-89-072B 06/17/2008 Engine/Fuel System - Oil/Fuel Additive Information
- 00-07-30-022D 06/10/2008 A/T - 4L60/65E, No Reverse/2nd or 4th Gear
- 08-07-30-027 06/04/2008 A/T - No Movement in Drive or 3rd Gear
- 01-07-30-010C 05/12/2008 A/T - Torque Converter Replacement Information
- 99-07-30-030F 05/01/2008 A/T - Grinding/Growling Noise in Park on Incline
- 02-06-03-009C 04/17/2008 Electrical - Battery Charging Tips/Recommendations
- 08-08-51-002 03/12/2008 Body - TPO Fascia Cleaning Prior to Painting
- 08-09-41-003 02/25/2008 Restraints - Usage of Used/Salvaged/Imitation Components
- 06-06-04-035A 02/05/2008 Fuel System - E85 Fuel Usage Precaution
- 04-03-10-012B 02/01/2008 Wheels - Chrome Wheel Brake Dust Accumulation/Pitting
- 01-05-23-001B 01/31/2008 Brakes - Rotor Lateral Runout Correction Information
- 08-01-38-001 01/25/2008 A/C - Refrigerant Recovery/Recycling/Equipment
- 05-06-01-010B 09/28/2007 Engine - Sealant Usage/Procedures
- 07-08-45-002 09/05/2007 Electrical - Aftermarket Fuse Warning
- 07-08-63-001 04/17/2007 Body - Polypropylene Energy Absorber Replacement
- 02-08-42-004A 03/30/2007 Instruments - Reduced PRNDL Display Visibility
- 04-07-30-013B 02/01/2007 Engine, A/T - Shift/Driveability Concerns/MIL ON
- 06-00-89-054 11/30/2006 Warranty - Claims Submission
- 01-07-31-002B 11/01/2006 M/T - Hydraulic Clutch Bleeding Procedure Improvement
- 02-08-98-001C 10/09/2006 Body - Metal Panel Adhesive Bonding Information
- 00-06-02-006D 08/15/2006 Cooling System - Coolant Recycling Information
- 06-01-39-007 07/25/2006 A/C - Contaminated R134A Refrigerant
- 06-08-45-004 05/02/2006 Electrical - Instrument Panel And General Wiring Repair
- 02-08-48-001B 03/29/2006 Body - Urethane Adhesives for Glass Applications
- 06-03-10-004 03/01/2006 Tires/Wheels - Wheel Weight Usage Precautions
- 02-01-39-004B 11/16/2005 A/C - New PAG Oil
- 01-07-30-041B 10/06/2005 A/T - Diagnosing Fluid Leaks
- 03-05-24-001A 03/21/2005 Brakes - Wheel Cylinder Inspection Guidelines
- 03-09-41-003A 02/09/2005 Restraints - Air Bag System Diagnostics
- 04-08-61-001A 11/29/2004 Body - Battery Compartment Floor Pan Corrosion
- 01-01-38-006D 09/01/2004 A/C - R-134a System Flushing Procedures
- 01-03-10-009A 07/27/2004 Wheels - Plastic Wheel Nut Covers Loose/Missing
- 02-06-03-010A 07/02/2004 Battery - Parasitic Drain
- 04-06-01-021 06/24/2004 Engine - New Rear Main Seal/Special Tool
- 04-06-00-047 06/24/2004 Fuel - Top Tier Detergent Gasoline Information
- 04-06-01-013 04/01/2004 Engine - Serpentine Drive Belt Wear Information
- 01-01-38-013A 10/29/2003 A/C - Unnecessary Compressor Replacement
- 03-07-30-027 06/01/2003 A/T - Oil Cooler Flushing Frequently Asked Questions
- 03-01-38-001 03/01/2003 A/C - System Sealers/Leak Detection Guidelines
- 99-06-01-012A 02/01/2003 Engine - Remanufactured Supercharger Units
- 02-06-01-008 03/01/2002 Engine - New Prelube Tool
- 01-07-30-029 10/01/2001 A/T - Core Return Product Feedback Form
- 01-09-40-002 06/01/2001 Seat Belt System - Collision Replacement Guidelines
- 01-00-89-009 05/01/2001 Key/Key Number/Security Chip - Replacement
- 01-00-89-007 04/01/2001 Emissions Inspection/Maintenance - Labor Operations
- 99-07-30-020A 04/01/2001 A/T - Service Procedure Changes
- 99-02-32-007A 02/01/2001 Steering - Vibration, Shudder, or Moan Noise
- 00-00-90-001 11/01/2000 Suspension - Chassis Lubrication Importance
- 00-07-30-011 06/01/2000 ACDelco(R) Remanufactured Transmissions - Program Update
- 00-06-04-026 06/01/2000 PCM - Returned Product Feedback Program
- 00-05-22-004 05/01/2000 Brake Fluid - Level And Filling Recommendations
- 00-06-04-021 05/01/2000 EVAP System - Service of Connectors
- 99-01-38-006A 05/01/2000 A/C - Refrigerant Recovery/Recharge Equipment
- 99-00-84-021B 04/01/2000 Warranty - GM Dealer Parts Procurement
- NHTSA00V057000 02/25/2000 Recall 00V057000: Seat Belt Retractor Failure
- 99-09-41-004 01/01/2000 Air Bag (SIR) On-Off Switch Kits, New Parts and Service
- 99-08-66-002A 01/01/2000 Trap Resistant Trunk Kit - Function/Installation
- 99-09-40-008 01/01/2000 Child Restraint - Auxiliary Seat Belt
- 99-08-50-021 12/01/1999 Front Seat Heat Element - Non-Functional
- 99-06-02-018 11/01/1999 Cooling - Thermostat Design Change
- 99-06-04-053 11/01/1999 PROM - Powertrain Control Module Reprogramming
- 99-08-42-009 11/01/1999 IP Dimmer Control - Proper Setting
- 99-08-45-005 11/01/1999 Accessory Receptacle/Cigar Lighter - Inoperative
- 99-06-02-017 10/01/1999 Cooling - Radiator Repair/Replacement Guidelines
- 99-03-10-103 10/01/1999 Wheels - Stud Removal Tool Change
- 99-07-30-021 10/01/1999 A/T - New Solenoid Testing Kit
- 99-00-89-016 09/01/1999 Warranty - Labor Time Guide Updates, 09/99
- 99-00-01-001 09/01/1999 Engine - AC Delco Remanufactured Engines
- 99-03-10-102 06/01/1999 Warranty - OE Chrome Plated Aluminum Wheel ID
- 99-08-49-006 04/01/1999 Instrument Panel - Upper Surface Reflection
- 99-06-03-002 03/01/1999 Battery - Insulator Replacement & Caution
- 99-06-03-001 03/01/1999 Battery - Testing Equipment Explained
- 83-81-34 03/01/1999 SIR - Operating Vehicle with Warning Light On
- 86-05-02 12/01/1998 Warranty - Notice of Delayed Start Process
- 83-32-09 11/01/1998 Tools - Power Steering Bleeder Adapter
- 83-32-10 11/01/1998 Tools - Adjuster Locknut Wrench
- 83-17-04 10/01/1998 Door Handles - On White Painted Vehicles Turning Yellow
- 83-15-16 10/01/1998 New Windshield/Glass Urethane Adhesive Caulking Kit
- 83-02-01 09/01/1998 Crankcase Ventilation System - Revised Maintenance
- 80-05-03 08/01/1998 Warranty - Parts Warranty Special Claims B and C
- 84-96-01 08/01/1998 Entertainment Systems - Correct Labor Codes
- 83-90-12 08/01/1998 Tools - Keyless Entry Transmitter Tester
- 68-05-02B 07/01/1998 Warranty - Courtesy Transportation Guidelines
- 83-96-05 07/01/1998 Radio Telephone/Mobile Radio - Install/Troubleshooting
- 83-90-08 06/01/1998 Cruise Control - (W/Electro Stepper Mtr.) Diagnostics
- 82-05-02 05/01/1998 Warranty - Request for Wholesale Authorization
- 82-05-05 05/01/1998 Warranty Inquiry System
- 73-71-04A 05/01/1998 Interior - Noise/Vibration/Growl, Front On Turns/Accell
- 87-61-25 05/01/1998 Connecting Rod Bearing - Revised Clearance Specification
- 87-61-24 04/01/1998 Engine - Surface Conditioning Discs Precautions
- 48-05-01C 03/01/1998 Customer Concern Not Duplicated /Verified - Labor
- 83-01-14 03/01/1998 VIN Plate - Replacement Policy and Procedure
- 83-64-09 03/01/1998 Tools - Released for CS Generator Diagnosis
- 72-05-09 02/01/1998 Warranty - GM Dealer Empowerment Program
- 82-05-01 02/01/1998 Warranty - New Vehicle/Replacement Battery
- 72-05-13 01/01/1998 Warranty - Repair/Replace Policies & Procedures
- 72-05-14 01/01/1998 Warranty - Enhanced Sublet Repair Policy
- 72-05-12 01/01/1998 Suspension - Shock Absorber/Strut Replacement Guidlines
- 73-50-37 01/01/1998 Brakes - Rotor & Hub Flange Cleaning Tool Revision
- 73-90-23 01/01/1998 Airbags - Frontal (SIR) ON-Off Switch Kits, Parts/Procs
- 48-05-02B 12/01/1997 Parts Expediting - Reimbursement Policy
- 33-17-01A 12/01/1997 Exhaust System - Paint Peeling from Painted Muffler
- 72-05-11 12/01/1997 Warranty - Rail Dust Removal & Chemical Spotting Labor
- 62-05-02A 11/01/1997 Labor - Revised Operation Z1241/Personal Property Damage
- 73-12-13 11/01/1997 A/C - PureGuard 2 Operating Alert
- 23-50-05B 11/01/1997 Brakes - Rotor Warranty Service Procedure
- 63-10-41B 11/01/1997 Power Door Locks - Inoperative/Manual Function OK
- 73-05-06 10/01/1997 Warranty - Labor Time Guide Addition
- 77-61-22 10/01/1997 Engine - Leak at Oil Pan Sealing Flange
- 73-01-09 10/01/1997 Starting - Revised Procedures for Inop Ignition Cylinder
- 77-61-16A 09/01/1997 Engine - Oil Leak at Rear of Engine Near Flywheel Cover
- 56-32-02B 09/01/1997 Steering Column - Intermittent Click Noise/Snap
- 72-05-05 08/01/1997 Warranty - Guidelines for Using E0420 Wheel Replace
- 71-63-04 08/01/1997 Fuel - Revised Sender Replacement Caution/Notices
- 72-05-06 08/01/1997 Warranty - Guidelines for I/M 240 Labor
- 72-05-04 08/01/1997 Warranty - Guidelines for Claiming Windshield Replace
- 53-65-06A 06/01/1997 Driveline - Vibration Over 37 MPH
- 73-16-08 06/01/1997 Interior - Excessive Vibration Of Rearview Mirror
- 63-17-07B 06/01/1997 Paint - Basecoat/Clearcoat Paint Systems Specifications
- 77-65-15 05/01/1997 Supercharger - Outlet Gasket Split, Air Leak
- 73-50-19 05/01/1997 Interior - Metallic Buzz/Rattle From I/P, Brakes Applied
- 73-10-54 05/01/1997 Windshield - Two-Part Urethane Adhesive For Installation
- 73-05-03 04/01/1997 Warranty - Labor Time Guide Update
- 620504 04/01/1997 Warranty - Required Claim Submission Procedures
- 631208A 04/01/1997 A/C - Tool And Equipment Maintenance
- 631050 03/01/1997 Roof Panel - Dimple Appearance Running Front to Back
- 549001A 03/01/1997 Radio - CLN Indicator ON
- 731204 02/01/1997 A/C - Systems With R12 Or R134a Service Issue
- 731049 02/01/1997 Body - Sealer Tape For Collision Repairs
- 677164 02/01/1997 A/T - Intermittent, NEUTRAL Condition at Highway Speeds
- 600503 01/01/1997 Warranty - Repair and Claims Procedures
- 631047A 01/01/1997 Cardboard Roof Insulator - Removal/Install Procedure
- 649601 01/01/1997 Compact Disc Players - CD Changer Loading Procedures
- 436407A 01/01/1997 Charging - Low Voltage Reading Or Dim Lights At Idle
- 310503C 12/01/1996 Warranty - Claim Processing
- 531212A 12/01/1996 A/C - Odor at Start up in Humid Climates
- 577106A 12/01/1996 A/T - 4T60E Cold Start Rattle Noise
- 63-10-47 12/01/1996 Cardboard Roof Insulator - R&R Procedure
- 631215 11/01/1996 A/C Compressor Seal Washer - Reference Chart
- 610111 11/01/1996 Key Code - Information
- 689601A 10/01/1996 Audio - Procedure To Handle Customer Radio Concerns
- 400501A 09/01/1996 Warranty - Corporate Parts Return Program Instructions
- 319004A 09/01/1996 Air Bag - Module Shipping/Return Procedure
- 668304A 09/01/1996 Odometer/Speedometer - ACDelco Service Center Locations
- 632002 09/01/1996 Polypropylene Foam Energy Absorbers - Repair
- 68-05-03 06/01/1996 Warranty - Goodwrench Service Lifetime Service Guarantee
- 533404A 06/01/1996 Suspension - Underbody Noise from Rear of Vehicle
- 633301 05/01/1996 Steering - Popping Noise From Front When Turning
- 531703A 05/01/1996 Aluminum Wheels - Refinishing
- 676301 05/01/1996 Fuel System - 20-30 Second Rough Idle after Hot Restart
- 636532 05/01/1996 Enhanced Emission Inspection Maintenance - Equipment
- 631209 05/01/1996 A/C - R12 or R134a Service Recommendations
- 638111 04/01/1996 Headlamp Lens - Distortion Caused by Aiming Equipment
- 531033 02/01/1996 Sunroof - Water Leak or Wind Noise
- 636401 02/01/1996 Updated Battery Replacement Catalog Numbers
- 538127 02/01/1996 Power Door Locks - Inoperative/Fuse Blows
- 531101A 01/01/1996 Heater - Reduced Driver's Side Performance
- 536508 01/01/1996 SPS/FLASH EPROM - Programming
- 539004A 01/01/1996 Security & Remote Keyless Entry System - Revision
- 516547 01/01/1996 Oxygen Sensor Test - Revised Tech 1 Mass Storage CD
- ATRATB353 01/01/1996 A/T - 4T60E 2nd Gear Starts, Shifts 1-3
- 43-01-03A 12/01/1995 Paint - Information and SPID Label
- 531619 12/01/1995 Headliner - Loose or Rattling in Rear
- 536507 12/01/1995 Enhanced Emission I/M - Program Update
- 531621 12/01/1995 Door Trim Lace - Poor Retention
- 576129A 11/01/1995 Piston Ring - Revised Identification/Installation
- 533501 11/01/1995 Front Wheel Bearing/Wheel Speed Sensor - New Design
- 536202 11/01/1995 Engine Coolant - Information on Back Service
- 531616 11/01/1995 Carpet - Wet or Smelly
- 536406 10/01/1995 Battery - Revised Replacement Procedure
- 536505 10/01/1995 SPS/EEPROM - Programming Chart
- 576132 10/01/1995 Crankshaft Balancer - Revised Service Procedure
- 538209 10/01/1995 Daytime Running Lamp - Retrofit Kits
- 536504 09/01/1995 Tech 1 & VIM - ECM Programming
- 538307 09/01/1995 Ashtray Assembly - Distorted
- 531704 09/01/1995 Paint - Polishing And Swirl Mark Removal
- 516543 08/01/1995 Service Manual - DTC P1565 Chart Revision
- 516542 08/01/1995 Engine - Cranks But Won't Run Revision
- 588302A 07/01/1995 Vehicle - AC Delco Locator Service, Electronics Exchange
- 570502 06/01/1995 Warranty Information Network System - Stage 2
- 580101 06/01/1995 Vehicle - Use of a Diagnostic Worksheet
- 539602 06/01/1995 Radio - Excessive AM Static Noise with Engine Running
- 536201 06/01/1995 Extended Life Engine Coolant - DEX-COOL(TM)
- 570102 06/01/1995 Fuel - Reformulated/Oxygenated Gasolines
- 510103 05/01/1995 GM Campaign Identification Label
- 576113 05/01/1995 Engine - Continuous Spark Knock/Oil Consumption
- 576403 05/01/1995 Starter Motor - Continues to Run After Engine is Running
- 531508 05/01/1995 `A' Pillar - Creak Noise at Right Side Base
- 516529 05/01/1995 Service manual - DTC P0712 Revision
- 516525 05/01/1995 EGR System - DTC P1406 Manual Revision
- 531611 05/01/1995 Carpet - Saturated/Wet
- 530501 04/01/1995 Labor Time Guide - Format Change
- 431218A 03/01/1995 Tools - A/C Leak Detector Maintenance Kit Availability
- 576107 03/01/1995 Balance Shaft - Special Tools and Procedure Revision
- 535001A 03/01/1995 ABS & ABS/TCS Pressure Modulator Valve - Serviceability
- 576504 03/01/1995 UART - Communication Link With Scan Tool Installed
- 570201 03/01/1995 A/T - DEXRON III Fluid Introduction
- 531502 03/01/1995 Door Handle - Discoloration in the Key Cylinder Opening
- 516502 02/01/1995 I/M Emissions Diagnostic Manual -Program
- 577101 02/01/1995 Automatic Transaxle - Product Update
- 531501 02/01/1995 Fuel Filler Door - Inoperative
- 310503A 01/01/1995 Warranty - Claims Processing
- 439021 01/01/1995 Phone, Dealer Installed - Diagnostics/Replacement
- 436510 01/01/1995 I/M 240 Program - Equipment Purchase
- ATRATB280 01/01/1995 A/T - 4T60E Oil Scoop Eliminated
- ATRATB281 01/01/1995 A/T - 4T60E New Design Pump Body And Rotor
- ATRATB282 01/01/1995 A/T - 4T60E Torrington Bearing Replaced
- ATRATB283 01/01/1995 A/T - 4T60E Wiring Harness Updates
- ATRATB284 01/01/1995 A/T - 4T60E 3rd Sprag Clutch Replaces 3rd Roller Clutch
- ATRATB285 01/01/1995 A/T - 4T60E New Design Input Clutches
- ATRATB286 01/01/1995 A/T - 4T60E Redesigned TCC Solenoid
- 431109A 12/01/1994 HVAC Display - Errors or Blower Operation Concerns
- 811526 12/01/1994 Sunroof - Repairs
- 436507 12/01/1994 Enhanced IM240 Program - Implementation Plan
- 435009 12/01/1994 Brakes, Front - Pulsation Diagnosis, Correction, Repair
- 431504A 11/01/1994 Outside Electrochromic Mirror - Revised Face R&R
- 95C08A 11/01/1994 Campaign - A/T Defective 2nd Clutch Reaction Plates
- 431215 11/01/1994 A/C - R134a Leak Detection With Tracer Dye
- 436506 10/01/1994 I/M 240 Repairs - Obtaining Technical Assistance
- 431606 10/01/1994 Leather Seat Covers - Cleaning Procedure
- 446501 10/01/1994 PROM/MEMCAL - Identification Marks
- 410103 09/01/1994 Campaign - Product Bulletin Numbering System
- 435007 09/01/1994 ABS/Traction Off Lamp Light On, DTCs 45 or 51 Set
- 431510 09/01/1994 Doors, Front - Scraping Noise/High Opening Effort
- 431221 08/01/1994 A/C - Refrigerant Capacity
- 431509 08/01/1994 Sunroof - Clicking noise
- 449001 08/01/1994 SIR DTC 24 Diagnosis
- 316501R 06/01/1993 Tools - Introduction Of The Fuel Injector Tester
- ATRATB078 11/01/1991 A/T - How To Use A Pressure Gauge
- ATRATB028 10/01/1990 A/T - Engine Vacuum Testing
- ATRATB9002006 02/01/1990 A/T - Choosing the Right ATF
- ATRATB8930 10/01/1989 A/T - Math Part II
- ATRATB8927 09/01/1989 A/T - Twenty Steps To Successful Repairs
- ATRATB8923 08/01/1989 A/T - Math Formulas Part I
- 89358 11/01/1988 Battery - Diagnosis and Charging
- ATRATB8754 09/01/1987 A/T - Front Bushing Wear
- ATRATB8748 08/01/1987 A/T - Slipping or No-Shift/Metal Sealing Rings
- 81I37 02/01/1981 Oxygen Sensors - Silica Contamination
| | | sniperdude Fanatic
| Subject: Re: FAQ: 1995-1999 Buick Riviera TSB & Recall Database Fri Apr 12, 2013 3:39 pm | |
| I pulled these from AllData, by the way. It's worth the sub if you're planning on keeping the car for a while. | |
| | | AA Administrator
| Subject: Re: FAQ: 1995-1999 Buick Riviera TSB & Recall Database Fri Apr 12, 2013 3:43 pm | |
| Mike, can you please list the same info for 96/97/98/99? Thanks! _________________ '05 GTO 6.0L • 6-spd • 95k miles • 0-60: 4.8s • 16.9 avg MPG • Nelson Ledges Lap: 1:26'95 Celica GT 2.2L • 5-spd • 165k miles • 0-60: yes'98 SC Riviera • 281k miles • 298 HP/370 TQ • 0-60: 5.79s • ET: 13.97 @ 99.28 • 4087 lb • 20.1 avg MPG • Nelson Ledges Lap: 1:30 3.4" pulley • AL104 plugs • 180º t-stat • FWI w/K&N • 1.9:1 rockers • OR pushrods • LS6 valve springs • SLP headers • ZZP fuel rails KYB GR2 struts • MaxAir shocks • Addco sway bars • UMI bushings • GM STB • Enkei 18" EV5s w/ Dunlop DZ101s • F-body calipers EBC bluestuff/Hawk HP plus • SS lines • Brembo slotted discs • DHP tuned • Aeroforce • Hidden Hitch^^^ SOLD ^^^ '70 Ninety-Eight Holiday Coupe 455cid • 116k miles^^^ SOLD ^^^ | |
| Subject: Re: FAQ: 1995-1999 Buick Riviera TSB & Recall Database Fri Apr 12, 2013 3:46 pm | |
| That is fantastic, thanks! So no recalls then?
Much appreciated.
| | | sniperdude Fanatic
| Subject: Re: FAQ: 1995-1999 Buick Riviera TSB & Recall Database Fri Apr 12, 2013 3:49 pm | |
| Sorry Aaron, AllData only gives you the one subscription per model year. I only have the 95 on there right now. 16.95 for additional vehicle or year.
| | | sniperdude Fanatic
| Subject: Re: FAQ: 1995-1999 Buick Riviera TSB & Recall Database Fri Apr 12, 2013 3:51 pm | |
Much appreciated.
Al Only two specified. One is a general campaign: NO: 95-C-08A
GROUP: 7
DATE: November 1994 SUBJECT: TRANSAXLE - IMPROPERLY STAMPED SECOND CLUTCH REACTION (STEEL) PLATES.
MODELS: CERTAIN 1995 SKYLARKS, CENTURYS, REGALS, LESABRES, PARK AVENUE/ULTRAS AND RIVIERAS
IMPORTANT :THIS BULLETIN IS A SUPPLEMENT REVISION OF BULLETIN 95-C-O8 DATED OCTOBER 1994. IT INCORPORATES PARTS COST INFORMATION CORRECTED IN DCS 94-06 DATED OCTOBER 14, 1994, AND SIMPLIFIES LABOR OPERATION USAGE. PLEASE REPLACE THE WARRANTY CLAIM INFORMATION SECTION IN 95-C-08 WITH THIS INFORMATION.....and this one, a safety recall: Recall 00V057000: Seat Belt Retractor Failure
Vehicle Description: Passenger vehicles. The rear shoulder belt(s) do not retract. A retainer could separate from a rear seat shoulder belt retractor which results in the retractor return spring becoming disengaged. In a crash, an occupant may receive more severe injuries if there is excessive slack in the shoulder belt.
GM has not yet developed a remedy for this campaign.
GM has not yet provided an owner notification schedule.
Owners who take their vehicles to an authorized dealer on an agreed upon service date and do not receive the free remedy within a reasonable time should contact Oldsmobile at 1-800-442-6537 or Buick at 1-800-521-7300. Also contact the National Highway Traffic Safety Administration's Auto Safety Hotline at 1-888-DASH-2-DOT (1-888-327-4236). | |
| | | Sponsored content
| Subject: Re: FAQ: 1995-1999 Buick Riviera TSB & Recall Database | |
Similar topics | |
