| | Recirculate Mode Intake | |
| | Author | Message |
urbanski_m Amateur
Name : Mike Age : 40 Location : Connecticut Joined : 2013-08-06 Post Count : 38 Merit : 0
| Subject: Recirculate Mode Intake Mon Jul 07, 2014 9:47 pm | |
| Does any one know where the air intake is for the HVAC recirculate mode on a 97 Riviera? I want to deodorize the HVAC system in my car and need to spray the cleaner into the interior intake while in Recirculate mode. I tried to find it myself with the system on high, but couldn't. Pictures would help | |
| | | bigdave Fanatic
| Subject: Re: Recirculate Mode Intake Mon Jul 07, 2014 10:04 pm | |
| Using a piece of paper under the dash is the best way to find it. I have never done it on a Riv, but have on other cars. With fan on high and on recirc mode, wave a piece of paper around under the dash until you feel it getting sucked in.
| | | deekster_caddy Master
| Subject: Re: Recirculate Mode Intake Tue Jul 08, 2014 4:07 pm | |
| If you have to 'deoderize' I would be willing to bet that what you really need to do is push a heavy wire (coathanger) carefully up into the drain (on the firewall, near the power steering pump, looks like a small duck's bill facing down) and let the water out. That will most likely make any unusual odors go away.
| | | albertj Master
| Subject: Re: Recirculate Mode Intake Tue Jul 08, 2014 7:32 pm | |
| - deekster_caddy wrote:
- If you have to 'deoderize' I would be willing to bet that what you really need to do is push a heavy wire (coathanger) carefully up into the drain (on the firewall, near the power steering pump, looks like a small duck's bill facing down) and let the water out. That will most likely make any unusual odors go away.
...and if that does not work, make a deodorizing solution of OdoBan (available at Sams Club and HomeDepot) per label directions, about a gallon of it in hot tap water, and pour it into the air intake on the drivers side just below the windshield wiper. | |
| | | urbanski_m Amateur
| Subject: Re: Recirculate Mode Intake Wed Jul 09, 2014 9:23 am | |
Derek, how far should the coat hanger wire go? I don't want to do any damage. | |
| Subject: Re: Recirculate Mode Intake Wed Jul 09, 2014 4:42 pm | |
Derek,
how far should the coat hanger wire go? I don't want to do any damage. I'd guess 3 inches or so. You just have to break through the layer of crap clogging the drain, and you'll start getting wet. Then you'll know it's time to stop. | |
| | | Sponsored content
| Subject: Re: Recirculate Mode Intake | |
Similar topics | |
