 valve seals and headers???
2000ws6transam
PostSubject: valve seals and headers???   Tue Apr 16, 2013 11:55 pm
First off anyone useing fel pro valve stem seals? need to get the new heads on and dont wanna wait for a set of vitons to get here. @nd questions where the heck do i find headers for our car!!!!!!!!!!!! i would like a variation to choose from
Merit : 179
PostSubject: Re: valve seals and headers???   Wed Apr 17, 2013 8:35 am
PostSubject: Re: valve seals and headers???   Wed Apr 17, 2013 10:15 am
What heads do you plan on running? when you say "new" are they ported or what?
PostSubject: Re: valve seals and headers???   Wed Apr 17, 2013 1:40 pm
http://www.ssautochrome.com/level.itml/icOid/1886
http://www.sfxperformance.com/parts/PAC701205.htm
Or, check ebay. You can usually find some on there
Are these headers known to fit Series I SC heads? The links say they are for Series II SC cars.
PostSubject: Re: valve seals and headers???   Wed Apr 17, 2013 1:45 pm
No... he has a 97 riv? Series II
PostSubject: Re: valve seals and headers???   Wed Apr 17, 2013 3:37 pm
my bad, thought this was the new guy's post. bonk
PostSubject: Re: valve seals and headers???   Wed Apr 17, 2013 3:57 pm
It's ok you're new wink
2000ws6transam
PostSubject: Re: valve seals and headers???   Wed Apr 17, 2013 7:17 pm
Heads are hand ported and polished milled down just a little bit to make sure they are flat, 5 angle valve job with over sized valves...
Merit : 179
PostSubject: Re: valve seals and headers???   Fri Apr 19, 2013 1:29 pm
You need to make sure that the LIM is ported to match. Same with the exhaust ports. I'm not sure what you're planning on doing as far as more modding is concerned, but you will most definitely need larger injectors and a good tune to match the larger valves. I could see it running lean as hell without more fuel. There is a such thing as too much air wink
