 Series I Exhaust Manifolds
Series I Exhaust Manifolds Empty
PostSubject: Series I Exhaust Manifolds   Series I Exhaust Manifolds EmptyMon Apr 22, 2013 6:21 pm
Today I started taking some of the parts off a motor we have on a stand in the shop. I took off the front and rear exhaust manifolds to prep them to swap into my car over the summer. This motor had 90k original miles on it and showed some of the things we were expecting to see.
First off, to my surprise, the entire front manifold and crossover pipe (all one piece) was lighter than the little rear manifold. The steel is much thicker on the rear.
I had read about problems with cracking manifolds on the series I and expected the rear manifolds to be more prone since they are really stuffed in there with not much room for the heat to escape but they are solid and I think it would take ALOT of heat to hurt them.
Series I Exhaust Manifolds Ee266711-6e5c-4d36-9654-9863a9544ce0_zps4c07556f
The fronts were a different story. There were four cracks around 2-4" long.
Series I Exhaust Manifolds 0fdf62d2-7d43-46fe-8605-5f69ed2d43e5_zpsfaaab54c
None of the cracks were visible with it still on the motor and 2 couldnt be seen until removing the heat shied around the crossover.
The next thing I noticed after was the welding on the inlets of the manifolds. Each is welded from the inside creating a lip of about half a dime size in spots all the way around. This would most certainly limit airflow at high RPMs I think the rear manifolds were worse but it could vary from car to car. The welds had created a buildup of hardened black junk from the exhaust that made probably cut between 1/4 and 1/2" off of the diameter of the inlets. After cleaning the junk off the welds were still more than I would like to have interfering with the exhaust....
Series I Exhaust Manifolds E2360594-2f1d-4045-b396-a61dee2b5fe0_zps8c489dcc
Series I Exhaust Manifolds Dee05534-839d-4568-9a43-35a3bf09aba2_zps3d2c7c97
Series I Exhaust Manifolds 834247d8-d42a-4ed7-8b57-d57ddc131741_zps9fc258dc
Series I Exhaust Manifolds 55293ed3-b7e1-4c51-a2f0-62b8ad0c4212_zpsa46232e0
I plan on removing the rust and corrosion and welding the cracks first, then welding inlets from the outside so I can trim away the welded lip from the inside. Then they'll probably be painted to keep them from rusting too quickly, most importantly the welds. Then we're going to wrap both sets and replace. I am not going to have these in anytime soon but hopefully mid-summer or earlier. I am not yet sure of any benefits but I will be sure to update on anything I learn or anything that can be gained.
If theres anything I might have missed or any ideas anyone has had for a job like this feel free to chime in!
Also, not sure if there is anything issues with the Series II but having headers available, its probably best to go that route anyway!
Thanks,
Dave
moldymac
PostSubject: Re: Series I Exhaust Manifolds   Series I Exhaust Manifolds EmptyWed Apr 24, 2013 12:09 pm
I've had to get cracks welded on my 95 before. Did yours have an gaskets between the block and manifold? Both the engine I pulled and the one from the yard did not have them on mine.
PostSubject: Re: Series I Exhaust Manifolds   Series I Exhaust Manifolds EmptyWed Apr 24, 2013 12:13 pm
Mine also didnt have any gaskets! Im curious to see if the motor in my car has any cracks in the manifolds!
» hmf swamp series exhaust
» exhaust snorkel
» Looking for HMF exhaust
