 1997 blowing fuel pump fuses
3 posters
skriski
1997 blowing fuel pump fuses Empty
PostSubject: 1997 blowing fuel pump fuses   1997 blowing fuel pump fuses EmptyThu May 23, 2013 3:42 am
Ive gone through all of the "usual suspects". Shorted wiring, pump relay, ICM, fuel pump module and cant seem to come up with an answer... blows fuse when everything above mentioned is unplugged. Trying to find a wiring diagram or someone who might know what else is on this circuit!!!!! Ive read rumors that the fuel circuit is taken over by the oil pressure switch after initial prime.. any truth to that?
Merit : 180
PostSubject: Re: 1997 blowing fuel pump fuses   1997 blowing fuel pump fuses EmptyThu May 23, 2013 5:58 am
Check the decal and make sure the fuel pump fuse that is Insatalled, is actually the correct amp capacity.
PostSubject: Re: 1997 blowing fuel pump fuses   1997 blowing fuel pump fuses EmptyThu May 23, 2013 11:31 am
Pull the fuse and unplug everything again, then check the 'cold' side of the fuse position to ground with an ohmmeter. If there is a short to ground there you've got a damaged wire to look for. How are you checking for "Shorted wiring"?
I don't believe the oil pressure switch tells the PCM to start/stop the fuel pump these days. That sounds old school. I think fuel pump on/off after priming is controlled by RPM (crank position signal) but not 100% sure on that.
» 97 PAU the same fuel pump as a Riv?
» Horn Keeps Blowing Fuses
» fuel line leak. need to disable fuel pump. Fuse or relay?
» Fuel pressure and fuel pump
» 96 fuel pump ID
