SuperRivL67 Member
Name : SCl67 Location : Stockton,Ca Joined : 2011-10-12 Post Count : 65 Merit : 2
| Subject: Transmission interchange question Sat May 25, 2013 11:49 am | |
| Do the n/a Riviera's have the same transmission as the SC for 1997. | |
highwaywarrior Fanatic
| Subject: Re: Transmission interchange question Sat May 25, 2013 12:14 pm | |
| I think the na rivs have the 4t60 non heavy duty... or the 4t65e non hd | |
SuperRivL67 Member
| Subject: Re: Transmission interchange question Sat May 25, 2013 12:22 pm | |
| The one I'm currently looking at I think is the hd looking at the diff.. Top of the case reads 908s side tag reads part#24210160 serial#1216284 | |
| Subject: Re: Transmission interchange question Sat May 25, 2013 1:07 pm | |
| If I'm not mistaken, the N/A cars have a different gear ratio in them. The trans might fit in, but it certainly won't shift/drive right unless the PCM is programmed to do so. S/C gear ratio is 2.93 N/A gear ratio is 3.05 | |
SuperRivL67 Member
| Subject: Re: Transmission interchange question Sat May 25, 2013 1:08 pm | |
| Subject: Re: Transmission interchange question | |
