Name : Dmitry Joined : 2016-08-28Post Count : 247 Merit : 11
Subject: Does this sound familiar? Engine squeal. Sun Feb 16, 2020 12:21 pm
I can not find the source of this annoying noise. Does this sound like a bad alternator bearing?
Subject: Re: Does this sound familiar? Engine squeal. Sun Feb 16, 2020 1:34 pm
Dang Dmitry. Ain't got no clue.
Subject: Re: Does this sound familiar? Engine squeal. Sun Feb 16, 2020 7:19 pm
Wow, that's a spooky sound. Very distinctive, someone is bound to know what it is.
Name : Larry Age : 67 Location : Oakland Gardens, NY Joined : 2007-01-23Post Count : 2179 Merit : 149
Subject: Re: Does this sound familiar? Engine squeal. Mon Feb 17, 2020 9:14 am
Take the belts off and run the engine. Might be alternator or water pump or other driven accessory.
71stagegs Enthusiast
Name : steve Age : 71 Location : L.I NY Joined : 2008-03-09Post Count : 189 Merit : 2
Subject: Re: Does this sound familiar? Engine squeal. Mon Feb 17, 2020 2:03 pm
Stan take a very long screwdriver and it put on all things turning with your ear on the other end check the belt tensioners first they make some crazy sounds
DeepFrozen Enthusiast
Subject: Re: Does this sound familiar? Engine squeal. Tue Feb 18, 2020 1:45 am
Hm. For how long is it safe to run the engine without coolant circulation? And why? Is it even possible that engine itself makes this sound? I think it is definitely something belt driven, but still - it leaves me with 5 suspects Ok, maybe 4 - I think I can safely rule out the A/C compressor. On the second thought... I think I can take the belt off when the engine is cold and safely rev the engine up couple of times - enough to make sure the noise is gone, or to find out something truly wonderful )
Subject: Re: Does this sound familiar? Engine squeal. Tue Feb 18, 2020 2:47 am
In fact, I have a special stethoscope, but, evidently, it's not enough - a pair of trained ears is a must-have component. To me everything in there is loud and noisy, I can not specify any distinctive sound source. Besides, only idler pulley and alternator can be inspected with a stethoscope. Or I simply don't know how to use it )
Subject: Re: Does this sound familiar? Engine squeal. Tue Feb 18, 2020 11:10 am
You can run the engine for a minute, long enough to tell if it is a belt driven noise, then just turn everything by hand. The problem accessory should be evident.
Name : Location : Finger Lakes of New York State Joined : 2007-05-31Post Count : 8576 Merit : 180
Subject: Re: Does this sound familiar? Engine squeal. Tue Feb 18, 2020 11:15 am
Sounds like more than one issue.
1) Intermittent screech after throttle blip: I'd look at the PS pump. Water pump failing sound I'm familiar with is more like marbles in a can.
2) do you know for sure you do not have an intake manifold or vacuum harness leak? That 3800 is kind of whistle-y.
3) probably because of where it is -- when my alternator has failed in the past, the bad bearings sound like a bad/spun engine bearing, a squeal that is really disheartening because that's what you think it is when you first hear it. truly gut-wrenching squeal...
4) try to rule out the AC first. In "auto" mode the AC runs almost all the time.
Really, I'd be thinking of re-doing any R&R on the intake (intake manifold, air cleaner, even check air cleaner housing--is it installed correctly) and turning every pulley, except the crank pulley, by hand to find any roughness or grind and replacing the pulley or driven part. I figure it would take me all day to find this by myself. Even using the long screwdriver, a stethoscope, or a piece of cutoff garden hose.
Subject: Re: Does this sound familiar? Engine squeal. Tue Feb 18, 2020 4:15 pm
Stan you will hear the grinding with a simple screwdriver using a long one you can reach all of them have done it many times it works quickly
Subject: Re: Does this sound familiar? Engine squeal. Tue Feb 18, 2020 11:55 pm
Mine is just fine I believe. Don't have such a noise
Subject: Re: Does this sound familiar? Engine squeal. Wed Feb 19, 2020 8:26 am
Bump -- so, Dmitry, what did you find?
Subject: Re: Does this sound familiar? Engine squeal. Wed Feb 19, 2020 9:53 am
So far - not much, did not have time. Yesterday I replaced the idler pulley (2 minute job) and it turned out that its bearing was dry and with a noticeable play. Alas, the idler pulley was not the source of my squeal, but the overall noise in the engine compartment dropped a notch. I'm planning a massive under-the-hood job: going to replace upper intake manifold (not just gaskets - got the brand new one), valve stem seals, alternator bearing, check up the vacuum lines and many more small things. I hope the new alternator bearing will fix my squealing.
Will report back on my progress.
Subject: Re: Does this sound familiar? Engine squeal. Wed Feb 19, 2020 9:45 pm
good luck
Subject: Re: Does this sound familiar? Engine squeal. Thu Feb 27, 2020 3:25 am
Ok, it is something related to the PCV system. I revved up the engine to produce the squeal and tried to open the oil cap - the squeal stopped immediately. Good to know it's not failing PS or water pump. I hope this problem will go away as soon as I install my new upper intake manifold (new PCV valve included).
Subject: Re: Does this sound familiar? Engine squeal. Tue Mar 24, 2020 1:51 am
Upper intake manifold replaced - no more squeals, woo-hoo!
Subject: Re: Does this sound familiar? Engine squeal. Tue Mar 24, 2020 3:58 am
Subject: Re: Does this sound familiar? Engine squeal. Wed Mar 25, 2020 10:53 am
From this:
...to this:
Congrats on finding the problems.
Subject: Re: Does this sound familiar? Engine squeal. Fri Mar 27, 2020 3:21 am
Thanks, guys.
And now - my old intake manifold.
When I flipped it over, I just couldn't stop screaming )))
