 no instrument panel
gmann3001
Name : Glenn W. Peck
PostSubject: no instrument panel   Fri Jun 07, 2013 6:31 pm
OK guys, long story short... passenger window motor died. I replaced it and now window goes down but not up...
I read that its most likely due to my broken wires in my drivers door, need ti fix asap. but after replacing the window
motor I found that my dash is dead confused I checked all fuses. then pulled out the back seat. I found a relay for the instrument
panel and it just keeps ticking, so i removed it and replaced with a good one and the good one now just ticks.
I'm thinking about replacing all the relays for good measure but not sure if that's going to help...
oh also the hvac runs hot on med. fan and has no display just dashes?
any ideas?
http://gmann3001@yahoo.com
PostSubject: Re: no instrument panel   Sat Jun 08, 2013 11:12 am
I think someone else just had this almost exact problem and it turned out to be one or more broken wires in the harness between the door and body, in the boot where it bends.
gmann3001
PostSubject: Re: no instrument panel   Fri Jun 14, 2013 12:04 am
well, I fixed the wires in the drivers door. and still no luck with the dash. I'm going to check the fuses again and change all the relays.
gmann3001
PostSubject: Re: no instrument panel   Mon Jul 15, 2013 2:39 am
ok I fixed the issue. first the relay. then found that we have several instrument fuses, 2 were bad.
replaced and now shes runnin again!
PostSubject: Re: no instrument panel   Mon Jul 15, 2013 2:56 am
great Glenn
no instrument panel
