 98 riv climate control
mdg642rf
98 riv climate control Empty
PostSubject: 98 riv climate control   98 riv climate control EmptySun Jun 23, 2013 1:19 pm
the climate control on my 98 riv went completely out. checked the fuses  all ok....any ideas before I open the wallat? I'm thinking it may be a blower resister..please help.thank you
PostSubject: Re: 98 riv climate control   98 riv climate control EmptySun Jun 23, 2013 1:31 pm
Blower control module will cause the blower fan to stop working, or work intermittently, but it should not cause the climate control to stop working, as in the control itself isn't operational. Something else must be up.
mdg642rf
PostSubject: Re: 98 riv climate control   98 riv climate control EmptySun Jun 23, 2013 1:41 pm
re hvac...would the blower control module disable heater / ac / front an rear defogger?
PostSubject: Re: 98 riv climate control   98 riv climate control EmptySun Jun 23, 2013 1:51 pm
Bad blower control module will cause the blower fan to stop working, or work intermittently (affects AC/heat/vent).
mdg642rf
PostSubject: Re: 98 riv climate control   98 riv climate control EmptySun Jun 23, 2013 2:30 pm
AA...thanks for the info...
Merit : 147
PostSubject: Re: 98 riv climate control   98 riv climate control EmptySun Jun 23, 2013 11:17 pm
open the climate control and see if one or more of your ballast resistors failed.  It will be obvious once you get the control head unit opened, and if you are handy with electronics repair will be obvious too - just be sure to use better resistors.  Ceramics or wirewounds intended for RF applications should work fine, I got mine from Digi-Key.
PostSubject: Re: 98 riv climate control   98 riv climate control EmptyWed Jun 26, 2013 3:44 pm
If it happens to be the climate control head unit and you dont feel like fixing it i have a spare one i could ship out.
PostSubject: Re: 98 riv climate control   98 riv climate control EmptyWed Jun 26, 2013 8:40 pm
I don't have my service manual nearby - can someone tell me the location of the blower control module?
TIA
PostSubject: Re: 98 riv climate control   98 riv climate control EmptyWed Jun 26, 2013 9:08 pm
Mike, here's a few links if you're going to look into the climate control head unit:
Thread is about lighting but might help you if you take the CC head unit apart: http://rivperformance.editboard.com/t126-write-up-fixing-hvac-climate-control-lighting?highlight=HVAC
My personal experience with HVAC head unit issues. Though I found a solution at first, it was only temporary and the problems I described in the thread cropped back up again. I bought a used HVAC head unit, installed it and have had 0 issues since then, around a year ago: http://rivperformance.editboard.com/t9148-hvac-issues?highlight=HVAC
Let us know what happens - I know firsthand how much of a PITA issues like these are in the summer flame
PostSubject: Re: 98 riv climate control   98 riv climate control EmptyWed Jun 26, 2013 9:11 pm
Derek, here's the write up with some pics r.e. blower control module: http://rivperformance.editboard.com/t7381-write-up-blower-motor-control-module-replacement?highlight=blower
Passenger side close to the floor when plastic is off
PostSubject: Re: 98 riv climate control   98 riv climate control EmptyThu Jun 27, 2013 12:45 pm
awesome thanks. I should have been more proactive about searching dammit! wink
PostSubject: Re: 98 riv climate control   98 riv climate control EmptyThu Jun 27, 2013 1:37 pm
Lol all good! Btw, it's a total (imo) PITA to get out just because even with my tiny little hands, it took an eon to unscrew the furthest screw... have fun! twisted
doctorthor
doctorthor
PostSubject: Re: 98 riv climate control   98 riv climate control EmptyMon Dec 14, 2015 5:14 pm
I have this strange problem with my climate control. This winter the air compressor clutch will not kick on unless I disconnect the battery and reconnect it. Then it will work perfectly parked in the driveway. All the modes work. The temp is totally controllable. The fan is fine. The clutch turns on and off with the vent button. I played with all the switches at least a half hour. No issues whatsoever. But as soon I drive it about a mile or so I stop the car. If I turn the auto button off I can hear the clutch kick off. I hit the auto button again and clutch will not turn back on. All the buttons and temp controls still work. Then i cycle battery power and its fine again. So far I have cleaned the dust off the inside temp sensor. I took out the glovebox out and shook all the wires around. I cleaned the outside temp plug and the compressor plug. By the way I serviced up the refrigerant last summer and it was blowing ice cold in auto.
doctorthor
doctorthor
PostSubject: Re: 98 riv climate control   98 riv climate control EmptyMon Dec 14, 2015 10:57 pm
Yeah I think I'm a dumbass its working exactly like its supposed to. It's all about the computer shutting off the clutch control circuit around 40 degrees. I heated up ambient temperature sensor with wife's blow dryer it works fine.
It must have been cooling off when I drove it. The outside temp in Portland is 42 degrees.. But you would still think compressor would come on in defost no matter what to clear the windowshield.
PostSubject: Re: 98 riv climate control   98 riv climate control EmptyMon Dec 14, 2015 11:22 pm
I myself am not sure if mine works as it should. I never use it hahahaha.....
doctorthor
doctorthor
PostSubject: Re: 98 riv climate control   98 riv climate control EmptyTue Dec 15, 2015 9:18 am
Ok no more dumb questions from me i just ordered up the service manuals on ebay. Think I'll wrap them up and throw them under the xmas tree. Ill tell my wife Santa must have stopped by.😁
PostSubject: Re: 98 riv climate control   98 riv climate control EmptyTue Dec 22, 2015 2:49 pm
One of the adjustments I made when tuning my car was to lower that setting to 36. It never iced up on me, and I really wanted that compressor to help dry the windshield in some crappy weather. A/C compressor still original with over 250K miles on it, and I changed that setting about 150,000 miles ago...
» Micron Radio Control
» control lines
» air traffic control !
» A BLACK WOMAN'S PERSPECTIVE ON GUN CONTROL
» control box cover with battery compartment for gpx 5000
