 '95 Rear Spring upper and lower insulators?
4 posters
AKC
AKC
'95 Rear Spring upper and lower insulators? Empty
PostSubject: '95 Rear Spring upper and lower insulators?   '95 Rear Spring upper and lower insulators? EmptyMon Aug 29, 2011 3:47 pm
Anyone have a line on the upper and lower insulators for the rear springs on a '95 Riviera?
I've been searching the forum and parts houses without much luck.
I have new rear springs and shocks to install and if I'm going to all that trouble, might as well replace the insulators while I'm at it.
Any help would be appreciated. Thanks!
Merit : 20
PostSubject: Re: '95 Rear Spring upper and lower insulators?   '95 Rear Spring upper and lower insulators? EmptyMon Jun 24, 2013 8:21 pm
Bump on this... I finally got the new car up on the lift, and I found that the rear drivers side spring seat is ripped in half. Ive looked all over and cant find anything...
Any ideas?
PostSubject: Re: '95 Rear Spring upper and lower insulators?   '95 Rear Spring upper and lower insulators? EmptyMon Jun 24, 2013 9:48 pm
http://www.ebay.com/itm/Moog-K5349-Coil-Spring-Insulator-Buick-Riviera-1997-/300465894237?pt=Motors_Car_Truck_Parts_Accessories&hash=item45f529b35d&vxp=mtr
Merit : 20
PostSubject: Re: '95 Rear Spring upper and lower insulators?   '95 Rear Spring upper and lower insulators? EmptyMon Jun 24, 2013 11:39 pm
http://www.ebay.com/itm/GM-REAR-SUSPENSION-LOWER-SPRING-INSULATOR-25627582-CADILLAC-SEVILLE-/281114745143?pt=Motors_Car_Truck_Parts_Accessories&vxp=mtr&hash=item4173be9937#shId
Its this one! Thank God for the Holy Grail of part numbers!
Merit : 180
PostSubject: Re: '95 Rear Spring upper and lower insulators?   '95 Rear Spring upper and lower insulators? EmptyTue Jun 25, 2013 9:10 pm
Ad also that GM has little taste for variety in hard parts...
Merit : 20
PostSubject: Re: '95 Rear Spring upper and lower insulators?   '95 Rear Spring upper and lower insulators? EmptyWed Jun 26, 2013 2:45 pm
Im not complaining!
» FAQ: Shocks & Struts Options
» FAQ: Aftermarket Lowering Springs
» Lower Part of Rear Bumper Cover
» Write-Up: Subframe/Cradle Mount Insulators & Bushings
» Napa 8638 upper radiator hose?
