 Loss of 4th Gear/Overdirve
rivren
Name : Ren Bortignon
Loss of 4th Gear/Overdirve Empty
PostSubject: Loss of 4th Gear/Overdirve   Loss of 4th Gear/Overdirve EmptyMon Jul 29, 2013 7:27 pm
My '95 Riv is running good but I have an issue with my '88 Oldsmobile Toronado. The transmission is not shifting into overdrive. A transmission repairman confirmed that gears 1,2 & 3 are working properly as well as the Torq Converter Clutch. He is telling me the 4th gear teeth are worn down. I believe I lost 4th gear about 2 weeks ago. I didn't even notice. I had absolutely no slipping or prior warning. My concern is to pay for mechanical transmission repair when it could be electrical. I pulled the code EO39 which relates to the TCC. The manual reference a 15amp fuse which I confirmed is good and the brake switch which could play a role. I asked the repair guy while we were doing a test drive about the brake switch and he said it and the TCC were working properly. I'd appreciate any thoughts or suggestions.
rivren
PostSubject: Re: Loss of 4th Gear/Overdirve   Loss of 4th Gear/Overdirve EmptyFri Aug 16, 2013 11:05 pm
in case anyone is interested, I salvaged a 77k trans and had my mechanic swap it out. it's been 2 weeks and 500 miles and the 1988 olds toro is running strong in R or 1 or 2 or 3 or 4th gear.
PostSubject: Re: Loss of 4th Gear/Overdirve   Loss of 4th Gear/Overdirve EmptyFri Aug 16, 2013 11:32 pm
Great news. Thanks for the update!
» Top Gear USA next week, one of our wagons represented?
» Transmission & gear-case fill, drain and oil
» 4WD Recovery gear what do you use?
» stuck in high gear.
» Kayaking gear for sale
