| please help | |
snowman8000 Amateur
Name : loren barnhart Age : 46 Location : la grange Joined : 2013-05-18 Post Count : 24 Merit : 0
| Subject: please help Mon Aug 19, 2013 2:05 pm | |
| Hello everyone I have a 95 riveria supercharged and I have heard from someone that has a 99 riv that from 95 to 99 models had a problom with one wire in the main wireing harness that would break down when it got hot has any one else had a problom like that if so what is it I'm having some probloms with my riv and I would like to know it it may be related to the story that I have heard and also how rare is the 95 model supercharged dose anyone know how many we're made and how I can find out the number my car is thank you
Please I need info I went to start my car this morning it started just fine but for the first time the check engine light came on I diddent think much of it as I know the oxygen sensor needs to be replaced and I put it in drive and it acted like it had no power at all I shut the car off and re started it and the check engine light went off and it had power again WHAT COULD BE WRONG its a 95 buick riveria supercharged | |
| Subject: Re: please help Mon Aug 19, 2013 2:30 pm | |
| Possibly a loose, brittle or cracked wire in the engine harness, could have been a cracked vacuum line... Lots of possibilities. The good news is that if the check engine light was on, there will be a code stored in the computer's history. Anyone with an OBD-1.5 code reader can get the code for you. The bad news is that OBD-1.5 is kind of rare. Most cars had OBD-1 (pre-1995) or OBD-2 (or II, post-1996). Without the code there isn't much else we can tell you.
Also, the O2 sensor is one of the most mis-diagnosed parts. If the check engine light/computer isn't telling you it's a dud, it doesn't need to be replaced. That will keep the check engine light on as well. More likely that you have a vacuum leak or some other air leak on the intake side. (see above 1st sentence about possible vacuum leaks) | |
matt270avian Expert
| Subject: Re: please help Mon Aug 19, 2013 2:32 pm | |
| Almost sounds like a vacuum leak. Can anyone confirm? | |
snowman8000 Amateur
| Subject: Re: please help Mon Aug 19, 2013 2:36 pm | |
| Can any codes be pulled on it if the check engine light it off | |
snowman8000 Amateur
| Subject: Re: please help Mon Aug 19, 2013 2:39 pm | |
| Ok so a air intake leak or vacume leak could be causing loss of power like that
It also has died on me before at idle and wouldent start again till I let it sit for about 30 mins or so | |
matt270avian Expert
| Subject: temp Mon Aug 19, 2013 3:06 pm | |
| I doubt it. You could try autozone, but I think the code is lost when the light goes off. | |
| Subject: Re: please help Mon Aug 19, 2013 3:15 pm | |
| As Deekster has worded so nicely, go and get the vehicle scanned. A Check Engine Light means there is a code stored in the PCM. Whether it's on now or not, there is a code stored. You need to have that code pulled before we can give you any type of REAL advice. Cars can, and will stop running for numerous problems. We can't tell you what's wrong with the car, or get you started in the right direction without a code..... | |
snowman8000 Amateur
| Subject: Re: please help Mon Aug 19, 2013 3:32 pm | |
| Subject: Re: please help Mon Aug 19, 2013 4:53 pm | |
| Subject: Re: please help Mon Aug 19, 2013 5:08 pm | |
| Subject: Re: please help | |
| please help | |
