| FAQ: Programming a New Keyless Entry Remote | |
+57100percentjake BMD Rivit slugranch llamalor2112 sniperdude jbeganny th3fr4nchi5e Trystlore riviera559 nothincame2mind robotennis61 Cmurphy Abaddon shrek BrianEsser LARRY70GS 98inSFl Rickw maximum chrldo Eldo Hard4unot2 slacker2620 DEMonte1997 albertj dnyce200 71stagegs dscott2000 EatDirtFartDust Sweepspear Karma 95ParkAveUltra deekster_caddy manofmany GMFreak8 curious riv mdhall1 Ryan from Ohio rivparadise 98RIV7777 ibmoses 97Riv-Jon 96riv racinfan mayfair4life187 99Rivman steel2040 SpaceBar jimmyriv T Riley AA 1998 Riv jax95riv NO 4 EVR 98riv 5 rivs rgt now 61 posters |
maximum Amateur
Name : Mark Age : 61 Location : NW Indiana Joined : 2010-03-04 Post Count : 27 Merit : 0
| Subject: Re: FAQ: Programming a New Keyless Entry Remote Fri Mar 12, 2010 6:28 pm | |
| Subject: Re: FAQ: Programming a New Keyless Entry Remote Fri Mar 12, 2010 7:40 pm | |
| - maximum wrote:
- wheres that located ?
It's under the instrument panel on the passenger side. If you want to work on these cars, you need a factory service manual(FSM). That is not optional, these cars are very complicated. The FSM has all the trouble shooting charts so that you don't end up replacing parts you don't have to. The charts are very involved, and too much to post here. Did you follow the programming procedure and remove the jumper before you shut the ignition? I never did get an answer on that one. | |
maximum Amateur
| Subject: Re: FAQ: Programming a New Keyless Entry Remote Sat Mar 13, 2010 8:25 am | |
| I tryed but the car never reconized the key fob | |
| Subject: Re: FAQ: Programming a New Keyless Entry Remote Sat Mar 13, 2010 8:37 am | |
| - maximum wrote:
- I tryed but the car never reconized the key fob
I would try getting another key fob. Yours may be wrong, or it is defective. | |
| Subject: Re: FAQ: Programming a New Keyless Entry Remote Sat Mar 13, 2010 8:46 am | |
| This is the one I have.
http://cgi.ebay.com/ebaymotors/1996-1997-1998-1999-Buick-Riviera-Keyless-Entry-Remote_W0QQcmdZViewItemQQhashZitem1bf90eaf18QQitemZ120142606104QQptZMotorsQ5fCarQ5fTruckQ5fPartsQ5fAccessories | |
| Subject: Re: FAQ: Programming a New Keyless Entry Remote Sat Mar 13, 2010 8:50 am | |
| Here is another place to order.
https://www.remotesandkeys.com/SearchResults.asp?Cat=3723
Does the number on the back of your remote match one of these numbers? Current GM P/N: 25678792 P/N on back of remote: 25678792, or 25628814, or 25668603 | |
BrianEsser Enthusiast
Name : Brian Esser Age : 47 Location : Ohio Joined : 2010-01-22 Post Count : 168 Merit : 8
| Subject: Re: FAQ: Programming a New Keyless Entry Remote Sat Mar 13, 2010 10:27 am | |
| - LARRY70GS wrote:
- This is the one I have.
http://cgi.ebay.com/ebaymotors/1996-1997-1998-1999-Buick-Riviera-Keyless-Entry-Remote_W0QQcmdZViewItemQQhashZitem1bf90eaf18QQitemZ120142606104QQptZMotorsQ5fCarQ5fTruckQ5fPartsQ5fAccessories Wow, that's expensive. I just ordered mine for $29 with free shipping. Should be here today in fact. hope it works. | |
maximum Amateur
| Subject: Re: FAQ: Programming a New Keyless Entry Remote Sat Mar 13, 2010 11:55 am | |
| it has the # 25668603 and fcc id KOBUT1BT | |
maximum Amateur
| Subject: Re: FAQ: Programming a New Keyless Entry Remote Sat Mar 13, 2010 12:00 pm | |
| i know the remotes work, he was useing them up untill a couple weeks before I got them, his wife wreaked the car, but he kept the remotes, and gave them to me | |
| Subject: Re: FAQ: Programming a New Keyless Entry Remote Sat Mar 13, 2010 12:18 pm | |
| - maximum wrote:
- it has the # 25668603 and fcc id KOBUT1BT
I'd try another Key Fob before trying anything else. You should have more than one anyway. | |
ibmoses Aficionado
| Subject: Re: FAQ: Programming a New Keyless Entry Remote Sat Mar 13, 2010 1:49 pm | |
| Be positive you have pins #4 and #8 shorted. It would be easy to get the pins wrong...
The #4 and #8 pins WILL have the metal conductors in them | |
maximum Amateur
| Subject: Re: FAQ: Programming a New Keyless Entry Remote Sat Mar 13, 2010 2:24 pm | |
| got the tight pins, and have 2 remotes and tryrd the both,,,,this is getting to be APITA !!! | |
| Subject: Re: FAQ: Programming a New Keyless Entry Remote Sat Mar 13, 2010 2:31 pm | |
| Have you got the troubleshooting guide from the FSM. Because it sounds like there isn't anything more that can be done on the "Simple" side of things, now you have follow the guide in the book and you will solve the problem. There is a lack of communication between the fob / remote and car, it would seem. | |
| Subject: Re: FAQ: Programming a New Keyless Entry Remote Sat Mar 13, 2010 2:33 pm | |
| - Rickw wrote:
- Have you got the troubleshooting guide from the FSM.
Because it sounds like there isn't anything more that can be done on the "Simple" side of things, now you have follow the guide in the book and you will solve the problem. There is a lack of communication between the fob / remote and car, it would seem. ...time for that TechII. Albertj | |
| Subject: Re: FAQ: Programming a New Keyless Entry Remote Sat Mar 13, 2010 2:36 pm | |
| Considering you got the remotes for free, the best price going, I would ask your local GM dealer how much do they charge to program the remotes with the Tech2. Doesn't take long to do and the price charged really depends on the shop and how busy they are. | |
maximum Amateur
| Subject: Re: FAQ: Programming a New Keyless Entry Remote Sat Mar 13, 2010 3:38 pm | |
| I might just go ahead and get a remote entry/start for it, and give the remotes back to my friend ! | |
| Subject: Re: FAQ: Programming a New Keyless Entry Remote Sat Mar 13, 2010 10:51 pm | |
| If you chose that route, be aware that many people with Riviera's have had major problems with the conflict of an aftermarket Remote Start and Alarm System installation. The car has a problem if the system isn't installed by someone that know's the Riv's existing Alarm and Pass-Key systems. Do a search on here for some tips to pass on to your installer. Try searching for Alarm System's or Remote Start Systems and Pass-Key. It has been done with some success but there have also been a lot of complaints after being installed for a while that end up requiring the removal of all aftermarket systems. Again do yourself a favor before pricing out or having something installed and do the searches on here. You may find some good info that you can print out and give to your installer for a heads up. | |
maximum Amateur
| Subject: Re: FAQ: Programming a New Keyless Entry Remote Sun Mar 14, 2010 11:23 am | |
| ok thanks for all the help and the heads up about installing a aftermarket system | |
| Subject: Re: FAQ: Programming a New Keyless Entry Remote Sun Mar 14, 2010 6:55 pm | |
| A few things...
- The BCM and the MALL are the same thing. MALL must be an older term for the Body Control Module, as they are used interchangeably in the manual, but I've never been able to find out what MALL stands for... Any idea, Albert?
- I don't think the BCM is on the passenger side, I believe it is on the driver's side near the LCM (Lamp Control Module.)
- The BCM/MALL isn't the interface for the keyfobs, the RFA (Remote Function Actuator) is... This module is beneath the package tray, right behind the RR speaker in the trunk. While it's unlikely, I suppose you should check that this module is in place and that the connectors are in good shape. | |
| Subject: Re: FAQ: Programming a New Keyless Entry Remote Sun Mar 14, 2010 7:33 pm | |
| - Eldo wrote:
- A few things...
- The BCM/MALL isn't the interface for the keyfobs, the RFA (Remote Function Actuator) is... This module is beneath the package tray, right behind the RR speaker in the trunk. While it's unlikely, I suppose you should check that this module is in place and that the connectors are in good shape. I've never looked for the BCM, so I pulled out my FSM, and it gives contradictory descriptions on the location. On the component locator page, it states, "under the right side of the IP near the rear of the IP compartment". The next page under BCM component views, it says, "Passenger Compartment under the left side of the instrument panel" Does anyone else find the FSM very difficult to use? I find it difficult to find things in it, and once you find something, you end up having to skip around trying to find other referenced things in different sections of the FSM. It drives me nuts sometimes, and makes making a repair or finding a fault so much more difficult than it has to be. I think it could be organized a lot better. | |
| Subject: Re: FAQ: Programming a New Keyless Entry Remote Sun Mar 14, 2010 9:04 pm | |
| - Eldo wrote:
- A few things...
- The BCM/MALL isn't the interface for the keyfobs, the RFA (Remote Function Actuator) is... This module is beneath the package tray, right behind the RR speaker in the trunk. While it's unlikely, I suppose you should check that this module is in place and that the connectors are in good shape. Eldo got it right. Albertj | |
| Subject: Re: FAQ: Programming a New Keyless Entry Remote Sun Mar 14, 2010 9:41 pm | |
| - LARRY70GS wrote:
- Eldo wrote:
- A few things...
Does anyone else find the FSM very difficult to use? I find it difficult to find things in it, and once you find something, you end up having to skip around trying to find other referenced things in different sections of the FSM. It drives me nuts sometimes, and makes making a repair or finding a fault so much more difficult than it has to be. I think it could be organized a lot better. Larry your correct about some discrepancies in the manual. But component location changes were common during production that even if we were to do a complete manual re-write we would end up with a manual that had inconsistencies from car to car depending on the MFG date of the car. I do agree with need to bounce around a lot. They could be organized better. But I have found every MFG has a different way of laying out the information needed. Some are intuitively easier than others for sure. The GM ones take a little more constant use to get used to finding what you are looking for, there is no doubt they could be better in how they are organized. They could at least reference the other sections and pages that are related to what you are working on, instead of having to jump around and find it. Or ask someone else the question to your problem because you are so frustrated with the book. That's where having both Alldata and the FSM or access to Mitchell as well is helpful. If you have all 3 it becomes a bit easier, but you end up with discrepancies between them and can end up confused as to which is the correct info. It can be a no win, but some data is still better than none. These are the same problems the mechanics in the field encounter everyday as they are trying to fix your car and not spend more time than necesary, not only researching but fixing the problem. Experience helps tremendously but there are times when the mechanic that is highly experienced encounters the same problem, a unit or control box is not where it is supposed to be due to a mid year change and time is money. | |
| Subject: Re: FAQ: Programming a New Keyless Entry Remote Mon Mar 15, 2010 11:29 am | |
| - Rickw wrote:
- LARRY70GS wrote:
- Eldo wrote:
- A few things...
Does anyone else find the FSM very difficult to use? I find it difficult to find things in it, and once you find something, you end up having to skip around trying to find other referenced things in different sections of the FSM. It drives me nuts sometimes, and makes making a repair or finding a fault so much more difficult than it has to be. I think it could be organized a lot better. Larry your correct about some discrepancies in the manual. But component location changes were common during production that even if we were to do a complete manual re-write we would end up with a manual that had inconsistencies from car to car depending on the MFG date of the car. I do agree with need to bounce around a lot. They could be organized better. But I have found every MFG has a different way of laying out the information needed. Some are intuitively easier than others for sure. The GM ones take a little more constant use to get used to finding what you are looking for, there is no doubt they could be better in how they are organized. They could at least reference the other sections and pages that are related to what you are working on, instead of having to jump around and find it. Or ask someone else the question to your problem because you are so frustrated with the book. That's where having both Alldata and the FSM or access to Mitchell as well is helpful. If you have all 3 it becomes a bit easier, but you end up with discrepancies between them and can end up confused as to which is the correct info. It can be a no win, but some data is still better than none. These are the same problems the mechanics in the field encounter everyday as they are trying to fix your car and not spend more time than necesary, not only researching but fixing the problem. Experience helps tremendously but there are times when the mechanic that is highly experienced encounters the same problem, a unit or control box is not where it is supposed to be due to a mid year change and time is money. Thanks Rick, I'm glad it isn't just me. Still, the FSM is better than nothing. There's no way to fix these cars without one | |
| Subject: Re: FAQ: Programming a New Keyless Entry Remote Tue Mar 16, 2010 10:26 am | |
| Just received mine this morning and following the direction from the first page, had it programmed on the second try. The trick is definitely to depress the buttons at the exact time. Now I need to read up how to customize all my settings now. lol | |
| Subject: Re: FAQ: Programming a New Keyless Entry Remote Tue Mar 16, 2010 6:20 pm | |
| - BrianEsser wrote:
- Just received mine this morning and following the direction from the first page, had it programmed on the second try. The trick is definitely to depress the buttons at the exact time. Now I need to read up how to customize all my settings now. lol
Yep, there is no room for error or variation with that button press thing. Albertj | |
| Subject: Re: FAQ: Programming a New Keyless Entry Remote | |
