| FAQ: Programming a New Keyless Entry Remote | |
+57100percentjake BMD Rivit slugranch llamalor2112 sniperdude jbeganny th3fr4nchi5e Trystlore riviera559 nothincame2mind robotennis61 Cmurphy Abaddon shrek BrianEsser LARRY70GS 98inSFl Rickw maximum chrldo Eldo Hard4unot2 slacker2620 DEMonte1997 albertj dnyce200 71stagegs dscott2000 EatDirtFartDust Sweepspear Karma 95ParkAveUltra deekster_caddy manofmany GMFreak8 curious riv mdhall1 Ryan from Ohio rivparadise 98RIV7777 ibmoses 97Riv-Jon 96riv racinfan mayfair4life187 99Rivman steel2040 SpaceBar jimmyriv T Riley AA 1998 Riv jax95riv NO 4 EVR 98riv 5 rivs rgt now 61 posters |
Sweepspear Fanatic
| Subject: Re: FAQ: Programming a New Keyless Entry Remote Thu Mar 19, 2009 12:13 pm | |
| I just bend a paper clip into a U shape. | |
EatDirtFartDust Fanatic
Name : The Josh Age : 40 Location : Somewhere between Sullivan and Saint Peters Missouri. Joined : 2009-03-27 Post Count : 284 Merit : 2
| Subject: Re: FAQ: Programming a New Keyless Entry Remote Wed Apr 08, 2009 11:02 pm | |
| This is a gravedig, I know... I just recently got a remote through ebay from KeylessRide.com and the directions had me looking for some phantom pin to ground in the trunk, by the keyless module... wrong. I found the DLC on the drivers side, then I used this handy detonator I assembled a few years ago: It consists of a 60 cent momentary switch from Radio Shack and a length of speaker wire. I've used it for model rockets, testing circuits and even a remote-controlled paintball gun (I'd be happy to tell the story ) So I slid one wire into pin 4, and one into pin 8. Closed the door. Turned on the key. Held down the button and heard the door locks cycle, then held the unlock button on each of the two remotes. Then let go of the "detonator" button and whala, worked like a charm. | |
dscott2000 Enthusiast
Name : Scott Age : 42 Location : Kansas City, MO Joined : 2008-07-27 Post Count : 160 Merit : 0
| Subject: Re: FAQ: Programming a New Keyless Entry Remote Sun Apr 12, 2009 10:07 pm | |
| - 98RIV7777 wrote:
- There's away to program them I just forget how to, I'll look it up as soon as I get home for you, probally later tomight or first thing in the morning
Here is how I reprogrammed my remote to my 97 Bonneville. All you have to do is, push the lock and unlock buttons at the same time until your lights blink. Then, your remote will be re programmed to your car. | |
71stagegs Enthusiast
Name : steve Age : 71 Location : L.I NY Joined : 2008-03-09 Post Count : 189 Merit : 2
| Subject: keyless remote Sun Jul 26, 2009 12:02 am | |
| Does any one know how to program remote Thanks Steve | |
ibmoses Aficionado
| Subject: Re: FAQ: Programming a New Keyless Entry Remote Sun Jul 26, 2009 8:58 am | |
dnyce200 Amateur
Name : dnyce Location : baltimore Joined : 2009-07-15 Post Count : 31 Merit : 0
| Subject: Programming a Remote (Please Help) Sun Dec 13, 2009 11:57 pm | |
| Hello guys dnyce here i havent been on here in a while but my rivi is coming together now, im trying to program a remote for the stock alarm system. I recently bought it from ebay thru the company called mykeyless.com. Im having a problem locating the DLC (Data Link Connector) under the dashboard. The remote came with all the directions Im not that experienced in this just wanted some advice from someone who has expertise in this. Oh yea i have a 95 Riviera. Thanks Guys. | |
| Subject: Re: FAQ: Programming a New Keyless Entry Remote Mon Dec 14, 2009 12:38 am | |
| Previous owner or a mechanic may have pushed the DLC into the panel. Not a big deal.
The DLC is **supposed** to be in that rectangular slot under the left side of the dash. Just remove the screws that hold the panel up, take out the panel and it should be pretty easy to find the DLC; it will be probably be dangling from somewhere near the steering shaft. If not, maybe someone was in there already and stuck it up there so it would not rattle - just us a flashlight and find it. WHen you find it the program your remote per instructin. For your convenience you may want to slip the DLC back into the slot on that kick panel you pulled off You may (or may not) want to use some foam-based double sided trim tape or some of those clear 3M mounting squares (for posters and such) to stick on the mounting ears so it does not slide out so easily.
dnyce200 Amateur
| Subject: Re: FAQ: Programming a New Keyless Entry Remote Mon Dec 14, 2009 12:55 am | |
| Thanks Albertj for the advice i will be working on this in the morning, but quik question in the directions it says that i have to jump two ports in the DLC connector its says something about a jumper wire to connect it to the two ports on the DLC connector, were do i get this jumper wire from??? | |
| Subject: Re: FAQ: Programming a New Keyless Entry Remote Mon Dec 14, 2009 1:01 am | |
| I don't know; however, some have been known to use a partially unbent paper clip.
...be careful in there.
ibmoses Aficionado
| Subject: Re: FAQ: Programming a New Keyless Entry Remote Mon Dec 14, 2009 7:48 am | |
DEMonte1997 Aficionado
| Subject: Re: FAQ: Programming a New Keyless Entry Remote Mon Dec 14, 2009 7:54 am | |
| Do all Rivs have the DLC just dangling? I noticed that is the case with mine. Had to laugh when I was uploading a file to my PCM and realized it was just hanging there via the wires. I'm probably going to fab up a bracket for it. | |
ibmoses Aficionado
| Subject: Re: FAQ: Programming a New Keyless Entry Remote Mon Dec 14, 2009 9:39 am | |
| Mine is bolted down to the dash or something.^^^^follow the link in my previous post for a pic. Bert | |
| Subject: Re: FAQ: Programming a New Keyless Entry Remote Mon Dec 14, 2009 5:39 pm | |
| On mine the DLC has little ears that fit into a couple slots around a hole in the driver side knee panel under the dash. *EVERY* time my car is in for service and the techs use the thing, they shove it into the hole. Used to tick me off until I saw why - the way GM has it in there, the Tech II is really tough to use. It is a whole lot easier if you pull the DLC out of the slots and dangle it under the dash. Then the issue is it's about impossible to fit it back in unless you remove the knee panel - which for various reasons most techs are not going to do. So they shove it up under the dash.
So when I get a moment after such a service I'll pull the panel (it does not take long at all) slip the DLC back in place and refit the panel. Gotta make sure to slip the panel into the nylon clip on the firewall or else it rattles (sometimes).
If one wanted to one could probably stick it in place for good with a couple of those silicone Scotch poster squares, or a couple 1/2" or so long sheet metal or trim screws, in the obvious places.
dnyce200 Amateur
| Subject: Re: FAQ: Programming a New Keyless Entry Remote Mon Dec 14, 2009 5:42 pm | |
| Thanks guys i successfully programmed the remote i used a old stereo wire as the jumper wires and connected to two ends to the DLC and its works!!! I love making progress. Thanks for the advice | |
slacker2620 Special
Name : Thomas Joined : 2009-11-13 Post Count : 8 Merit : 0
| Subject: Keyless Remotes Thu Dec 17, 2009 9:56 pm | |
| I have a 95 rivi and never got either remote with it for the keyless entry. Can I buy 2 remotes off ebay and program them both? I was under the impression that you had to have at least one original for it to work?
Slacker | |
99Rivman Aficionado
| Subject: Re: FAQ: Programming a New Keyless Entry Remote Fri Dec 18, 2009 8:34 am | |
| No you don't have to have an original one, actually when you do the programming if you had a working remote it has to be re-programmed at the same time as the new one. So, if you get two replacements they will need to be programmed at the same time. | |
Hard4unot2 Amateur
Name : Herb Location : Detroit Joined : 2009-12-18 Post Count : 41 Merit : 0
| Subject: Keyless Entry Remote Mon Jan 18, 2010 2:26 pm | |
| I brought a pad off ebay and played contortionist this weekend but could not get the keypad to cycle. I had two different instruction sheets for the '95 Riv but no luck. One sheet involved closing the doors the other didn't. | |
99Rivman Aficionado
| Subject: Re: FAQ: Programming a New Keyless Entry Remote Mon Jan 18, 2010 4:36 pm | |
| If I remember correctly the doors need to be closed to program the remotes. That's how it was on the '99 anyway.
HTH | |
| Subject: Re: FAQ: Programming a New Keyless Entry Remote Mon Jan 18, 2010 4:56 pm | |
| I think this is another of those '95-only problems...
Herb, the keyfob is rectangular rather than slightly tear-drop shape, right? | |
chrldo Special
Name : CHRLDO Location : Pittsburgh Joined : 2009-11-17 Post Count : 9 Merit : 0
| Subject: Re: FAQ: Programming a New Keyless Entry Remote Thu Jan 21, 2010 8:05 am | |
| i'd like to program a remote for my 95 riv , can some one give me instructions? | |
maximum Amateur
Name : Mark Age : 61 Location : NW Indiana Joined : 2010-03-04 Post Count : 27 Merit : 0
| Subject: Re: FAQ: Programming a New Keyless Entry Remote Wed Mar 10, 2010 3:38 pm | |
| I have a 97, and got 2 new key fobs, but can't get the car to find them, tryed 2 different methods and neither worked, Butt, my drivers side electric lock isn't working, could this have something to do with it ?? | |
| Subject: Re: FAQ: Programming a New Keyless Entry Remote Wed Mar 10, 2010 4:01 pm | |
| Subject: Re: FAQ: Programming a New Keyless Entry Remote Wed Mar 10, 2010 5:30 pm | |
| - maximum wrote:
- I have a 97, and got 2 new key fobs, but can't get the car to find them, tryed 2 different methods and neither worked, Butt, my drivers side electric lock isn't working, could this have something to do with it ??
Easiest thing is to take the car and fobs to somoeone who has a TechII. Dealers do, but you *may* be able to find a larger independent garage who does and can sync your new fobs. I do not have my FSM set at the moment, but there's instructions in there for syncing fobs w/o a TechII. Although I admit I've never done that. I'd have my car in for other service and say "oh by the way my fob quit working will you please re-sync them while you do this other stuff." As an adjunct to other work the charge if any was minimal. Albertj | |
| Subject: Re: FAQ: Programming a New Keyless Entry Remote Wed Mar 10, 2010 5:42 pm | |
| - dscott2000 wrote:
Here is how I reprogrammed my remote to my 97 Bonneville. All you have to do is, push the lock and unlock buttons at the same time until your lights blink. Then, your remote will be re programmed to your car. To clarify, that is not programming, it is "re-synchronizing" the remotes... This is what you do with a remote that is already programmed to the car, but only works on the panic button function because the rolling codes have come out of sync. The process below, along with Bert's photo up above of how the DLC is numbered, is how to program them: Jumper the data line connector (DLC) terminal 8 to terminal 4. Close all of the doors. Turn ON the ignition switch (The door will cycle to LOCK). Press and hold the following buttons on one of the transmitters: * LOCK, and * UNLOCK (After a 30 second delay, the doors will lock and unlock.) PRESS THOSE 2 BUTTONS AS SIMULTANEOUSLY AS POSSIBLE!!In order to program extra transmitters, repeat the last step with each one.
maximum Amateur
| Subject: Re: FAQ: Programming a New Keyless Entry Remote Wed Mar 10, 2010 10:21 pm | |
| so theres no way I can program the key fobs to work with my riviers without taking it to someone that has a techll ? | |
| Subject: Re: FAQ: Programming a New Keyless Entry Remote | |
