| FAQ: Programming a New Keyless Entry Remote | |
+57100percentjake BMD Rivit slugranch llamalor2112 sniperdude jbeganny th3fr4nchi5e Trystlore riviera559 nothincame2mind robotennis61 Cmurphy Abaddon shrek BrianEsser LARRY70GS 98inSFl Rickw maximum chrldo Eldo Hard4unot2 slacker2620 DEMonte1997 albertj dnyce200 71stagegs dscott2000 EatDirtFartDust Sweepspear Karma 95ParkAveUltra deekster_caddy manofmany GMFreak8 curious riv mdhall1 Ryan from Ohio rivparadise 98RIV7777 ibmoses 97Riv-Jon 96riv racinfan mayfair4life187 99Rivman steel2040 SpaceBar jimmyriv T Riley AA 1998 Riv jax95riv NO 4 EVR 98riv 5 rivs rgt now 61 posters |
maximum Amateur
Name : Mark Age : 61 Location : NW Indiana Joined : 2010-03-04 Post Count : 27 Merit : 0
| Subject: Re: FAQ: Programming a New Keyless Entry Remote Wed Mar 10, 2010 10:23 pm | |
| Jumper the data line connector (DLC) terminal 8 to terminal 4. Close all of the doors. Turn ON the ignition switch (The door will cycle to LOCK). Press and hold the following buttons on one of the transmitters:
* LOCK, and * UNLOCK (After a 30 second delay, the doors will lock and unlock.)
In order to program extra transmitters, repeat Step 5.
when I try this it cycles to lock unlock, but never finds the fobs ?? any help ? as to why? | |
| Subject: Re: FAQ: Programming a New Keyless Entry Remote Wed Mar 10, 2010 10:46 pm | |
| When i got one replacement for my car a long time ago i had the exact same problem and out of frustration I brought it to the dealer for programming with a GM Tech 2. I forget what they charged me, but it worked. I know it cost more to program it than it did to buy a used one on EBay. But I did not have the benefit of this site to ask questions at the time. So, I'm sorry to say I don't have an answer other than to go to the dealer. Sorry | |
| Subject: Re: FAQ: Programming a New Keyless Entry Remote Wed Mar 10, 2010 10:52 pm | |
| - maximum wrote:
- Quote :
- Jumper the data line connector (DLC) terminal 8 to terminal 4.
when I try this it cycles to lock unlock, but never finds the fobs. any help as to why? It cycles to lock when you turn the key, or double-cycles after 30 seconds of holding down both buttons on the keyfob? ALSO: Are the FCC ID numbers on the back of the fobs the same as the original?
| Subject: Re: FAQ: Programming a New Keyless Entry Remote Wed Mar 10, 2010 11:05 pm | |
| I'll have to try this again with an old remote i have after replacing the battery again and see what happens. But up to this point I've had no luck in the past with this procedure either.
BTW: The FCC ID numbers on all mine are exactly the same.
| Subject: Re: FAQ: Programming a New Keyless Entry Remote Wed Mar 10, 2010 11:07 pm | |
when I try this it cycles to lock unlock, but never finds the fobs ?? any help ? as to why? You have to press the lock and unlock buttons at about exactly the same time, which is a neat trick if you can do it and impossible if you have chunky fingers. Nothing will happen for about 30 seconds, then the locks will cycle. Albertj | |
| Subject: Re: FAQ: Programming a New Keyless Entry Remote Wed Mar 10, 2010 11:09 pm | |
| - maximum wrote:
- so theres no way I can program the key fobs to work with my riviers without taking it to someone that has a techll ?
If you tried the instructions and could not get them to work then you need to find someone with a techII. If you have not tried the instructions yet, repeated asking is unliely to be effective. Also - be sure the batteries in the remote(s) are in fact good and that you indeed have the correct remotes for your Riv. Albertj
| Subject: Re: FAQ: Programming a New Keyless Entry Remote Wed Mar 10, 2010 11:16 pm | |
| - Rickw wrote:
- I'll have to try this again with an old remote i have after replacing the battery again and see what happens.
BTW: The FCC ID numbers on all mine are exactly the same. Actually, I was quizzing Maximum about this. But you're right, the FCC ID number have to be the same ones the car was built for... There are millions of identical-looking remotes out there, but the RFA in each car only accepts a certain FCC ID. Another thing, Rick, don't bother with the old remote. Replacing the battery on a remote that has already been programmed to the car would only require re-synchronizing, not reprogramming. Plus, if you go into programming mode, you'll wipe out the settings for the other existing remotes... | |
| Subject: Re: FAQ: Programming a New Keyless Entry Remote Thu Mar 11, 2010 12:36 am | |
| - maximum wrote:
- I have a 97, and got 2 new key fobs, but can't get the car to find them, tryed 2 different methods and neither worked, Butt, my drivers side electric lock isn't working, could this have something to do with it ??
I hope your not expecting a new key fob to fix a broken electric drivers side door lock.? That's not gonna happen. | |
98inSFl Enthusiast
Name : Ed Location : WPB Florida Joined : 2010-01-16 Post Count : 249 Merit : 14
| Subject: Re: FAQ: Programming a New Keyless Entry Remote Thu Mar 11, 2010 12:51 am | |
| Over my way Auto Zone had a neat fob tester attached to a selection of battery's ... | |
maximum Amateur
| Subject: Re: FAQ: Programming a New Keyless Entry Remote Thu Mar 11, 2010 9:10 am | |
| I don't have the old remotes, didn't get them with the car, a friend had a couple from his Park ave that he gave me to try | |
| Subject: Re: FAQ: Programming a New Keyless Entry Remote Thu Mar 11, 2010 9:59 am | |
| make sure you counted the pins in the DLC right.
apology for my earlier error.
ibmoses Aficionado
| Subject: Re: FAQ: Programming a New Keyless Entry Remote Thu Mar 11, 2010 10:48 am | |
| See post # 6 in this thread: The remotes for a : 96-99 Riv, PA, Lesabre or Bonneville are the same. Or at leat thats what I remember that I determined when looking on ebay. Verify the FCC ID Code on the back of the remote is:KOBUT1BT. If the code is different it wont work Bert | |
maximum Amateur
| Subject: Re: FAQ: Programming a New Keyless Entry Remote Thu Mar 11, 2010 1:28 pm | |
| the remotes do have this code on the back KOBUT1BT | |
| Subject: Re: FAQ: Programming a New Keyless Entry Remote Thu Mar 11, 2010 2:43 pm | |
| - maximum wrote:
- the remotes do have this code on the back KOBUT1BT
That's the one... Mine, the 2 originals and 2 more I've bought off of eBay, read: GM/UTA 25628814 FCC ID KOBUT1BT CANADA 1983 101 393 The only thing I can reiterate is what Albert said about pressing both buttons simultaneously. Oh, and you didn't answer my question about which lock-cycle(s) you're getting... | |
| Subject: Re: FAQ: Programming a New Keyless Entry Remote Thu Mar 11, 2010 4:59 pm | |
| All 3 of my remotes for my 98 are 25678792. When programming the remotes, they must all be done at the same time. Also, it is very important to remove the jumper wire BEFORE you turn off the ignition, otherwise, the programming is erased. | |
maximum Amateur
| Subject: Re: FAQ: Programming a New Keyless Entry Remote Thu Mar 11, 2010 5:44 pm | |
| sorry, it cycles to unlock, when I put in the jumper, not to lock ! nothing when I press both buttons on the fob | |
| Subject: Re: FAQ: Programming a New Keyless Entry Remote Thu Mar 11, 2010 6:21 pm | |
| - maximum wrote:
- sorry, it cycles to unlock, when I put in the jumper, not to lock ! nothing when I press both buttons on the fob
Did you read my post above? Try it again. Get in the car and close both doors. Jumper the DLC. Turn the ignition switch to on. The door locks will cycle. Hold the Unlock and Lock buttons down on one of the remotes. You might have to hold them for 20-30 seconds before you hear the door locks cycle again. Repeat for any other remotes you wish to program. IMPORTANT!! REMOVE THE JUMPER. Then shut the ignition and test your remotes. | |
| Subject: Re: FAQ: Programming a New Keyless Entry Remote Thu Mar 11, 2010 7:43 pm | |
| - Eldo wrote:
- GM/UTA 25628814
Is the GM / UTA number supposed to be the same on all of them.? Mine are different. Yet have the same FCC ID # | |
| Subject: Re: FAQ: Programming a New Keyless Entry Remote Thu Mar 11, 2010 8:09 pm | |
| - Rickw wrote:
- Eldo wrote:
- GM/UTA 25628814
Is the GM / UTA number supposed to be the same on all of them.? Mine are different. Yet have the same FCC ID # Not sure Rick, all of mine are 25678792. Other numbers are the same as above. | |
| Subject: Re: FAQ: Programming a New Keyless Entry Remote Thu Mar 11, 2010 8:12 pm | |
| I think maybe the GM # indicates it is unique to your car, otherwise everyone that has one with the FCC ID KOBUT1BT would work on every Riviera, as we all seem to have the same FCC #. I don't know, just speculating. | |
| Subject: Re: FAQ: Programming a New Keyless Entry Remote Fri Mar 12, 2010 2:24 pm | |
| - Rickw wrote:
- I think maybe the GM # indicates it is unique to your car, otherwise everyone that has one with the FCC ID KOBUT1BT would work on every Riviera, as we all seem to have the same FCC #.
I don't know, just speculating. GM number is just the part number; think of the FCC ID as a 'type' code. So - to make them "unique to your car" you have to program them. If they are the right type, they can be programmed. I wonder if maximum had/has an aftermarket alarm installed. If so all bets are off for now, until the wiring is restored to stock assuming the MALL (or is it the BCM tht runs the locks?) is not damaged. MIght have to find a TechII and run the diagnostics on the culprit module? not sure... Albertj | |
maximum Amateur
| Subject: Re: FAQ: Programming a New Keyless Entry Remote Fri Mar 12, 2010 3:19 pm | |
| no I thought about the aftermarket alarm or start /entry, and checked. There's nothing aftermarket there.....yet ! | |
| Subject: Re: FAQ: Programming a New Keyless Entry Remote Fri Mar 12, 2010 3:46 pm | |
| - maximum wrote:
- no I thought about the aftermarket alarm or start /entry, and checked. There's nothing aftermarket there.....yet !
I replaced my BCM once, when stuff quit working right. I had already repaired it (cold solder joint - easy fix) but it failed a second time. Albertj
maximum Amateur
| Subject: Re: FAQ: Programming a New Keyless Entry Remote Fri Mar 12, 2010 6:17 pm | |
| Subject: Re: FAQ: Programming a New Keyless Entry Remote Fri Mar 12, 2010 6:18 pm | |
| - maximum wrote:
- whats the BCM ???
Body Control Module | |
| Subject: Re: FAQ: Programming a New Keyless Entry Remote | |
