 ac help?>
steel2040
ac help?> Empty
PostSubject: ac help?>   ac help?> EmptyMon Jun 18, 2007 12:39 pm
i just tried to put on my ac it doesnt work. The compressor isnt goin on i checked the fuse. any one suggest i pull the negative off the batt and see if it works then? if it does is there a relay that may be bad?
ac help?> Empty
PostSubject: Re: ac help?>   ac help?> EmptyMon Jun 18, 2007 1:51 pm
If you've been playing with your airbox or intake, make sure you plugged the IAT sensor back in. If not, your AC may not work.
ac help?>
