| The infamous twerking steering wheel | |
Johnny5 Fanatic
Name : Going Nowhere Fast Age : 37 Location : Louisiana Joined : 2013-09-11 Post Count : 459 Merit : 1
| Subject: The infamous twerking steering wheel Sun Sep 29, 2013 8:49 pm | |
| I have spent countless dollars on trying to find this one problem my steering wheel shimmy and as I go over bumps or uneven pavement the car pulls to the right ball joints tie rods engine mounts trans mounts sway bar links rotors brakes calipers and on a hot day on the interstate I feel a lot of the road going up a hill is when it feels like the right wheel wants to move excessively | |
Johnny5 Fanatic
| Subject: Re: The infamous twerking steering wheel Sun Sep 29, 2013 8:57 pm | |
| I've changed those parts so far* | |
| Subject: Re: The infamous twerking steering wheel Sun Sep 29, 2013 9:14 pm | |
Johnny5 Fanatic
| Subject: Re: The infamous twerking steering wheel Sun Sep 29, 2013 9:40 pm | |
| Yeah its a shimmy vibration just something I didnt feel before I got these tires which are balanced by me and they are in working conditions | |
Johnny5 Fanatic
| Subject: Re: The infamous twerking steering wheel Sun Sep 29, 2013 9:45 pm | |
| - stan wrote:
- ....shimmy.....
its not normal and I cant record it I just know it hasnt been like this I used to be able to freely turn my car in to a full spin with just using my finger n | |
| Subject: Re: The infamous twerking steering wheel Mon Sep 30, 2013 12:41 am | |
| I think this is more than one issue. The vibration is probably your tire/wheel balance. The steering pull pull might be alignment or inner/outer tie rod end. _________________ '05 GTO 6.0L • 6-spd • 95k miles • 0-60: 4.8s • 16.9 avg MPG • Nelson Ledges Lap: 1:26'95 Celica GT 2.2L • 5-spd • 165k miles • 0-60: yes'98 SC Riviera • 281k miles • 298 HP/370 TQ • 0-60: 5.79s • ET: 13.97 @ 99.28 • 4087 lb • 20.1 avg MPG • Nelson Ledges Lap: 1:30 3.4" pulley • AL104 plugs • 180º t-stat • FWI w/K&N • 1.9:1 rockers • OR pushrods • LS6 valve springs • SLP headers • ZZP fuel rails KYB GR2 struts • MaxAir shocks • Addco sway bars • UMI bushings • GM STB • Enkei 18" EV5s w/ Dunlop DZ101s • F-body calipers EBC bluestuff/Hawk HP plus • SS lines • Brembo slotted discs • DHP tuned • Aeroforce • Hidden Hitch^^^ SOLD ^^^ '70 Ninety-Eight Holiday Coupe 455cid • 116k miles^^^ SOLD ^^^ | |
Hell Hound 065 Rookie
Name : Chris Modica Age : 46 Location : Brooksville fl. Joined : 2013-08-16 Post Count : 12 Merit : 0
| Subject: Re: The infamous twerking steering wheel Mon Sep 30, 2013 12:49 am | |
| Maybe check your strut mount bearings | |
Johnny5 Fanatic
| Subject: Re: The infamous twerking steering wheel Mon Sep 30, 2013 1:10 am | |
- I think this is more than one issue. The vibration is probably your tire/wheel balance. The steering pull pull might be alignment or inner/outer tie rod end.
brand new wheels tires changed all of that listed above I balanced the wheels my self alignment I did recently 2moths ago tie rods changed them | |
| Subject: Re: The infamous twerking steering wheel Mon Sep 30, 2013 1:13 am | |
| Try rotating the wheels, see if anything changes. _________________ '05 GTO 6.0L • 6-spd • 95k miles • 0-60: 4.8s • 16.9 avg MPG • Nelson Ledges Lap: 1:26'95 Celica GT 2.2L • 5-spd • 165k miles • 0-60: yes'98 SC Riviera • 281k miles • 298 HP/370 TQ • 0-60: 5.79s • ET: 13.97 @ 99.28 • 4087 lb • 20.1 avg MPG • Nelson Ledges Lap: 1:30 3.4" pulley • AL104 plugs • 180º t-stat • FWI w/K&N • 1.9:1 rockers • OR pushrods • LS6 valve springs • SLP headers • ZZP fuel rails KYB GR2 struts • MaxAir shocks • Addco sway bars • UMI bushings • GM STB • Enkei 18" EV5s w/ Dunlop DZ101s • F-body calipers EBC bluestuff/Hawk HP plus • SS lines • Brembo slotted discs • DHP tuned • Aeroforce • Hidden Hitch^^^ SOLD ^^^ '70 Ninety-Eight Holiday Coupe 455cid • 116k miles^^^ SOLD ^^^ | |
Johnny5 Fanatic
| Subject: Re: The infamous twerking steering wheel Mon Sep 30, 2013 1:15 am | |
| - Hell Hound 065 wrote:
- Maybe check your strut mount bearings
this is the only part I haven't touched yet this and front hubs and control arms and I just did alot of research reading today at work and it has alot of the signs of what im dealing with but I want to make sure before I go and spend some more money and be upset | |
Johnny5 Fanatic
| Subject: Re: The infamous twerking steering wheel Mon Sep 30, 2013 1:22 am | |
- Try rotating the wheels, see if anything changes.
Mr. AA I tried that as well I have been doing some searching and these are factory struts and mounts on the car still and they seem like the issue upon diagnosis | |
| Subject: Re: The infamous twerking steering wheel Mon Sep 30, 2013 1:29 am | |
| Never hurts to update the struts. The originals are usually shot after 100k miles, and they really weren't that good brand new. While you're in there replace the strut mounts/bearings, too. _________________ '05 GTO 6.0L • 6-spd • 95k miles • 0-60: 4.8s • 16.9 avg MPG • Nelson Ledges Lap: 1:26'95 Celica GT 2.2L • 5-spd • 165k miles • 0-60: yes'98 SC Riviera • 281k miles • 298 HP/370 TQ • 0-60: 5.79s • ET: 13.97 @ 99.28 • 4087 lb • 20.1 avg MPG • Nelson Ledges Lap: 1:30 3.4" pulley • AL104 plugs • 180º t-stat • FWI w/K&N • 1.9:1 rockers • OR pushrods • LS6 valve springs • SLP headers • ZZP fuel rails KYB GR2 struts • MaxAir shocks • Addco sway bars • UMI bushings • GM STB • Enkei 18" EV5s w/ Dunlop DZ101s • F-body calipers EBC bluestuff/Hawk HP plus • SS lines • Brembo slotted discs • DHP tuned • Aeroforce • Hidden Hitch^^^ SOLD ^^^ '70 Ninety-Eight Holiday Coupe 455cid • 116k miles^^^ SOLD ^^^ | |
| Subject: Re: The infamous twerking steering wheel | |
