 So need help after making a discovery the hard way....
2 posters
Trystlore
Trystlore
So need help after making a discovery the hard way.... Empty
PostSubject: So need help after making a discovery the hard way....   So need help after making a discovery the hard way.... EmptyThu Dec 27, 2012 11:28 pm
I was having the as i understand it, common 3800 issue of the bad plastic heater pipes ( the little 90 degree plastic ones) much to my chagrin i discovered that the hidden one on Buick isn't plastic but metal. unfortunately i found this out by it breaking and leaving half the aluminum inserted pipe in its receiver on the engine. Just wondering if anyone has any ideas how to get that piece out. That way i can get the new one and insert it in to the receiving port. attaching a pic if i can figure it out to give you all an idea what piece broke.
PostSubject: Re: So need help after making a discovery the hard way....   So need help after making a discovery the hard way.... EmptyFri Dec 28, 2012 6:59 am
There is nothing holding it in except the oring and maybe some corrosion buildup. I was able to use a right angle pick and right angle screwdriver on the plastic one, you should be able to use whatever you can get in there.
I like the penetrant PB Blaster over anything else. and mayne you can fit a big easy-out bolt extractor in it?
Trystlore
Trystlore
PostSubject: Re: So need help after making a discovery the hard way....   So need help after making a discovery the hard way.... EmptyFri Dec 28, 2012 10:48 am
Ill give that a try , though its the metal one that broke. It has me buying a whole idler assembly. plastic one came right out. metal side broke as i was wiggling it out.
» Just making sure... (Electrical)
» making a sticker
» Just making sure these rims fit.
» PROM and or Bin file for 95 Riviera
» Series I Supercharger... making noise?
Riv Performance ::   N/A 3800 Tech :: Series II N/A Engine, Transmission, PCM-
