 Is the intake screen important?
96_Juggernaut
EatDirtFartDust
9 posters
EatDirtFartDust
Is the intake screen important? Empty
PostSubject: Is the intake screen important?   Is the intake screen important? EmptyFri Apr 17, 2009 10:30 pm
I was doing a BG fuel induction service, and in the process had to remove a c-clip that was holding in a flimsy screen that is in front of the mass air flow sensor.
I can think of three possible reasons for it being there:
Cut down on intake noise
Stop large particles that may have circumvented the air filter
Diffuse the air coming in, so that it blows onto the mass air flow sensor at an even rate as the rest of the intake.
If it is there for the latter reason I should leave it. The other two reasons I'm not worried about.
What is your take?
PostSubject: Re: Is the intake screen important?   Is the intake screen important? EmptyFri Apr 17, 2009 10:48 pm
It is the latter reason, leave it in, just clean it gently with Mass Airflow Sensor Cleaner (aerosol can) and a soft toothbrush if it is very dirty. I have used this cleaner made by CRC.
PostSubject: Re: Is the intake screen important?   Is the intake screen important? EmptySat Apr 18, 2009 8:28 pm
What Rick said. Be careful not to touch the sensor wire inside the MAF body when you spray it clean. Let it dry completely before installing, it dries quickly though.
PostSubject: Re: Is the intake screen important?   Is the intake screen important? EmptySun Apr 19, 2009 8:08 pm
ding ding ding
That's why it's there. Better off to leave it there.
96_Juggernaut
96_Juggernaut
Name : Todd Balestrini
PostSubject: Re: Is the intake screen important?   Is the intake screen important? EmptyWed Nov 27, 2013 10:54 am
Is there a part number for this? discovered mine has a few little dings in it and it screws with my A.D.D knowing its like that. Tried looking at the "holy grail" and did not see it.
PostSubject: Re: Is the intake screen important?   Is the intake screen important? EmptyWed Nov 27, 2013 10:59 am
You could probably pop it off and flatten it out. Mine has a few dings too, but I don't mind too much. I'm not sure as to how you would get it off though. Maybe somebody like ZZP sells them
Edit: I found this. http://www.gmforum.com/performance-brainstorming-tuning-96/remove-throttle-body-screen-removal-281867/
PostSubject: Re: Is the intake screen important?   Is the intake screen important? EmptyWed Nov 27, 2013 11:15 am
http://www.rockauto.com/catalog/moreinfo.php?pk=88565&cc=1022050
RockAuto....$20
96_Juggernaut
96_Juggernaut
PostSubject: Re: Is the intake screen important?   Is the intake screen important? EmptyWed Nov 27, 2013 11:34 am
RockAuto....$20
Awesome, thanks guys
Merit : 28
PostSubject: Re: Is the intake screen important?   Is the intake screen important? EmptyWed Nov 27, 2013 1:43 pm
I popped mine out and was able to straighten out all the holes with a paper clip.
Name : Going Nowhere Fast
PostSubject: Re: Is the intake screen important?   Is the intake screen important? EmptyWed Nov 27, 2013 5:11 pm
Go to amazon.com its like 18 dollars or go to a local junk yard and snatch one off a 96 or better
PostSubject: Re: Is the intake screen important?   Is the intake screen important? EmptyWed Nov 27, 2013 5:19 pm
I think it's one of those things that you should just get new if you're not going to fix yours. You would be lucky to find a perfect one AND not to mess it up.
Riv Performance ::   N/A 3800 Tech :: Series II N/A Engine, Transmission, PCM-
