| Hard Start After Installing Guages | |
Fromano Special
Name : Fromano Age : 62 Location : duncansville pa Joined : 2013-10-12 Post Count : 9 Merit : 0
| Subject: Hard Start After Installing Guages Sun Oct 27, 2013 11:29 am | |
| I put new gauges in my car yesterday watertemp volt and oil pressure .now I am having a hard time starting car I have to pump gas to get it to start can any body tell me what I did wrong .and how to fix it this may sound dumb but where to I go to get answers to my quastions. | |
bigdave Fanatic
| Subject: Re: Hard Start After Installing Guages Sun Oct 27, 2013 12:01 pm | |
| Did you disable the factory sending units to run your new gauges? If so, PCM doesn't know temperature of coolant at start up. | |
Fromano Special
| Subject: Re: Hard Start After Installing Guages Sun Oct 27, 2013 12:11 pm | |
| no I did not how do I do that . | |
bigdave Fanatic
| Subject: Re: Hard Start After Installing Guages Sun Oct 27, 2013 12:22 pm | |
| How did you hook your coolant temp gauge at the engine? | |
Fromano Special
| Subject: Re: Hard Start After Installing Guages Sun Oct 27, 2013 12:52 pm | |
| I took out sensor out by tsat housing and ran new wires in to car . cooling fans are staying on now | |
bigdave Fanatic
| Subject: Re: Hard Start After Installing Guages Sun Oct 27, 2013 7:04 pm | |
| I think if you put the original sensor back in and hook the factory wires back up, your car will operate properly again, assuming it did before. By removing the original sending unit, your PCM doesn't know what temp the engine is at. Therefore it cannot adjust fueling or fan turn on. If you post what year your car is, someone may be able to help you hook up your aftermarket gauges. | |
| Subject: Re: Hard Start After Installing Guages Sun Oct 27, 2013 8:20 pm | |
| You can't remove any of the factory sensors. The PCM (Powertrain control module, or 'computer') relies on them to know what it's supposed to be doing to your engine. Removing the PCM's coolant sensor means it doesn't know the engine temp, so assumes it's very cold and won't run right at all. Put it back! I'm not aware of any other location where you can add a coolant temp sending unit.
If you have a '96 or newer, there is a digital 'gauge' that plugs into the OBD-II diagnostic port under the dash, called an Aeroforce gauge. With that, you can read anything the PCM makes available, including coolant temp, oil pressure and voltage. BTW Aeroforce is just one example, there are other OBD-II gauges out there. That's one that most of us are familiar with because it works well with GM PCMs. | |
Fromano Special
| Subject: Re: Hard Start After Installing Guages Mon Oct 28, 2013 7:57 am | |
| hi thanks for info my riv is a 97 . mods are 104s cai have supercharger pullies to put on but I am dealing with this guage thing.i did order the aero force guage . any thing else I should know before I start .those other mods . any info will help me . again thank you | |
| Subject: Re: Hard Start After Installing Guages Mon Oct 28, 2013 4:46 pm | |
| Subject: Re: Hard Start After Installing Guages | |
