 Super charger pulley seal?
IFallsRon
Super charger pulley seal? Empty
PostSubject: Super charger pulley seal?   Super charger pulley seal? EmptySun Oct 27, 2013 1:45 pm
There seems to be some leakage that looks to be from behind the charger pulley. Is there a replaceable seal and a procedure?
PostSubject: Re: Super charger pulley seal?   Super charger pulley seal? EmptySun Oct 27, 2013 6:31 pm
i know you can replace and rebuild the snouts. i see the kits on ebay all the time but dont know how. there may be a right up if ya try the search
IFallsRon
PostSubject: Re: Super charger pulley seal?   Super charger pulley seal? EmptySun Oct 27, 2013 8:55 pm
Found the rebuild kit on ebay. Looks to require tools missing from my garage. Need to regroup.
PostSubject: Re: Super charger pulley seal?   Super charger pulley seal? EmptyMon Oct 28, 2013 10:12 am
I replaced the SC snout seal on my SC. I only required some needle nosed pliers after I had already pulled the pulley off. I did it while downsizing pulleys to a 3.4. I had the snout off the car and also needed SC oil
SC Snout Seal
IFallsRon
PostSubject: Re: Super charger pulley seal?   Super charger pulley seal? EmptyTue Oct 29, 2013 6:56 am
ebay seller says: "Requires the use of a hydraulic press.
YOU WILL DAMAGE THE PULLEY IF YOU TRY TO USE A GEAR PULLER."
I'm sure there's a local shop with a press.
Kit comes for $85 plus shipping. Seems my parts guy could come in cheaper.
Merit : 148
PostSubject: Re: Super charger pulley seal?   Super charger pulley seal? EmptyTue Oct 29, 2013 7:03 am
ZZP sells a nice puller for under $100 IIRC. I would troll eBay and see if someone is selling one.
IFallsRon
PostSubject: Re: Super charger pulley seal?   Super charger pulley seal? EmptySun Nov 10, 2013 3:54 pm
My plug has some odd size star pattern. WTF?
IFallsRon
PostSubject: Re: Super charger pulley seal?   Super charger pulley seal? EmptyThu Oct 06, 2016 8:39 am
With the help of my retired mechanic neighbor, I started the seal replacement job. The neighbor designed and cut the plate to fit on his puller. You can see that we did not take off the snout. The pulley was on tight and took plenty of effort.
The seal was beat up. There was no retainer but plenty of RTV or other sealant.
Had planned to replace bearings but the shaft seats solidly. Will consider replacing coupler later.
Replacing the seal is important now for me because the oil spins out and makes the belts slippery enough to jump the pulleys.
Super charger pulley seal? 100_1849_zpsvnsu3c9k
Super charger pulley seal? 100_1850_zpsfnibigqf
Super charger pulley seal? 100_1851_zpsxw2fccij
Super charger pulley seal? 100_1853_zpsbbx0i3bw
PostSubject: Re: Super charger pulley seal?   Super charger pulley seal? EmptyThu Oct 06, 2016 9:31 am
The snout can be rebuilt quite easily if you have a hydraulic press. I rebuilt mine with the help of a YouTube video. Physically took it off, rebuilt it, and reinstalled it in about an hour.
FYI....the next time you have to take the pulley off, heat it towards the center with a micro-torch. DO NOT use acetylene or map gas. I used a Butane 1400* micro-torch. It slides off fairly easily without popping several times.
Then, for re-installation, put the pulley itself in the oven at 300* for about 20 minutes. The thing slides back on with ease. It still needs to be pressed on, but again, no popping.
Merit : 148
PostSubject: Re: Super charger pulley seal?   Super charger pulley seal? EmptyFri Oct 07, 2016 10:38 am
Also if your engine has any mild lope whatsoever then you might want to electrically check your coils. I suspect the 2-5 is different from the others. Let us know.
» SuperCharger for a 16HP/18HP Briggs and Stratton?
» Aquatico's new Super Charger 300M
» HooptownGTA's Super 16 Pre-season Rankings
» Pulley Question
