 Orange Dust on Belt
Orange Dust on Belt Empty
PostSubject: Orange Dust on Belt   Orange Dust on Belt EmptySun Oct 27, 2013 5:09 pm
Dose anybody have any idea what could be causing this?
Orange Dust on Belt 407905121
I know I have recently said here that my SC belt is torn, but this has been happening way before that happened. I thought it might be the alternator. Although it tested good, I recently replaced it, and cleaned the area but the dust returned. The only thing I can think of is that as the belts deteriorate they are producing this dust,
Orange Dust on Belt 407905120
or is it the SC idler pulley that has become ultra shiny where it was once black?
Orange Dust on Belt 407905119
Any ideas? Has this happened to anyone else?
PostSubject: Re: Orange Dust on Belt   Orange Dust on Belt EmptySun Oct 27, 2013 6:21 pm
that is the weirdest thing ive saw in a while
PostSubject: Re: Orange Dust on Belt   Orange Dust on Belt EmptySun Oct 27, 2013 8:11 pm
water pump leaking? Do you ever have to add coolant?
PostSubject: Re: Orange Dust on Belt   Orange Dust on Belt EmptySun Oct 27, 2013 9:59 pm
Do all the pulley's spin while the engine is running?  Any of them wobble?
PostSubject: Re: Orange Dust on Belt   Orange Dust on Belt EmptySun Oct 27, 2013 10:15 pm
Happened to a couple Saturn owners here:
http://www.saturnfans.com/forums/showthread.php?t=39918
Seems too similar to be coincidence.
Also here with Hondas:
http://www.hondasuv.com/members/archive/index.php/t-57970.html
The common idea mentioned in both threads is rust, which seems to come from the AC compressor clutch. Worth a look.
Another theory is that certain belts contain steel belts, which leach rust when they get old.
Maybe try replacing the belt with a different brand (Gates/NAPA), since yours is torn anyway. If the problem goes away you know it was the belt.
PostSubject: Re: Orange Dust on Belt   Orange Dust on Belt EmptyMon Oct 28, 2013 3:47 am
That's what I thought, because I do sometimes top up coolant reservoir (very little) but engine and garage floor are clean and dry?
Will double check but at a passing glance, nothing obvious.
Thanks for that Aaron, very useful links. Its my theory as well that the belts are producing this stuff, so really want to get to it now,
If its not, changing the AC compressor out to find out its something else would be a biatch.confused
PostSubject: Re: Orange Dust on Belt   Orange Dust on Belt EmptyMon Oct 28, 2013 10:19 am
Id almost guess that the shiny idler pulley is seizing up a bit. It sure is a pain to replace that one.
PostSubject: Re: Orange Dust on Belt   Orange Dust on Belt EmptySat Nov 23, 2013 1:20 am
Well, just wanted to update everybody, the orange dust was in fact produced by the belts. Its been about three weeks since I changed them and the dust has not returned. There wasn't much on the old belts to be able to tell you guys what brand they were. All I can make out was this number....
5060940 if that help anyone.
PostSubject: Re: Orange Dust on Belt   Orange Dust on Belt EmptySun Nov 24, 2013 12:33 pm
I replaced a set of belts on a Subaru Outback yesterday that had the same orange residue. Possibly something manufactured into the belts as a warning to replace them.
PostSubject: Re: Orange Dust on Belt   Orange Dust on Belt EmptyMon Nov 25, 2013 9:58 am
Possibly some steel braiding reinforcing the rubber in the belt? Not sure what exactly but there is more than just rubber in the belts! I would be surprised to find steel but who knows? I can't find anything in a quick search to back me up. I've never seen that before.
Orange Dust on Belt
» Belt Drive Case Filter
» Chain in place of belt.
» Prototype of new combo belt harness for Minelab GPX's
» RZ Dust Masks
» V-Belt
