 fuel pressure spec
Go to page : 1, 2, 3  Next
mattsaari
PostSubject: fuel pressure spec   Sun Nov 03, 2013 1:00 am
So i hqve another post that i have code p0171 well today i went to check my fuel pressure and key on engine off it was 35psi and running at any speed in park it was a steady 25 psi. this seems low but i can not find the spec qnywhere on this board. im thinking it is way to low and replaced the fuel filter with no chnage and stqrting to think i may need a fuel pump soon!
96_Juggernaut
Name : Todd Balestrini
PostSubject: Re: fuel pressure spec   Sun Nov 03, 2013 1:18 am
Not sure about the Riviera but 25 does indeed seem very low. have you tried measuring fuel pressure with the vacuum line disconnected from the fuel pressure regulator ?
Name : Going Nowhere Fast
PostSubject: Re: fuel pressure spec   Sun Nov 03, 2013 1:32 am
my my my my you must have a 96 buddy this is our year I see and ... im fighting the same code are you currently having any other codes
mattsaari
PostSubject: Re: fuel pressure spec   Sun Nov 03, 2013 1:33 am
Yea i tried both connected and disconected. it stayed about the same which i would think would be normal as less vac would drop the pressure even more and im assuming the pressure isnt there to begin with but i may be wrong
mattsaari
PostSubject: Re: fuel pressure spec   Sun Nov 03, 2013 1:35 am
this currently is the only code i did have a camshaft positioning sensor code but that was fixed by replacing a broken wire and pin
PostSubject: Re: fuel pressure spec   Sun Nov 03, 2013 1:42 am
and you haven't done nothing else to your car no mods ... have you changed any of the fuel filters?
mattsaari
PostSubject: Re: fuel pressure spec   Sun Nov 03, 2013 1:44 am
nope car is completly stock only things done are new radiator oil pan tensioner serp belts and replace broken wire to pcm but nothing performance wise also i did replace the inline filter near the compressor but didnt touch the screans on the pump
96_Juggernaut
PostSubject: Re: fuel pressure spec   Sun Nov 03, 2013 1:46 am
Less vacuum should increase fuel pressure, and positive pressure ( boost ) should increase it even more.
PostSubject: Re: fuel pressure spec   Sun Nov 03, 2013 1:48 am
only thing I can think of is the quick fixes its a filter under the car and the one on the pump in the tank and a vuccum line that runs to the regulator
PostSubject: Re: fuel pressure spec   Sun Nov 03, 2013 1:52 am
do you have a T on the front of the supercharger or you have a single line ran str8 to the MAP
PostSubject: Re: fuel pressure spec   Sun Nov 03, 2013 1:00 am
but p0171 is a lean code some extra air is coming in from somewhere you have to check the lines
mattsaari
thats what i was thinking im leaning towards pump have you ever replaced just the pump and not the whole sending unit i found just a pump and strainer for 48 to save cash but idk if its best off replacing the whole thing
mattsaari
PostSubject: Re: fuel pressure spec   Sun Nov 03, 2013 1:01 am
wouldnt too little fuel do the same?
96_Juggernaut
PostSubject: Re: fuel pressure spec   Sun Nov 03, 2013 1:04 am
I think a leak in a vacuum line is more common ( and cheaper ) than a faulty fuel pump. always check the cheapest fixes first
PostSubject: Re: fuel pressure spec   Sun Nov 03, 2013 1:05 am
I have heard of it done but I have never seen it and not on the riv ... but look for a vacuum first
mattsaari
PostSubject: Re: fuel pressure spec   Sun Nov 03, 2013 1:06 am
the map goes to a t that has a factory plug and then anothe line going to the intake manifold
PostSubject: Re: fuel pressure spec   Sun Nov 03, 2013 1:08 am
I just seen the p0171 code you put down. reason is because its having to take in more air from a vacuum line, lower intake leaking
mattsaari
PostSubject: Re: fuel pressure spec   Sun Nov 03, 2013 1:13 am
that was my original guess but still wondering if fuel pressure has somthing to do with it 25 at idle just dont seem healty and i did try taking a can of carb cleaner and spraying around the intake and all the vac lines with no change in how its running
PostSubject: Re: fuel pressure spec   Sun Nov 03, 2013 1:19 am
its not going to change how its running but you will hear an increase in engine idle it will spike that's a tricky code mines haven't came back but im spraying more gas than usual and its killing me in the pockets
mattsaari
PostSubject: Re: fuel pressure spec   Sun Nov 03, 2013 1:22 am
thats what i should have said but there was no change in idle def is a pita code been chasing my tail the last couple weeks lol
PostSubject: Re: fuel pressure spec   Sun Nov 03, 2013 1:25 am
did you spray around the lower intake and the egr valve and its piping something its under the hood if the car is starting fine
mattsaari
PostSubject: Re: fuel pressure spec   Sun Nov 03, 2013 5:12 pm
yea tried spraying that as well went through almos a whole can of carb cleaner lol. and it idles really nice and smooth around 500 rpm runs like a dream just the code
mattsaari
PostSubject: Re: fuel pressure spec   Sun Nov 03, 2013 5:15 pm
New update i checked fuel pressure again today and now its at almost 50 key on engine off and at idle its around 35 but the guage bounces real bad that i cant read it which seems to me to be pointing again to a fuel pump as its prolly going down when the injectors open and the fp isnt keeping up. i did also put a vac guage on the reg and it held vac and with key on engine off the fuel pressure went down with vac applied to the regulator so i know the reg is good still thinking fuel pump i thi.k im going to try to replace just the pump in the sendong unit in the next few weeks!
PostSubject: Re: fuel pressure spec   Sun Nov 03, 2013 9:01 pm
Find a old one in the junk yard n experiment first so u dont have no long down time in the process
PostSubject: Re: fuel pressure spec   Sun Nov 03, 2013 9:53 pm
If it's hitting 50 with the key off, try changing your fuel filter before you replace the pump.
fuel pressure spec
