rivparadise Fanatic
Name : Samuel Age : 51 Location : Niagara Co. Joined : 2007-06-10 Post Count : 381 Merit : 11
| Subject: 1st to 2nd shift tuning Wed Mar 14, 2012 5:37 am | |
| When I get on it off the line, first gear seems to wind out more than I like into second. Every other part of the shifts feels just fine at any speed. If driving casual 1st to 2nd isn't bad. When driving spirited, I always wait for her to shift to 2nd then engage the Supercharger. Can I tweek this! | |
| Subject: Re: 1st to 2nd shift tuning Wed Mar 14, 2012 9:42 am | |
| Yes, the shift points can be adjusted with DHP PowrTuner or HPTuners software.
However, the PCM is supposed to hold the gears out longer at higher throttle %, as this lets you use your power & torque for better acceleration. The SC is engaged in 1st gear, especially at higher RPM! If you lower the 2nd gear shift RPM, the car will not accelerate as quickly. I've pushed mine up even higher to hold the shifts longer. _________________ '05 GTO 6.0L • 6-spd • 95k miles • 0-60: 4.8s • 16.9 avg MPG • Nelson Ledges Lap: 1:26'95 Celica GT 2.2L • 5-spd • 165k miles • 0-60: yes'98 SC Riviera • 281k miles • 298 HP/370 TQ • 0-60: 5.79s • ET: 13.97 @ 99.28 • 4087 lb • 20.1 avg MPG • Nelson Ledges Lap: 1:30 3.4" pulley • AL104 plugs • 180º t-stat • FWI w/K&N • 1.9:1 rockers • OR pushrods • LS6 valve springs • SLP headers • ZZP fuel rails KYB GR2 struts • MaxAir shocks • Addco sway bars • UMI bushings • GM STB • Enkei 18" EV5s w/ Dunlop DZ101s • F-body calipers EBC bluestuff/Hawk HP plus • SS lines • Brembo slotted discs • DHP tuned • Aeroforce • Hidden Hitch^^^ SOLD ^^^ '70 Ninety-Eight Holiday Coupe 455cid • 116k miles^^^ SOLD ^^^ | |
charlieRobinson Expert
| Subject: Re: 1st to 2nd shift tuning Tue Dec 03, 2013 10:09 pm | |
| I think what Sam might have been referring to is the lag between the 1st and 2nd shift at WOT. At least that's my concern.
I notice a delay between shifts that feels like acceleration is lagging because of it. Do you guys know what I'm talking about?
Is this shift pressure? shift speed? Scott?
Are there ideal values we should be tuning our trans to?
Please teach me!
Thank you! | |
| Subject: Re: 1st to 2nd shift tuning Wed Dec 04, 2013 10:14 am | |
| It's Shift Time, and Shift Pressure that will make those shifts faster. The lower the Shift Time, the faster is shifts. The higher the Shift Pressure, the harder it will shift. | |
| Subject: Re: 1st to 2nd shift tuning | |
