 Weird tranny problem.
eskiho
Weird tranny problem. Empty
PostSubject: Weird tranny problem.   Weird tranny problem. EmptySun Nov 24, 2013 10:02 pm
It's kinda of hard to explain so I decided the video was necessary. I have another video being uploaded of me manually shifting it after.
Here is the car in drive.
Let me explain what happens..
I put the car in drive I hit the gas.. it may slip.. it may not.. once it starts going, it'll shift to second at like 5 miles an hour, cause the engine to bog down.. then at like 18-20 mph it'll shift to third, cause the car to bog down... When I start slowing down, it will stay in the same gear, and bog down until 700 rpm or something, sometime it has stalled and stayed in gear i have to slam it in neutral or first and hope it works (happend twice I think)..
Manually shifted.
This video shows when I drive it "manually" 1>2>3>D
Accelerates great, kinda a delay from 1>2 and 2>3 but tis all good.Still bogs down and stays in gear when coming to a stop though.
Oh, and the cat is removed, got clogged when my pcm went bad, kept trying to diagnose.. flooded the engine with fuel...wouldnt crank...  clogged the cat..
PostSubject: Re: Weird tranny problem.   Weird tranny problem. EmptySun Nov 24, 2013 10:08 pm
^^^^^ with the youtube html tag.
eskiho
PostSubject: Re: Weird tranny problem.   Weird tranny problem. EmptySun Nov 24, 2013 10:12 pm
thanks, fixed. (the youtube link)
PostSubject: Re: Weird tranny problem.   Weird tranny problem. EmptyMon Nov 25, 2013 10:06 am
That doesn't look like it's shifting 1-2-3-4. 3rd gear at 22mph won't bog down like that. It looks like it's shifting from 1st to 3rd or even 1st to 4th. The "3rd" shift your getting is probably converter lock-up. You might want to have that thing scanned and see which trans codes are stored without an SES light.....You might have something as simple as a bad solenoid(s).
PostSubject: Re: Weird tranny problem.   Weird tranny problem. EmptyTue Nov 26, 2013 6:00 am
This could be caused by TCC clutch being stuck on, but it will report a DTC after a couple trips. Any codes or SES lights?
» Transmission problems
» Foote tranny problem
» what kinda oil do you use in your tranny?
» tranny question
» Random (weird) stories
