 95 RIV starts and stalls. anti-theft key dtc
EatDirtFartDust
95 RIV starts and stalls. anti-theft key dtc Empty
PostSubject: 95 RIV starts and stalls. anti-theft key dtc   95 RIV starts and stalls. anti-theft key dtc EmptySat Dec 07, 2013 5:51 pm
Car will start fine then immediately stall out as if I turned the key off. Code is for anti-theft. Got a new key, that didn't change it.
One time it was acting up and I tilted the steering wheel up, and the problem went away for several months.
A tech I know seems to think there is a broken wire for the anti-theft (key chip) reader.
I'm going to start taking the steering column shroud off Monday and look for this wire.
In the mean time: any tips on getting the steering column shroud off? It doesn't seem too easy. Also, is there a way I can just bypass the anti-theft key-chip reader? On most Fords there's a wire you can ground at the pcm to bypass, but you'll still get the theft warning on the dash.
Thanks in advance
-EDFD
(Sorry I haven't been around much, go into motorcycles and that takes up most of my time. The Riv is my bad-weather driver now.)
PostSubject: Re: 95 RIV starts and stalls. anti-theft key dtc   95 RIV starts and stalls. anti-theft key dtc EmptyTue Dec 10, 2013 1:20 am
Did ya get the problem solved?
PostSubject: Re: 95 RIV starts and stalls. anti-theft key dtc   95 RIV starts and stalls. anti-theft key dtc EmptyTue Dec 10, 2013 1:42 am
http://vats.likeabigdog.com
This is what my dad did on my car 4 years ago and you dont have to worry about the chip anymore if thats the problem. Just bypass it with the correct resistor and you just need to have a properly cut key. There are also no lights or anything associated with this bypass.
95rivieraSC
PostSubject: Re: 95 RIV starts and stalls. anti-theft key dtc   95 RIV starts and stalls. anti-theft key dtc EmptyThu Jan 09, 2014 12:50 am
my Riviera starts then dies. no clue whats wrong with it. will stay running if I put my foot on the gas but still ends up dying in 5 seconds or so. please help!
EatDirtFartDust
PostSubject: Re: 95 RIV starts and stalls. anti-theft key dtc   95 RIV starts and stalls. anti-theft key dtc EmptyThu Jan 09, 2014 9:01 am
It ended up being the PCM
AllData had me test resistance from the ignition collar to the plug at the firewall. Then it had me test the ground on the security module (passenger kick panel), then resistance from the security module to the pcm (behind the glove box). All was good, so it told me to replace the PCM. I did, and it's fixed.
PostSubject: Re: 95 RIV starts and stalls. anti-theft key dtc   95 RIV starts and stalls. anti-theft key dtc EmptyThu Jan 09, 2014 10:05 am
I have one problem with this "fix".....Now your Riv can be stolen in 60 seconds.
Cool that you fixed it. AllData comes in handy eh?
» Polaris RZR “Anti-Theft” Shift Lock Now Available from EMP
» New Anti-Theft Gear shift lock from EMP
» Bolt ready for another big season - starts in Rome on May 26
» ATV Anti-Freeze
» fish theft petition
