| Temp outside gauge not working?? | |
bmcd9179 Fanatic
Name : Bryson Age : 28 Location : Utah Joined : 2013-09-21 Post Count : 288 Merit : 1
| Subject: Temp outside gauge not working?? Thu Oct 10, 2013 8:47 pm | |
| Hi my gauge that tells me how warm or cold it is outside isn't working, anyone know how to replace this? I know it's not a big deal but if it's cheap and easy anyone know how to fix it? | |
| Subject: Re: Temp outside gauge not working?? Thu Oct 10, 2013 8:55 pm | |
| Check your exterior temp and intake air sensors are plugged in. Ext temp sensor is under front bumper in front of radiator, intake sensor is plugged into air box. Be sure the wiring isn't damaged, too. _________________ '05 GTO 6.0L • 6-spd • 95k miles • 0-60: 4.8s • 16.9 avg MPG • Nelson Ledges Lap: 1:26'95 Celica GT 2.2L • 5-spd • 165k miles • 0-60: yes'98 SC Riviera • 281k miles • 298 HP/370 TQ • 0-60: 5.79s • ET: 13.97 @ 99.28 • 4087 lb • 20.1 avg MPG • Nelson Ledges Lap: 1:30 3.4" pulley • AL104 plugs • 180º t-stat • FWI w/K&N • 1.9:1 rockers • OR pushrods • LS6 valve springs • SLP headers • ZZP fuel rails KYB GR2 struts • MaxAir shocks • Addco sway bars • UMI bushings • GM STB • Enkei 18" EV5s w/ Dunlop DZ101s • F-body calipers EBC bluestuff/Hawk HP plus • SS lines • Brembo slotted discs • DHP tuned • Aeroforce • Hidden Hitch^^^ SOLD ^^^ '70 Ninety-Eight Holiday Coupe 455cid • 116k miles^^^ SOLD ^^^ | |
bmcd9179 Fanatic
| Subject: Re: Temp outside gauge not working?? Thu Oct 10, 2013 11:24 pm | |
| So the wiring is good, I'll have to check the one by the radiator, I might have to replace it, know where I can get the part? | |
| Subject: Re: Temp outside gauge not working?? Fri Oct 11, 2013 4:15 pm | |
| rockauto.com or gmpartsdirect.com RockAuto will be cheaper shipping and price too.
May even be at your dealer.
bmcd9179 Fanatic
| Subject: Re: Temp outside gauge not working?? Fri Oct 11, 2013 5:28 pm | |
| You know what it's called lol? | |
bmcd9179 Fanatic
| Subject: Re: Temp outside gauge not working?? Mon Nov 04, 2013 12:28 am | |
| So my front sensor is completely distorted, looked slight it got ran over or something not sure what happened, you know what the part is called? | |
| Subject: Re: Temp outside gauge not working?? Mon Nov 04, 2013 4:31 pm | |
| Ambient Air Temp Sensor.
Some call it an Outside Air Temp Sensor. | |
bmcd9179 Fanatic
| Subject: Re: Temp outside gauge not working?? Sun Dec 22, 2013 3:35 pm | |
| So mine was found hanging basically I got a new one,where in the heck does it mount? Can someone send a pic? Or a description, thanks! | |
Rivit Enthusiast
Name : Jim Location : Walla Walla, Washington Joined : 2013-09-22 Post Count : 208 Merit : 22
| Subject: Re: Temp outside gauge not working?? Sun Dec 22, 2013 7:58 pm | |
| Subject: Re: Temp outside gauge not working?? | |
