| Is the intake screen important? | |
+596_Juggernaut deekster_caddy 1998 Riv Rickw EatDirtFartDust 9 posters |
EatDirtFartDust Fanatic
Name : The Josh Age : 40 Location : Somewhere between Sullivan and Saint Peters Missouri. Joined : 2009-03-27 Post Count : 284 Merit : 2
| Subject: Is the intake screen important? Fri Apr 17, 2009 10:30 pm | |
| I was doing a BG fuel induction service, and in the process had to remove a c-clip that was holding in a flimsy screen that is in front of the mass air flow sensor. I can think of three possible reasons for it being there: Cut down on intake noise Stop large particles that may have circumvented the air filter Diffuse the air coming in, so that it blows onto the mass air flow sensor at an even rate as the rest of the intake.
If it is there for the latter reason I should leave it. The other two reasons I'm not worried about.
What is your take? | |
| Subject: Re: Is the intake screen important? Fri Apr 17, 2009 10:48 pm | |
| It is the latter reason, leave it in, just clean it gently with Mass Airflow Sensor Cleaner (aerosol can) and a soft toothbrush if it is very dirty. I have used this cleaner made by CRC. | |
| Subject: Re: Is the intake screen important? Sat Apr 18, 2009 8:28 pm | |
| What Rick said. Be careful not to touch the sensor wire inside the MAF body when you spray it clean. Let it dry completely before installing, it dries quickly though. | |
| Subject: Re: Is the intake screen important? Sun Apr 19, 2009 8:08 pm | |
| - EatDirtFartDust wrote:
- Diffuse the air coming in, so that it blows onto the mass air flow sensor at an even rate as the rest of the intake.
ding ding ding That's why it's there. Better off to leave it there. | |
96_Juggernaut Fanatic
Name : Todd Balestrini Age : 41 Location : Beaufort S.C. Joined : 2013-07-08 Post Count : 293 Merit : 5
| Subject: Re: Is the intake screen important? Wed Nov 27, 2013 10:54 am | |
| Is there a part number for this? discovered mine has a few little dings in it and it screws with my A.D.D knowing its like that. Tried looking at the "holy grail" and did not see it. | |
matt270avian Expert
| Subject: Re: Is the intake screen important? Wed Nov 27, 2013 10:59 am | |
| You could probably pop it off and flatten it out. Mine has a few dings too, but I don't mind too much. I'm not sure as to how you would get it off though. Maybe somebody like ZZP sells them
Edit: I found this. http://www.gmforum.com/performance-brainstorming-tuning-96/remove-throttle-body-screen-removal-281867/ | |
| Subject: Re: Is the intake screen important? Wed Nov 27, 2013 11:15 am | |
| - 96_Juggernaut wrote:
- Is there a part number for this? discovered mine has a few little dings in it and it screws with my A.D.D knowing its like that. Tried looking at the "holy grail" and did not see it.
http://www.rockauto.com/catalog/moreinfo.php?pk=88565&cc=1022050 RockAuto....$20 | |
| Subject: Re: Is the intake screen important? Wed Nov 27, 2013 11:34 am | |
RockAuto....$20 Awesome, thanks guys | |
th3fr4nchi5e Addict
| Subject: Re: Is the intake screen important? Wed Nov 27, 2013 1:43 pm | |
| I popped mine out and was able to straighten out all the holes with a paper clip. | |
Johnny5 Fanatic
Name : Going Nowhere Fast Age : 37 Location : Louisiana Joined : 2013-09-11 Post Count : 459 Merit : 1
| Subject: Re: Is the intake screen important? Wed Nov 27, 2013 5:11 pm | |
| Go to amazon.com its like 18 dollars or go to a local junk yard and snatch one off a 96 or better | |
matt270avian Expert
| Subject: Re: Is the intake screen important? Wed Nov 27, 2013 5:19 pm | |
| I think it's one of those things that you should just get new if you're not going to fix yours. You would be lucky to find a perfect one AND not to mess it up. | |
| Subject: Re: Is the intake screen important? | |
