 Hard 2-3 shift
Merit : 59
PostSubject: Hard 2-3 shift   Tue Jan 07, 2014 4:49 pm
Hey everyone,
I have my first real issue with the Riviera in a while. Last night a rubber transmission line split sometime on my way home and it dumped what I figure was about 6 quarts of fluid. I thought it was acting strange because of the cold, but no. When I got home I couldn't make it up the driveway because the trans wasn't engaging very well, but I had 1 quart and a half leftover from the summer so I put it in there and made it up the driveway.
So today I fixed all that up and refilled with DEX VI, and went for a drive. Now I have a somewhat hard 2-3 shift, on the lines of a pro shift kit would feel like. All other upshifts, lockup, and downshifts are same as always.
Solenoid? I tried resetting the PCM, but no results. I have no known vacuum leaks at the moment, as I just tested for them.
Thanks everyone!
Merit : 59
PostSubject: Re: Hard 2-3 shift   Fri Jan 10, 2014 12:00 am
Well, I suppose the problem is gone at least for now. The car drove great, like it always used to, today. I'm guessing it was a solenoid acting up.
PostSubject: Re: Hard 2-3 shift   Fri Jan 10, 2014 2:13 pm
Could also have been air in the hydraulic circuits. Some times it takes awhile to work it's way out.
Hard 2-3 shift
