| Bright dash lights | |
bmcd9179 Fanatic
Name : Bryson Age : 28 Location : Utah Joined : 2013-09-21 Post Count : 288 Merit : 1
| Subject: Bright dash lights Fri Jan 24, 2014 12:35 am | |
| Hi guys so when I turn the dash lights dimmer. The clock and how many miles and what gear I'm in lights are still freaking bright. They don't dim, but everything else does, how does that work? | |
| Subject: Re: Bright dash lights Fri Jan 24, 2014 10:32 am | |
| I don't recall if everything dims on my 98. I keep mine set low and haven't touched it in a long time. | |
bmcd9179 Fanatic
| Subject: Re: Bright dash lights Fri Jan 24, 2014 10:34 am | |
| Yah? Huh so your miles light is really bright and everything else is really low? That's weird if there not suppose to dim | |
| Subject: Re: Bright dash lights Fri Jan 24, 2014 10:37 am | |
| No, I said "I don't recall if everything dims...." | |
| Subject: Re: Bright dash lights Fri Jan 24, 2014 11:32 am | |
| I'll check out mine at noon when I drive in the garage and close the door. | |
bmcd9179 Fanatic
| Subject: Re: Bright dash lights Fri Jan 24, 2014 11:50 am | |
| Oh sweet thanks, haha sorry I didn't read if very well, I know one of my lights on the dash doesn't glow it's on the dimmer right under the thing you pull out to turn the lights on, it slides left and right and it doesn't do anything for me, I'm not sure what it's for but I'm assuming it's for the lights that won't dim, I'm not sure how to fix it if it doesn't work | |
| Subject: Re: Bright dash lights Fri Jan 24, 2014 11:53 am | |
| That's the twilight sentinel control that lets you set the time your headlamps stay on when you lock/unlock the vehicle. The owners manual describes how to use it. _________________ '05 GTO 6.0L • 6-spd • 95k miles • 0-60: 4.8s • 16.9 avg MPG • Nelson Ledges Lap: 1:26'95 Celica GT 2.2L • 5-spd • 165k miles • 0-60: yes'98 SC Riviera • 281k miles • 298 HP/370 TQ • 0-60: 5.79s • ET: 13.97 @ 99.28 • 4087 lb • 20.1 avg MPG • Nelson Ledges Lap: 1:30 3.4" pulley • AL104 plugs • 180º t-stat • FWI w/K&N • 1.9:1 rockers • OR pushrods • LS6 valve springs • SLP headers • ZZP fuel rails KYB GR2 struts • MaxAir shocks • Addco sway bars • UMI bushings • GM STB • Enkei 18" EV5s w/ Dunlop DZ101s • F-body calipers EBC bluestuff/Hawk HP plus • SS lines • Brembo slotted discs • DHP tuned • Aeroforce • Hidden Hitch^^^ SOLD ^^^ '70 Ninety-Eight Holiday Coupe 455cid • 116k miles^^^ SOLD ^^^ | |
| Subject: Re: Bright dash lights Fri Jan 24, 2014 12:09 pm | |
| All of my dash lights dim, BUT the trip/odo, radio, and climate control lights do not go as dim as the rest of the dash lights. | |
| Subject: Re: Bright dash lights Fri Jan 24, 2014 12:35 pm | |
| It makes some sense. The ODO, radio, and HVAC are a fluorescent display type, while the dash gauges are back-lit with incandescent bulbs. Fluorescent displays are dimmable, but not on the same circuit as the gauge bulbs. While they could have used a 2nd dimmer circuit, it would have added cost. I've noticed other cars with this same issue. They probably figured if most of the dash dimmed, most drivers will be okay with it. It's never bothered me personally, but I drive with mine near max brightness 100% of the time. _________________ '05 GTO 6.0L • 6-spd • 95k miles • 0-60: 4.8s • 16.9 avg MPG • Nelson Ledges Lap: 1:26'95 Celica GT 2.2L • 5-spd • 165k miles • 0-60: yes'98 SC Riviera • 281k miles • 298 HP/370 TQ • 0-60: 5.79s • ET: 13.97 @ 99.28 • 4087 lb • 20.1 avg MPG • Nelson Ledges Lap: 1:30 3.4" pulley • AL104 plugs • 180º t-stat • FWI w/K&N • 1.9:1 rockers • OR pushrods • LS6 valve springs • SLP headers • ZZP fuel rails KYB GR2 struts • MaxAir shocks • Addco sway bars • UMI bushings • GM STB • Enkei 18" EV5s w/ Dunlop DZ101s • F-body calipers EBC bluestuff/Hawk HP plus • SS lines • Brembo slotted discs • DHP tuned • Aeroforce • Hidden Hitch^^^ SOLD ^^^ '70 Ninety-Eight Holiday Coupe 455cid • 116k miles^^^ SOLD ^^^ | |
| Subject: Re: Bright dash lights Fri Jan 24, 2014 2:11 pm | |
| On most vehicles, I can't put up with full bright dash lights at night. Maybe it's my old eyes. | |
| Subject: Re: Bright dash lights Fri Jan 24, 2014 2:53 pm | |
| Depends on the color of light for me. There are studies that seem to confirm certain colors have an effect on us at nighttime. Some of the findings even suggest it can effect our health. Red is the easiest on the eyes at night. Military flashlights have a red filter to preserve night vision. Green is okay. The Riv's dash has always been easy on my eyes. Blue is worst. My GTO was converted to blue lighting by the previous owner and it is horrid to view at night. I turn the dimmer most of the way down. I've considered converting back to the OEM green, but really don't feel like tearing apart the interior of a car I just bought. _________________ '05 GTO 6.0L • 6-spd • 95k miles • 0-60: 4.8s • 16.9 avg MPG • Nelson Ledges Lap: 1:26'95 Celica GT 2.2L • 5-spd • 165k miles • 0-60: yes'98 SC Riviera • 281k miles • 298 HP/370 TQ • 0-60: 5.79s • ET: 13.97 @ 99.28 • 4087 lb • 20.1 avg MPG • Nelson Ledges Lap: 1:30 3.4" pulley • AL104 plugs • 180º t-stat • FWI w/K&N • 1.9:1 rockers • OR pushrods • LS6 valve springs • SLP headers • ZZP fuel rails KYB GR2 struts • MaxAir shocks • Addco sway bars • UMI bushings • GM STB • Enkei 18" EV5s w/ Dunlop DZ101s • F-body calipers EBC bluestuff/Hawk HP plus • SS lines • Brembo slotted discs • DHP tuned • Aeroforce • Hidden Hitch^^^ SOLD ^^^ '70 Ninety-Eight Holiday Coupe 455cid • 116k miles^^^ SOLD ^^^ | |
bmcd9179 Fanatic
| Subject: Re: Bright dash lights Fri Jan 24, 2014 11:35 pm | |
| Hokey crap there so bright tho haha, we'll the light doesn't light up on the dimmer thing u were talking about aa maybe it doesn't work but I'll look in the owners manual to make sure and try it out, thanks you guys, is there any way to dim the lights like put something over with it bugs me haha | |
| Subject: Re: Bright dash lights Sun Jan 26, 2014 8:48 pm | |
| - 1998 Riv wrote:
- On most vehicles, I can't put up with full bright dash lights at night. Maybe it's my old eyes.
It all depends on the relative brightness. In the middle of nowhere with no streetlights and not much oncoming traffic, dimmer is nice. When it's bright around and there is a lot of ambient light it's nice to have the dash lights brighter. If I'm on a long road trip once I get away from the city and traffic I'll dim the dash lights as low as they go. | |
| Subject: Re: Bright dash lights | |
