 Hybridized Series I and Series II
ironclyde
ironclyde
Hybridized Series I and Series II Empty
PostSubject: Hybridized Series I and Series II   Hybridized Series I and Series II EmptyMon Jan 20, 2014 6:39 am
My son and I are building a stroker 3800 using a series I block and series II heads and camshaft, for his tired 3800 powered Camaro. I think I want to do the same thing for my 95 Riviera.
Has anyone on this BB tried this kind of a hybridization? I'd appreciate any info. Successes and failures are welcome to comment.
Merit : 122
PostSubject: Re: Hybridized Series I and Series II   Hybridized Series I and Series II EmptyMon Jan 20, 2014 4:09 pm
There is an old thread on 3800pro you will want to find.  Has hybrid in the title.  Outlines all the differences and what is needed.  In a *very* small nutshell(there is tons more on what needs to be done to hybrid the two), S2 heads will bolt on, but you need a custom LIM to make up the difference on the deck geometry.  Match that to the differences in making a s2 cam fit.  There's other stuff for push rod angles and oiling differences too.  I don't know if the guy ever made it run or not, but its massively more complicated than at first glance.  If you can't find the thread let me know and I'll dig it up.
(and anyone else will just tell you that its easier and cheaper to just build up a series2. They might be right, but the theoretical potential on the S1 taller block stroked with S2 enhancements are pretty awesome.)
ironclyde
ironclyde
PostSubject: Re: Hybridized Series I and Series II   Hybridized Series I and Series II EmptyMon Jan 27, 2014 7:41 pm
I did find another thread on the concept on another BBS. Maybe the moderator will allow me to post it. It's rather interesting.
http://www.3800pro.com/forum/general-tech/2953-si-ev6-tall-deck-block-sii-heads.html
PostSubject: Re: Hybridized Series I and Series II   Hybridized Series I and Series II EmptyTue Jan 28, 2014 12:55 am
The OP of the thread you posted from 3800pro is also a member here under the same name and was active for a bit not long ago. His buddy drove a Whipple supercharged Riviera that was one of their projects. Might be able to contact him if you have questions about specifics that he may have sorted out to save you some time.
Here is his showroom thread:
http://rivperformance.editboard.com/t1426-eric-s-calling-you-out-alexheheh?highlight=eric+is+calling+you+out
Good luck!
PostSubject: Re: Hybridized Series I and Series II   Hybridized Series I and Series II EmptyTue Jan 28, 2014 7:26 am
Just LS swap it.
ironclyde
ironclyde
PostSubject: Re: Hybridized Series I and Series II   Hybridized Series I and Series II EmptyThu Jan 30, 2014 10:17 pm
Awesome! I'd appreciate it. One of the biggest obstacles to overcome has been the lack of information available. I've been more successful as time has passed. But there are always questions.
Thanks!
» Movado Series 800 Chrono....
» Briggs 300 series engine
» Lucas Oil Off Road Racing Series Short Course---USTREAM TV Live
