| Write-Up: Building a Custom PVC Fenderwell Intake | |
L67 Aficionado
 | Subject: Re: Write-Up: Building a Custom PVC Fenderwell Intake Fri May 01, 2009 12:25 am | |
| - texasfan010 wrote:
- well the PVC wont have one yet, so what should i do? the plug is just dangling and there isnt an outlet on the PVC yet
Lay it inside the fenderwell if it reaches, otherwise keep it as far away from the exhaust as possible. |
texasfan010 Enthusiast
 | Subject: Re: Write-Up: Building a Custom PVC Fenderwell Intake Fri May 01, 2009 12:28 am | |
| Im just going to run without it for awhile, then im going to go to the junkyard, and find a IAT off a regal or riviera, cut it off, and put it in the PVC. Is it fine that the IAT wont even be touching the Intake? |
L67 Aficionado
 | Subject: Re: Write-Up: Building a Custom PVC Fenderwell Intake Fri May 01, 2009 12:35 am | |
- Im just going to run without it for awhile, then im going to go to the junkyard, and find a IAT off a regal or riviera, cut it off, and put it in the PVC. Is it fine that the IAT wont even be touching the Intake?
Why wouldn't you have an IAT sensor? It'll still remain even if you remove the stock airbox.... |
 | Subject: Re: Write-Up: Building a Custom PVC Fenderwell Intake Fri May 01, 2009 12:37 am | |
| the IAT sensor is on the box itself right? so the outlet part of it wont be on the car, only the plug part will be. |
L67 Aficionado
 | Subject: Re: Write-Up: Building a Custom PVC Fenderwell Intake Fri May 01, 2009 12:40 am | |
- the IAT sensor is on the box itself right? so the outlet part of it wont be on the car, only the plug part will be.
The dangling plug it where the sensor resides, so as long as the plug is somewhere near the incoming air it will still function. |
 | Subject: Re: Write-Up: Building a Custom PVC Fenderwell Intake Fri May 01, 2009 12:41 am | |
| oh ok so as long as i put the plug end as close as possible to the filter i will be ok for now? |
L67 Aficionado
 | Subject: Re: Write-Up: Building a Custom PVC Fenderwell Intake Fri May 01, 2009 12:43 am | |
Name : Codith Age : 30 Location : Villa Park, IL Joined : 2007-02-08 Post Count : 3601 Merit : 125
 | Subject: Re: Write-Up: Building a Custom PVC Fenderwell Intake Fri May 01, 2009 12:44 am | |
| Leaving the IAT sensor off somewhere in the engine bay still plugged in won't hurt anything as long as it's kept out of the way. That would be better than running with it unplugged. The only thing that could happen is the PCM will think the intake air is whatever temp the sensor sees which I reckon would be hotter, if anything, than whats coming through the intake and it will retard timing few degrees once the engine bay heats up which obviously isn't going to hurt anything except power and probably not by a very noticable amount. |
 | Subject: Re: Write-Up: Building a Custom PVC Fenderwell Intake Fri May 01, 2009 12:46 am | |
| well it wont be plugged in, the place where it plugs in is on the air box and i took that off for a FWI, theres nowhere for it to plug in yet |
L67 Aficionado
 | Subject: Re: Write-Up: Building a Custom PVC Fenderwell Intake Fri May 01, 2009 12:48 am | |
- well it wont be plugged in, the place where it plugs in is on the air box and i took that off for a FWI, theres nowhere for it to plug in yet
Right, so just leave it danglign somewhere near the air filter. |
 | Subject: Re: Write-Up: Building a Custom PVC Fenderwell Intake Fri May 01, 2009 12:55 am | |
| ok thats what i plan on doing. next week i plan on going to a junk yard and getting the top half of the air box, then using a dremel to cut out the IAT sensor outlet thing, then putting that on the PVC FWI, and plugging in the IAT sensor. Sound good? |
L67 Aficionado
 | Subject: Re: Write-Up: Building a Custom PVC Fenderwell Intake Fri May 01, 2009 1:00 am | |
- ok thats what i plan on doing. next week i plan on going to a junk yard and getting the top half of the air box, then using a dremel to cut out the IAT sensor outlet thing, then putting that on the PVC FWI, and plugging in the IAT sensor. Sound good?
Should be good. |
 | Subject: Re: Write-Up: Building a Custom PVC Fenderwell Intake Fri May 01, 2009 1:04 am | |
| i might just tape it to the PVC for now. Can i take the IAT sensor outlet off anything besides a 96' riviera? like a GTP, monte SS, 95' rivi? |
Name : Matthew Age : 31 Location : Florida Joined : 2007-01-17 Post Count : 4392 Merit : 101
 | Subject: Re: Write-Up: Building a Custom PVC Fenderwell Intake Fri May 01, 2009 10:26 am | |
| you might just want to pick up a new one from rockauto for $7 http://www.rockauto.com/catalog/x,carcode,1022038,parttype,5072i'm surprised when i go to the junk yard, pull a small part and the guy is like $20. F that, i'll give you $5 b/c it's worth $2. oh, and i dont know how long the center piece is b/c that's where the custom part come in. you will need to piece it together and find out where the filter sits and how long it need to be. 6" sounds a little short though, IDK. _________________ 1996 with 254k miles, L32 4" FWI -> ported N* -> Ported Gen V w/3.0" Pulley, Stage 3 Phenolic I/C, ZZP FMHE, 1.84 RR, Headers and 3" pipe to mufflers, F-body brakes, and lowered on Eibachs. -RIP AMG C400 White on black -daily  |
Jack the R Guru
Name : Rick Age : 59 Location : Lancaster, MA Joined : 2008-09-13 Post Count : 6081 Merit : 105
 | Subject: Re: Write-Up: Building a Custom PVC Fenderwell Intake Fri May 01, 2009 6:49 pm | |
| - Jack the R wrote:
What's the black piece between the 45 and 22(?), closest to the throttle body? It looks like it has an extra squarish part sticking out of it.
That's the LQ4 MAF Sensor. |
Jack the R Guru
 | Subject: Re: Write-Up: Building a Custom PVC Fenderwell Intake Fri May 01, 2009 7:17 pm | |
| Well that sounds like something I should already have then.  |
 | Subject: Re: Write-Up: Building a Custom PVC Fenderwell Intake Sat May 02, 2009 12:30 pm | |
| hey i made my PVC FWI last night. Man i LOVE the whine it makes, its amazing, i couldnt be happier. I just had to tape the IAT sensor to the piping. After driving for awhile I seen that my service engine soon light came on, and never has before. I dont think its a big deal, i think its just the IAT sensor is getting a little bit warmer air reading then what is actually going through the intake. What do you guys think? Am i safe to drive? |
 | Subject: Re: Write-Up: Building a Custom PVC Fenderwell Intake Sat May 02, 2009 12:37 pm | |
| Can you download the code and see what tripped the light? |
 | Subject: Re: Write-Up: Building a Custom PVC Fenderwell Intake Sat May 02, 2009 1:30 pm | |
| i dont know how to do that |
T Riley Guru
Name : Travis Age : 28 Location : Your wife's box Joined : 2007-02-08 Post Count : 5126 Merit : 9
 | Subject: Re: Write-Up: Building a Custom PVC Fenderwell Intake Sat May 02, 2009 2:18 pm | |
- i dont know how to do that
take it to autozone, pepboys, advance auto ETC.. and have them scan it.. |
 | Subject: Re: Write-Up: Building a Custom PVC Fenderwell Intake Sat May 02, 2009 2:45 pm | |
| how much does that cost? and if it is the IAT sensor, what code would that be? |
 | Subject: Re: Write-Up: Building a Custom PVC Fenderwell Intake Sat May 02, 2009 2:49 pm | |
| The scan is free and they will tell you not only the code, but what it means. Write down the code number. |
 | Subject: Re: Write-Up: Building a Custom PVC Fenderwell Intake Sat May 02, 2009 2:52 pm | |
| thanks. this will have to wait til tomorrow lol, my prom is tonight |
 | Subject: Re: Write-Up: Building a Custom PVC Fenderwell Intake Sun May 03, 2009 2:33 pm | |
| how do they do the scan? like where do they do the scan at? Do i have to take my car apart at all? |
