 Oil leak from Timing chain cover?
Steelrain
Oil leak from Timing chain cover? Empty
PostSubject: Oil leak from Timing chain cover?   Oil leak from Timing chain cover? EmptySun Mar 30, 2014 7:16 pm
I just got done replacing the oil pan gasket and putting in new oil/filter. I was about 90% sure that is where my leak was coming from. But, after replacing all of that I fired up the Riv and I am still getting the leak. It seems to be coming from the seam where the crankshaft pulley and timing chain cover meet. Is there any reason for this? Also, I do have a bit of play in CYL #3 if that has anything to do with it.
» big bear timing
» ford explorer timing gear
» Chain in place of belt.
» Warning label cover.
» fabric style bed cover
