| Replace front main seal | |
Steelrain Amateur
Name : Chris Location : Greenwood WI Joined : 2014-03-24 Post Count : 23 Merit : 0
| Subject: Replace front main seal Tue Apr 01, 2014 3:18 pm | |
| I have been looking on line for a while now and have not found anything that really helps me out. so i came here to ask fellow Riv owners, How do I go about replacing the Front Main Seal (crank shaft)? I have a massive leak coming from there and as of now the car is not useable. any and all help will be appreciated | |
| Subject: Re: Replace front main seal Tue Apr 01, 2014 3:40 pm | |
| That's actually the easier seal to replace. You need to pull the Harmonic Balancer off, and the seal is right behind it. It's not a common place for the 3800 to leak, which is why you haven't found anything on it. You'll need a Crankshaft Pulley Puller, and also a Seal Puller/Installer. You can usually get away without the seal tool, but it's recommended. What year is your car? | |
Steelrain Amateur
| Subject: Re: Replace front main seal Tue Apr 01, 2014 4:01 pm | |
| it is a 95
This is just to get the oil to stop leaking long enough for me to save up for a new engine. I have a spun rod bearing as well and a iffy at best tranny.. | |
| Subject: Re: Replace front main seal Tue Apr 01, 2014 4:17 pm | |
| Ah...it's you lol.
I think you can rent a Crank Pulley Puller from Autozone if you don't have one. I believe you can get at it from inside the passenger wheel well with some plastic trim removal. I've never personally done one on a '95. Hopefully someone who has can chime in. | |
Steelrain Amateur
| Subject: Re: Replace front main seal Tue Apr 01, 2014 4:26 pm | |
| i will have to see if i can rent it from O'Rielly or carquest as i dont have an autozone within 2hrs of me. I hope it is relatively simple as my other car will be gone on the 15th. | |
Steelrain Amateur
| Subject: Re: Replace front main seal Wed Apr 02, 2014 6:10 pm | |
| Will this http://www.harborfreight.com/46-piece-bolt-type-wheel-puller-set-69889.html work to pull the crank shaft puller? what do i need to pull the harmonic balancer? | |
| Subject: Re: Replace front main seal Wed Apr 02, 2014 7:03 pm | |
| That should work, yes. You only have to pull of the Harmonic Balancer aka Crank Pulley. | |
Steelrain Amateur
| Subject: Re: Replace front main seal Wed Apr 02, 2014 7:40 pm | |
| sounds good. cant beat the price of it.. was going to cost triple that at O'rielly | |
| Subject: Re: Replace front main seal Wed Apr 02, 2014 7:45 pm | |
| Yeah. Harbor Freight is awesome. Some of their stuff is literally crap, but most of it lasts/works a long time. For the price though, who cares if it only lasts 3 months lol. I have a fresh scar from a $9 Harbor Freight Heat Gun | |
Steelrain Amateur
| Subject: Re: Replace front main seal Wed Apr 02, 2014 7:54 pm | |
| I have bought a bit of stuff from them in the past and have been for the most part very happy with it..
When i was taking the feeder tube off when i pulled the oil pan my elbow smoked the tranny pan, the Dr wanted to give me stitches i just super glued it back together lol | |
IFallsRon Fanatic
Name : R.L. Joined : 2012-11-23 Post Count : 268 Merit : 2
| Subject: Re: Replace front main seal Wed Apr 02, 2014 8:08 pm | |
| - Abaddon wrote:
- Yeah. Harbor Freight is awesome. Some of their stuff is literally crap, but most of it lasts/works a long time. For the price though, who cares if it only lasts 3 months lol.
HF is my go-to source for tools I won't feel bad about breaking. | |
| Subject: Re: Replace front main seal | |
