 Disconnected line...any ideas?
Disconnected line...any ideas? Empty
PostSubject: Disconnected line...any ideas?   Disconnected line...any ideas? EmptyMon Apr 07, 2014 8:50 pm
Alright, getting ready to re-install everything after doing my lower intake gaskets and I forgot to upload this. In these two pictures you'll see thisline that runs 3rd behind the two fuel lines along the firewall behind the master cylinder. this third line runs down next to this little solenoid or bypass of some kind? not sure what the little box is, nor am I sure of what this hose is or why it is being bypassed. It is hanging completely unplugged and the hose fitting that it seemingly should plug into is being pinched off by a zip-tie...
What is all this?
Disconnected line...any ideas? IMAG0659_zpsddd9e1d6
Disconnected line...any ideas? IMAG0660_zpsbd6223ca
PostSubject: Re: Disconnected line...any ideas?   Disconnected line...any ideas? EmptyMon Apr 07, 2014 9:04 pm
Going off of Karma's pictures it does look like it goes there, and it does look like he had a zip tie there too and the plug goes into the side of that box. Looks like it's all there to me, just needs hooked up.
http://rivperformance.editboard.com/t4250-write-up-lower-intake-manifold-change-on-a-95
PostSubject: Re: Disconnected line...any ideas?   Disconnected line...any ideas? EmptyMon Apr 07, 2014 9:12 pm
I guess that'd be my question; what is it? And why has it never affected my car in my years driving it every day...haha
PostSubject: Re: Disconnected line...any ideas?   Disconnected line...any ideas? EmptyMon Apr 07, 2014 9:17 pm
My guess would be something to do with emissions. Karma would probably know though.
PostSubject: Re: Disconnected line...any ideas?   Disconnected line...any ideas? EmptyMon Apr 07, 2014 9:22 pm
He always knows... cool haha
Merit : 62
PostSubject: Re: Disconnected line...any ideas?   Disconnected line...any ideas? EmptyMon Apr 07, 2014 9:30 pm
Yep it's emissions related. It's the EVAP system purge solenoid, which vents evaporated fuel into the intake to use for combustion. It technically shouldnt affect anything being disconnected on that particular location.
It's funny for me to see that zip tie where it is - when my Series I was still in my Riviera I had a problem keeping that line connected too lol.
PostSubject: Re: Disconnected line...any ideas?   Disconnected line...any ideas? EmptyMon Apr 07, 2014 9:38 pm
Ha! Well now I know. I suppose I'll just let it hang the way it was or maybe plug it in and see if it stays  rolleyes
PostSubject: Re: Disconnected line...any ideas?   Disconnected line...any ideas? EmptyTue Apr 08, 2014 8:41 am
I believe on '96 and newer (OBD-II) if that's not hooked up you'd be getting evap codes. But I'm not sure if the OBD-I systems tested the tank vents. It's just a vent for the tank. In theory it will be a vacuum leak when the solenoid opens and should be hooked up. It keeps the gas tank under just a bit of negative pressure. No reason to leave it disconnected.
PostSubject: Re: Disconnected line...any ideas?   Disconnected line...any ideas? EmptyTue Apr 08, 2014 5:25 pm
Looks like someone put a spark plug boot there. On my Series 2, there is a foam filter that typically disintegrates leaving the owner to think there is a disconnected line. Could this be the same thing?
Merit : 62
PostSubject: Re: Disconnected line...any ideas?   Disconnected line...any ideas? EmptyWed Apr 09, 2014 9:58 am
There is typically a litttle foam filter on the boost bypass valve, but not on this evap solenoid. Everything looks right, just not connected razz .
Merit : 122
PostSubject: Re: Disconnected line...any ideas?   Disconnected line...any ideas? EmptyWed Apr 09, 2014 10:55 am
Everyone listen to Z-type. He knows things. smile
Merit : 62
PostSubject: Re: Disconnected line...any ideas?   Disconnected line...any ideas? EmptyWed Apr 09, 2014 10:56 am
Only because you taught me!
» Fluorocarbon line
» Bought this at the salvage yard. Ideas anyone?
» NEED HELP - Monofilament line & HOOKS/TREBLES size.
» New reel line
» Line cutting knife
