 75mm Throttle Body and Intake Kit installed on my other ride.
bigROC209
bigROC209
75mm Throttle Body and Intake Kit installed on my other ride. Empty
PostSubject: 75mm Throttle Body and Intake Kit installed on my other ride.   75mm Throttle Body and Intake Kit installed on my other ride. EmptySun Apr 20, 2014 6:12 pm
The registration and a smog inspection was due on my 02 Grand Marquis last month.  In order to pass smog I had to remove my intake setup and return my car's ECU back to stock settings.  My ride passed with flying colors!
I finally got around to re-installing my bolt-ons and replaced my ported and polished 65mm mustang throttle body with a beefier aftermarket 75mm throttle body.  It's time to let my 4.6 breathe!
It only makes sense to go with the 75mm since I upgraded the MAF sensor to a Mustang 80mm from the stock 70mm maf.  I also have a 75mm Trickflow intake plenum so the intake air should be a lot straighter since the plenum and TB are now the same size.
I also sprayed my previously chrome intake pipe with a can of ceramic engine enamel.
75mm Throttle Body and Intake Kit installed on my other ride. 75mm_t10
75mm Throttle Body and Intake Kit installed on my other ride. 75mm_t11
Here's a pic of the 75mm TB eating the stock throttle body.
75mm Throttle Body and Intake Kit installed on my other ride. 75mm_t12
75mm Throttle Body and Intake Kit installed on my other ride. 75mm_t13
75mm Throttle Body and Intake Kit installed on my other ride. 75mm_t14
75mm Throttle Body and Intake Kit installed on my other ride. 75mm_t15
PostSubject: Re: 75mm Throttle Body and Intake Kit installed on my other ride.   75mm Throttle Body and Intake Kit installed on my other ride. EmptyWed Apr 23, 2014 10:04 am
What else have you done to the 4.6? Curious what demands the larger TB.
PostSubject: Re: 75mm Throttle Body and Intake Kit installed on my other ride.   75mm Throttle Body and Intake Kit installed on my other ride. EmptyWed Apr 23, 2014 10:51 am
Did you have to do any tuning for the bigger TB? Me and my friend were going to grab a GT TB to put on his 3.8.
» Clean your throttle bodies!
» Just Add Dirt Videos
» Metallic Desert Red XTZ
» What RZR?
» Throttle body piece broke.
