sall Member
Name : sall Location : WBGV Joined : 2013-08-04 Post Count : 55 Merit : 0
| Subject: Tire Size/Offset - What are you running? Wed May 14, 2014 9:33 pm | |
| Just curious to see what everyone is running aftermarket wheel/tire wise. I am currently running 20x8.5" +45 Offset w/ 255/35/20 tires. I pressed in some new 0.5" longer wheels studs and added a 13mm spacer on the rear. So I have a +32 offset in the rear. I really like how it sits back there now. Is anyone running 255s up front with a +35 offset or higher? I want to flush it up a bit more but want to avoid rubbing at full clock. I have exhausted my resources on the Aurora forum for comparisons. | |
| Subject: Re: Tire Size/Offset - What are you running? Thu May 15, 2014 2:51 am | |
| I'm running 18x8 wheels with i believe a 43mm offset - front tires are 265/40?/18 MT drag radials - absolutely no contact. I had 275 width bfgoodrich somethings up front before and although I never really noticed it, I saw evidence of rubbing after a while. They were very noticeably wider than my current tires though to say something was making a bigger difference than 10mm (the sidewall profile was the same) | |
sall Member
| Subject: Re: Tire Size/Offset - What are you running? Thu May 15, 2014 11:20 am | |
| Thanks! I appreciate it. Looks your setup puts you ~7mm further out up front than I am right now.
Anyone else? | |
| Subject: Re: Tire Size/Offset - What are you running? | |
