 Write-Up: Installing a Front Strut Tower Brace (STB)
Go to page : Previous  1 ... 13 ... 22, 23, 24, 25, 26  Next
PostSubject: Re: Write-Up: Installing a Front Strut Tower Brace (STB)   Sun Jan 06, 2013 1:53 pm
Really the thicker you go the more clearance issues you'll start to run into. Both w/ the brake fluid reservoir And the hood. Don't want to start getting hood gap. I'd still be curious if someone were to craft an stb for the riv a la modern stb's. Those flatter arched bars with the furled edges...
Merit : 239
PostSubject: Re: Write-Up: Installing a Front Strut Tower Brace (STB)   Sun Jan 06, 2013 2:00 pm
I don't think many would pay for it. If we're questioning $65 shipped for a brand new OEM bar, it's going to be hard to sell a forged aluminum or carbon bar for $500 plus.
^^^ RIV IS FOR SALE! ^^^
PostSubject: Re: Write-Up: Installing a Front Strut Tower Brace (STB)   Sun Jan 06, 2013 3:12 pm
aint that the truth.
i bet i could fabricate a bar for less than $15 bucks.thats just for the materials.im guessing maybe even less than that.
i can buy 20 feet of 065 wall 5/8s tubing for around $15 bucks. 3/4 tubing around $20 bucks. youre not paying for the materials really.youre paying for the labor.
the more fabricating i get into the more of a bitch it is.working on steel is not easy. the cutting and the welding, the fumes and the setting up.Hard.
PostSubject: Re: Write-Up: Installing a Front Strut Tower Brace (STB)   Mon Jan 07, 2013 3:06 pm
Located one for $49.99 shipped. Might pull the trigger on this one.
PostSubject: Re: Write-Up: Installing a Front Strut Tower Brace (STB)   Mon Jan 07, 2013 4:26 pm
Shipping included, that's a fair deal.
PostSubject: Re: Write-Up: Installing a Front Strut Tower Brace (STB)   Sat Jan 12, 2013 1:00 pm
And a fair deal it was! A friend referred me to a parts guy in town. He located it and got it shipped to his shop for $50. This sucker bolted right up to my 99 will no modification needed! Flush on both ends like it was made for my car and clears everything perfectly. A perfect fit! UNHHH afro
Merit : 239
PostSubject: Re: Write-Up: Installing a Front Strut Tower Brace (STB)   Sat Jan 12, 2013 1:22 pm
Wow, this might be the first one to fit so well without rubbing the brake fluid reservoir. Nice job!
PostSubject: Re: Write-Up: Installing a Front Strut Tower Brace (STB)   Sat Jan 12, 2013 2:04 pm
Lies and deceit! Photo manipulation!
PostSubject: Re: Write-Up: Installing a Front Strut Tower Brace (STB)   Sat Jan 12, 2013 4:15 pm
I was just as surprised as you guys. Definitely giggled a little a bit when I realized it was going to be a perfect fit.
artlock
PostSubject: Re: Write-Up: Installing a Front Strut Tower Brace (STB)   Sat Jan 12, 2013 6:40 pm
I'm still wondering here. Does anyone know if the STB fits on the 95 series one the same way? I saw Gmann put one on his 95 but he has a series 2 engine. Does that matter at all? I am looking to do this upgrade. I just want to be sure. Thanks!
PostSubject: Re: Write-Up: Installing a Front Strut Tower Brace (STB)   Sat Jan 12, 2013 6:44 pm
Fit is the same on the 95. The master cylinder clearance issue remains on all years 95-99....except for Charlie apparently haha
artlock
PostSubject: Re: Write-Up: Installing a Front Strut Tower Brace (STB)   Sat Jan 12, 2013 6:50 pm
Cool,thanks! I think I am going to do this one!
PostSubject: Re: Write-Up: Installing a Front Strut Tower Brace (STB)   Sat Jan 12, 2013 10:21 pm
This STS STB is tits. Definitely made a noticeable difference in ride quality and cornering. Much smoother ride now overall. Definitely worth they $50 I paid Jerry to find it for me.
Does anyone else have a '99 with this on? I'd like to know if I am the only one who had it so easy.
PostSubject: Re: Write-Up: Installing a Front Strut Tower Brace (STB)   Mon Jan 14, 2013 12:46 am
The 98 and 99 models seem to have the easiest install. Mine was a 10 min job taking my time.
I believe the 95's have an issue with mounting bolts. They actually used studs coming up from underneath instead of bolts screwing in from the top side of the tower. And the stock studs, I think I've read, can be too short.
PostSubject: Re: Write-Up: Installing a Front Strut Tower Brace (STB)   Mon Jan 14, 2013 1:32 am
That's weird. On my 95 the bar sat right in. In fact I had room to add washers if I needed to. No shortage of bolt scratch
PostSubject: Re: Write-Up: Installing a Front Strut Tower Brace (STB)   Mon Jan 14, 2013 4:58 pm
Here's my 95. Sts bar I got from Rick (DEMonte1997) he had it fit for his 97 so the front bolt holes were cut open into...well, hooks really. Haha I just used a couple thin n wide washers on top of the bar to make up the lost surface area and bolted em down, plenty space for this. Also have the slight radial bend in the bar at the reservoir a la Aaron for the best clearance I could achieve.
No gap cool
PostSubject: Re: Write-Up: Installing a Front Strut Tower Brace (STB)   Mon Jan 14, 2013 5:49 pm
I am totally satisfied with this mod and would recommend it to everyone. The car feels even better just going in a straight line not to mention cornering. Love it.
I wonder how long it will take to forget how my Riv handled without it.
Merit : 239
PostSubject: Re: Write-Up: Installing a Front Strut Tower Brace (STB)   Mon Jan 14, 2013 7:31 pm
If you forget, just take the bar off and it will all come back!
Ash
PostSubject: Re: Write-Up: Installing a Front Strut Tower Brace (STB)   Tue Jan 15, 2013 10:58 am
I have a '99. It went on fairly easily, but I had to do the dimple modification over the brake system reservoir like llamalor2112 shows in his pictures. You may very well be the only one that had a direct fit with no interference. Maybe during the build of your car, tolerance stacking went in your favor. ?? scratch
Yes, a very noticable ride/handling difference after the installation.
Remove it? shocked Never. happy
Merit : 20
PostSubject: Re: Write-Up: Installing a Front Strut Tower Brace (STB)   Wed Apr 17, 2013 9:39 pm
BTW, it looks like these are still available for about $40 from "Vintage Parts" . According to a thread on a Cadillac forum, "Vintage Parts" bought out some portion of this GM stock.
They appear to have about 20 in stock, for about $40 each (not including shipping).
http://www.vpartsinc.com/
Search for:
GM/ACDELCO AUTO PARTS - 25653157
PostSubject: Re: Write-Up: Installing a Front Strut Tower Brace (STB)   Thu Apr 18, 2013 9:55 am
I too have a '99 and my STS bar when on smooth as butter. No problem what-so-ever. It was like it was made for my car.
Greatly changed the handling of my ride, in corners AND on straights. Definitely recommend this.
Randy T.
PostSubject: Re: Write-Up: Installing a Front Strut Tower Brace (STB)   Sat May 11, 2013 4:32 pm
nothincame2mind wrote:
I wonder if the Bonneville GXP STB will fit. Looks like it might help clear the MC. Not sure how many of them they are out there, but it might be another option. Apparently some Bonne guys are using the '98-'04 STS bars.
I put '03 Bonneville struts and a GXP Bonneville STB on my '97 Aurora, I had to elongate a couple strut holes to do this. If Rivieras suspension changed the same year as Auroras, then the GXP STB would be a bolt on affair for '98 and up Rivieras, unless they were some clearance issues with the SC Rivieras. Auroras have pretty much the same suspension from '98-'03, and it also carries on and improves with the Buick Lucerne.
Merit : 20
PostSubject: Re: Write-Up: Installing a Front Strut Tower Brace (STB)   Sun May 12, 2013 12:44 am
That is certainly very interesting. It would be great to see if it clears the SC and other bits on the Riviera. Just from a cursory glance at your photos, I think the one clear item in question would be if the bar is going to clear the alternator on the Riviera and also not hit the hood.
I found the following part number on a thread in a Cadillac forum and if the part number is correct, vintage parts has it as well, again for about $40.
http://www.cadillacforums.com/forums/cadillac-seville-cadillac-eldorado-forum/185146-will-bonneville-gxp-front-strut-tower.html
Part Number#25653157
Can anyone confirm the part number is for the Bonneville GXP strut brace?
Randy T.
PostSubject: Re: Write-Up: Installing a Front Strut Tower Brace (STB)   Sun May 12, 2013 9:04 am
Here is a link to the writeup on the Aurora forum, with current part numbers. A lot of places have them listed, but these are hard to find, they may say they have them and then contact you with a little higher quote saying they have to special order them. I got mine from another member on the Aurora forum.
http://aurorah.proboards.com/index.cgi?action=display&board=Zoom&thread=15888
Merit : 20
PostSubject: Re: Write-Up: Installing a Front Strut Tower Brace (STB)   Sun May 12, 2013 10:07 pm
The part #s in that thread are different. Vintage Parts only has a match for the right hand bracket.
Page 23 of 26Go to page : Previous  1 ... 13 ... 22, 23, 24, 25, 26  Next
