| Runnability issue hardest i ever had to diagnose | |
Trystlore Member
Name : Mike Woods Age : 53 Location : Kansas City Joined : 2012-08-04 Post Count : 78 Merit : 0
| Subject: Re: Runnability issue hardest i ever had to diagnose Sun Jun 08, 2014 5:59 pm | |
| This engine used to soundlike a jet from air intake when I blipped the throttle. | |
| Subject: Re: Runnability issue hardest i ever had to diagnose Sun Jun 08, 2014 8:05 pm | |
| If you hook a vacuum gauge up to the engine, and bring it up to about 1500 RPM in Neutral/Park, and hold it steady, the vacuum should hold steady at about 20". If it starts to fall off, that points to a clogged exhaust. _________________ 98 Riviera SC3800 All stock except gutted air box. 1970 Buick GS455 Stage1, TSP built 470BBB, 602HP/589TQ Best MPH, 116.06 MPH, Best ET, 11.54 https://www.youtube.com/watch?v=UHCda-t_Jls https://www.youtube.com/watch?v=sfT2tEO4XcU
Trystlore Member
| Subject: Re: Runnability issue hardest i ever had to diagnose Sun Jun 08, 2014 8:11 pm | |
| I have a vacuum gauge in route finally hope to have it tested in an hour or so. | |
| Subject: Re: Runnability issue hardest i ever had to diagnose Sun Jun 08, 2014 10:41 pm | |
| this is a longshot -- but find a factory manual and double check the plug wire order. They might be mixed up a little at the coil pack?!? I am grabbing at straws here. | |
Trystlore Member
| Subject: Re: Runnability issue hardest i ever had to diagnose Sun Jun 08, 2014 10:46 pm | |
| Nah they are good vacuum was 14.5 at idle 15 at 1500 rpm | |
| Subject: Re: Runnability issue hardest i ever had to diagnose Sun Jun 08, 2014 10:51 pm | |
| - Trystlore wrote:
- Nah they are good vacuum was 14.5 at idle 15 at 1500 rpm
Your vac could be higher, I am thinking exhaust is impaired.... | |
Trystlore Member
| Subject: Re: Runnability issue hardest i ever had to diagnose Sun Jun 08, 2014 10:56 pm | |
| Leaning there as well gonna open it up Tuesday and check engine reaction | |
rivi95era Enthusiast
Name : Marc Age : 41 Location : Albemarle Joined : 2014-05-18 Post Count : 110 Merit : 0
| Subject: Re: Runnability issue hardest i ever had to diagnose Mon Jun 09, 2014 8:13 am | |
| Its odd that all of the diagnostics nobody has mentioned to check the fuel pressure. That can lead to all the symptoms you mention and can be as simple as a clogged fuel filter. The next thing has already been mentioned and thats a clogged cat but you will actually loose power the warmer the car gets. GM's are prone to that but the symptoms are very pronounced. | |
| Subject: Re: Runnability issue hardest i ever had to diagnose Mon Jun 09, 2014 11:36 am | |
| - rivi95era wrote:
- Its odd that all of the diagnostics nobody has mentioned to check the fuel pressure. That can lead to all the symptoms you mention and can be as simple as a clogged fuel filter. The next thing has already been mentioned and thats a clogged cat but you will actually loose power the warmer the car gets. GM's are prone to that but the symptoms are very pronounced.
It's entirely possible, but rare. Changing the fuel filter is certainly a worthwhile idea, but I have seem OEM fuel filters with 200K on them. My '05 Yukon didn't even have a fuel filter. They relied entirely on the in-tank pickup screen (sock filter). That's got almost 200K on it and still on the original fuel pump. | |
| Subject: Re: Runnability issue hardest i ever had to diagnose Mon Jun 09, 2014 1:43 pm | |
My '05 Yukon didn't even have a fuel filter. They relied entirely on the in-tank pickup screen (sock filter). That's got almost 200K on it and still on the original fuel pump. The lifetime of a fuel filter is entirely based on where you are and where the fuel is refined. Some refineries are dirtier than others hence the reason for a fuel filter but they are all in a sense dirty, lol Having worked at a fuel station for quite some time a lil while back I got to know the transporters very well and they showed me how to get samples out of the in ground tanks. Nasty stuff before it goes through the pump and the fuel stations that have the screw on style filters at the top of the pump hose, REALLY Dirty!! Something else a lot of people don't know is most of the fuel stations that have three grades just mix 93 and 87 together to achieve 89. (US Octane and method) | |
Trystlore Member
| Subject: Re: Runnability issue hardest i ever had to diagnose Mon Jun 09, 2014 2:21 pm | |
| Changed fuel filter last week I will throw a fuel pressure tester on it tomorrow before I cracked it open. New fuel filter helped somewhat. But not as much as expected | |
| Subject: Re: Runnability issue hardest i ever had to diagnose Mon Jun 09, 2014 3:43 pm | |
Nope, that isn't normal. I have a vacuum/boost gauge installed on my 153,000 mile 98 Riv. It pulls 20" at idle all day every day. You either have a vacuum leak somewhere or a clogged exhaust. _________________ 98 Riviera SC3800 All stock except gutted air box. 1970 Buick GS455 Stage1, TSP built 470BBB, 602HP/589TQ Best MPH, 116.06 MPH, Best ET, 11.54 https://www.youtube.com/watch?v=UHCda-t_Jls https://www.youtube.com/watch?v=sfT2tEO4XcU
Trystlore Member
| Subject: Re: Runnability issue hardest i ever had to diagnose Mon Jun 09, 2014 3:51 pm | |
| Went all around the vacuum lines and intake with starting fluid since hose inspection was turning up any leaks.No leaks that we could find. Don't have a smoke machine anymore so gonna temporarily figure no vacuum leak. Weather permitting going to Unbolt the exhaust tomorrow and see if that solves my obvious issues. Though considering an issue I had when I was changing my plugs and a few other things my thoughts heavily lean towards the partially clogged exhaust. | |
| Subject: Re: Runnability issue hardest i ever had to diagnose Tue Jun 10, 2014 2:50 pm | |
| These are my readings, fully warm in Park, at normal idle. _________________ 98 Riviera SC3800 All stock except gutted air box. 1970 Buick GS455 Stage1, TSP built 470BBB, 602HP/589TQ Best MPH, 116.06 MPH, Best ET, 11.54 https://www.youtube.com/watch?v=UHCda-t_Jls https://www.youtube.com/watch?v=sfT2tEO4XcU
| Subject: Re: Runnability issue hardest i ever had to diagnose Tue Jun 10, 2014 3:15 pm | |
| [quote="LARRY70GS"]These are my readings, fully warm in Park, at normal idle. oh man thats fancy!!! | |
Trystlore Member
| Subject: Re: Runnability issue hardest i ever had to diagnose Tue Jun 10, 2014 3:32 pm | |
| Subject: Re: Runnability issue hardest i ever had to diagnose | |
