 gasket question
PostSubject: gasket question   Mon Jun 02, 2014 3:29 pm
My engine is currently torn down to the block.
The good news is, no chipped pistons!
Now I'm wondering, can I reuse my aluminum LIM gaskets? And can I reuse my exhaust manifold gaskets? They are the double layer metal type ones.
Obviously I'm doing new head gaskets and head bolts. I just don't want to spend more money than I have to!
Thanks guys!
Merit : 171
PostSubject: Re: gasket question   Mon Jun 02, 2014 5:05 pm
Yes and yes. Be sure to check the LIM gaskets VERY thoroughly. Inspect every single bit of rubber on both sides of those things for any rips or tears. If you see any hint of a tear, replace them.
As for the exhaust gaskets, absolutely re-use them. Those things never go bad.
PostSubject: Re: gasket question   Mon Jun 02, 2014 5:08 pm
Cool. Thanks man!
Merit : 49
PostSubject: Re: gasket question   Mon Jun 02, 2014 7:14 pm
Honestly if you can afford the time and the money just do them. I know they'll probably be just fine like Abaddon said, but why take the risk? A little bit of money to possibly save you a lot of time and money later on. Just my logic. Might as well do all of the hard to reach sensors while you're in there and have the room too.
PostSubject: Re: gasket question   Mon Jun 02, 2014 7:52 pm
But I'm a cheap ass mofo.  surprised
I know for a fact the lim gaskets only have like 10,000 miles on them too
PostSubject: Re: gasket question   Mon Jun 02, 2014 8:41 pm
After a full engine teardown/rebuild, it would really suck to have to do either of those gaskets again. Be cheap in other places. Don't skip such critical components. At least on the LIM gaskets. The exhaust gaskets aren't so bad to replace it you had to. The LIM gaskets - don't skip them please.
rivi95era
PostSubject: Re: gasket question   Tue Jun 03, 2014 8:10 am
Mine went bad and they have never been off the car.
Merit : 123
PostSubject: Re: gasket question   Thu Jun 05, 2014 8:09 pm
This
PostSubject: Re: gasket question   Thu Jun 05, 2014 9:50 pm
I reused them. The lim gaskets looked absolutely brand new, and I didn't really see how the exhaust gaskets could go bad. All seems good.
PostSubject: Re: gasket question   Thu Jun 05, 2014 10:01 pm
Tyler, you ready for norwalk tomorrow night?!
PostSubject: Re: gasket question   Thu Jun 05, 2014 10:04 pm
Depending on when you want to leave, I ought to be!
gasket question
» Best gasket sealant
» Clutch Release Mechanism removal , a question please.
» Best Header Gasket
» Pulley Question
» Write-Up: Oil Pan Gasket Replacement and Aluminum Oil Pan
