 head up replacing belts on 96 riviera
mattsaari
head up replacing belts on 96 riviera Empty
PostSubject: head up replacing belts on 96 riviera   head up replacing belts on 96 riviera EmptySun Jun 15, 2014 2:57 pm
I know a lot of people say you need to remove the whole motor mount and power steering pump but instead all you do is remove the lower right motor mount bolt that has the spacer as that is a pass through for the belt!! hope that helps someone just relized it today!
» Riviera has an apetite for supercharger belts
» Looking for advice
» Write-Up: Replacing Belts and Pulleys
» Crunching/Clunking/Roaring noise on takeoff and turning
» I need advice on replacing the engine on Riviera 95 SC
