 correct flywheel?
designer1962
designer1962
correct flywheel? Empty
PostSubject: correct flywheel?   correct flywheel? EmptyMon Jul 07, 2014 3:15 pm
Is the flywheel with part# 24503043 correct fot the 3800 series 1 SC engine? Automatic trans.
PostSubject: Re: correct flywheel?   correct flywheel? EmptyMon Jul 07, 2014 10:09 pm
There are two different flywheels (flexplates) for the '95 Riv. One has balance weights and one does not. You must use the right on or you will have a vibration problem.
correct flywheel?
» Correct way to repair pitch marks
» For all my grammatically correct friends.
» How do I remove a seized flywheel?
» I have oil slowly leaking out near the flywheel
» Is the "Correct" answer always the "RIGHT" answer?
