 Recirculate Mode Intake
urbanski_m
PostSubject: Recirculate Mode Intake   Mon Jul 07, 2014 9:47 pm
Does any one know where the air intake is for the HVAC recirculate mode on a 97 Riviera?  I want to deodorize the HVAC system in my car and need to spray the cleaner into the interior intake while in Recirculate mode.  I tried to find it myself with the system on high, but couldn't.   Pictures would help
PostSubject: Re: Recirculate Mode Intake   Mon Jul 07, 2014 10:04 pm
Using a piece of paper under the dash is the best way to find it. I have never done it on a Riv, but have on other cars. With fan on high and on recirc mode, wave a piece of paper around under the dash until you feel it getting sucked in.
PostSubject: Re: Recirculate Mode Intake   Tue Jul 08, 2014 4:07 pm
If you have to 'deoderize' I would be willing to bet that what you really need to do is push a heavy wire (coathanger) carefully up into the drain (on the firewall, near the power steering pump, looks like a small duck's bill facing down) and let the water out. That will most likely make any unusual odors go away.
Merit : 131
PostSubject: Re: Recirculate Mode Intake   Tue Jul 08, 2014 7:32 pm
...and if that does not work, make a deodorizing solution of OdoBan (available at Sams Club and HomeDepot) per label directions, about a gallon of it in hot tap water, and pour it into the air intake on the drivers side just below the windshield wiper.
urbanski_m
PostSubject: Re: Recirculate Mode Intake   Wed Jul 09, 2014 9:23 am
Derek,
how far should the coat hanger wire go?  I don't want to do any damage.
PostSubject: Re: Recirculate Mode Intake   Wed Jul 09, 2014 4:42 pm
Derek,
I'd guess 3 inches or so. You just have to break through the layer of crap clogging the drain, and you'll start getting wet. Then you'll know it's time to stop. wink
