 Timing Chain replacement & timing
akasirro
Timing Chain replacement & timing Empty
PostSubject: Timing Chain replacement & timing   Timing Chain replacement & timing EmptySat Jul 19, 2014 10:13 pm
Is there anyway to tell if my timing is off?  I just replaced a broken chain and the dots were not aligned when the chain broke.  I have the new chain, sprocket, and gear installed with the dots aligned but when I turn the engine by the cam bolt I have resistance at some points and none at other points.  Any help would be appreciated.   Its an 95 riv sc.  I'm in over my head but feel like this is the last hump... I'm hesitant to reinstall everything without confirming that this "resistance" is ok.  I also hear a slight bit of air as I turn the cam, I have the #1 spark plug out at the moment.
Please help!  Thanks!!
sloshua
sloshua
PostSubject: Re: Timing Chain replacement & timing   Timing Chain replacement & timing EmptySun Jul 20, 2014 12:30 am
if dots line up should be fine. If #1 plug is out yer not gonna get compression out of that cylinder obviously.
sloshua
sloshua
PostSubject: Re: Timing Chain replacement & timing   Timing Chain replacement & timing EmptySun Jul 20, 2014 12:39 am
well lemme help out a lil more the vin 1 or super charged motors are interference that means if chain breaks u can have a piston wack a valve thats still open and that can cause some major problems. best thing to do is to make sure all the valves are still going in and out and not stuck which would be yer problem if not getting compression on some of the cylinders
akasirro
PostSubject: Re: Timing Chain replacement & timing   Timing Chain replacement & timing EmptySun Jul 20, 2014 12:25 pm
thanks sloshua. i've been trying to think through how to confirm valve movement and i'm assuming that i will have to remove the valve cover to do so. sorry if i'm stating the obvious. i'm the oil, headlight, and wiper change guy at my garage... this all started with a no start condition that turned out to be a bad crankshaft position sensor.
going to pull the cover and take a look. i'm thinking that the cam position was set on the exhaust stroke when i lined up the dots.
PostSubject: Re: Timing Chain replacement & timing   Timing Chain replacement & timing EmptyMon Jul 21, 2014 3:29 pm
You're going to get resistance turning over an engine by hand. It's called compression. It happens to anything that uses pistons. Generally, if you turn an engine over by hand and get NO resistance, then there is some sort of timing issue (broken chain/belt). As long as you lined up the dots, the car should run.....
» big bear timing
» ford explorer timing gear
» Tecumseh HH120 Won't Start
» Rhino 700 Programmer/ECU
» 2 Honda xr80's for sale
