 car wont crank
jeffyd123
Name : Jeff Del Vechio
PostSubject: car wont crank   Tue Aug 12, 2014 11:46 am
hi guys... my 98's starter went out yesterday after warning me for a few months ( I would turn the key and there would sometimes be a 1 - 3 second delay before the starter would crank).
i put a new starter in and now it wont crank. Im wondering if there is a relay or a fuse in the starter circuit.
-Im not getting any weirdness on the VATS
-I can crank the car by shorting out the solenoid and the car runs fine
-there is no power coming to the solenoid
-Ive checked all of the fuses and none are blown.
before i replaced the starter, I was furiously trying to start the car by turning the key on and off and holding it on.... Im thinking this damaged something like the Ignition block switch (under the dash) or the neutral safety switch, or blew a fuse somewhere.
any ideas? Im wondering if there is a bad relay somewhere....
thanks a bunch
Jeff
Merit : 175
PostSubject: Re: car wont crank   Wed Aug 13, 2014 11:48 am
Have you checked the 10A CRANK Fuse in the IP Fuse Block? Or the Starter Enable Relay? The relay is located under the left side IP near the BCM.
Worst case scenario, the Ignition Switch is failing.
jeffyd123
PostSubject: Re: car wont crank   Wed Aug 13, 2014 7:53 pm
ill check the starter enable relay... crank fuse is ok
thx Abaddon
Merit : 131
PostSubject: Re: car wont crank   Sat Aug 16, 2014 11:18 am
...try replacing the solenoid, yours migh have been bad new or someone might have swapped it (buy the starter, swap solenoid, return starter "oh I don't need it...") and you got stuck. Maybe.
car wont crank
