Name : zack p Joined : 2013-03-16Post Count : 19 Merit : 0
Subject: need help, power steering problem/magnasteer Wed Aug 13, 2014 2:38 pm
I've been having problems with steering lately, things are fine while driving but at parking lot speeds, sometimes the power steering cuts out and it becomes very hard to turn and half the time it works fine, my service manuals top diagnosis is a magnasteer issue, but the section it refers you to (8a 45) seems to be missing or torn out. If anyone knows what kind of fix I'd be looking at for a magnasteer issue, or has the missing section in their manual or any other idea what's wrong with my steering, help would be greatly appreciated. All of this is on a 97 by the way.
CHAS1 likes this post
Subject: Re: need help, power steering problem/magnasteer Wed Aug 13, 2014 2:42 pm
It has nothing to do with the MagnaSteer. The pump is probably on its way out. It sounds like its not supplying enough pressure at low RPMS. Start with that.....
Name : Location : Finger Lakes of New York State Joined : 2007-05-31Post Count : 8577 Merit : 180
Subject: Re: need help, power steering problem/magnasteer Sat Aug 16, 2014 11:23 am
+ what abaddon said, Magnasteer does not clinch hard enough to cause an issue like that.
zpetey88 Rookie
Subject: Re: need help, power steering problem/magnasteer Thu Aug 28, 2014 6:08 pm
So is replacing the pump something that is feasible to do on my own? or am I going to have to go to a mechanic, and how much will the part and labor be do you think?
Subject: Re: need help, power steering problem/magnasteer Thu Aug 28, 2014 6:22 pm
Well, the lines have to be disconnected from underneath, and the pump can be removed from the top. Then you have to remove the Pulley with a P/S Pulley remover, and then install it on the new pump with a P/S Pulley installer. If you aren't mechanically inclined, nor have the tools, this isn't the P/S pump replacement job for you.
No clue what a pump costs these days, but you're looking at about 2-3 hours of labor + fluid and shop supplies.
zpetey88 Rookie
Subject: Re: need help, power steering problem/magnasteer Fri Aug 29, 2014 12:36 am
Alright man, thank you!
