JOE RIV 1 Amateur
Name : joe rivecco Joined : 2012-12-16 Post Count : 24 Merit : 0
| Subject: radio help Sat Sep 06, 2014 10:10 am | |
| i have a 97 riv that the radio works but no midrange out of the front speakers.i did replace the door speakers and the same sound.Is there a sep amp for the front or is it the head unit or chanel blown.thanks for the help. joe riv | |
| Subject: Re: radio help Sun Sep 07, 2014 12:31 am | |
| Fronts are driven direct from head unit, no amps. You could need a new head, or the wiring could be at fault. _________________ '05 GTO 6.0L • 6-spd • 95k miles • 0-60: 4.8s • 16.9 avg MPG • Nelson Ledges Lap: 1:26'95 Celica GT 2.2L • 5-spd • 165k miles • 0-60: yes'98 SC Riviera • 281k miles • 298 HP/370 TQ • 0-60: 5.79s • ET: 13.97 @ 99.28 • 4087 lb • 20.1 avg MPG • Nelson Ledges Lap: 1:30 3.4" pulley • AL104 plugs • 180º t-stat • FWI w/K&N • 1.9:1 rockers • OR pushrods • LS6 valve springs • SLP headers • ZZP fuel rails KYB GR2 struts • MaxAir shocks • Addco sway bars • UMI bushings • GM STB • Enkei 18" EV5s w/ Dunlop DZ101s • F-body calipers EBC bluestuff/Hawk HP plus • SS lines • Brembo slotted discs • DHP tuned • Aeroforce • Hidden Hitch^^^ SOLD ^^^ '70 Ninety-Eight Holiday Coupe 455cid • 116k miles^^^ SOLD ^^^ | |
charlieRobinson Expert
| Subject: Re: radio help Sun Sep 07, 2014 1:54 pm | |
| I have a stock head unit out of a 98. lemme know if you need it. | |
