 Helpful link on Tuning for Smaller SC Pulleys
PostSubject: Helpful link on Tuning for Smaller SC Pulleys   Tue Jul 03, 2007 1:49 pm
This guy has a lot of mods, but no intercooler, and running a 3.0" pulley with zero KR:
http://www.davetech.net/car-tuning.htm
Merit : 125
PostSubject: Re: Helpful link on Tuning for Smaller SC Pulleys   Tue Jul 03, 2007 1:56 pm
so with the purchase of high capacity injectors and a powertuner, this can be done if you take some time tuning it right?
PostSubject: Re: Helpful link on Tuning for Smaller SC Pulleys   Tue Jul 03, 2007 2:26 pm
This is the kind of tuning I'm doing right now, when I have the time for it. Here's what I've learned so far:
1) Ambient temps are a big deal. I can tune in my 3.2" pulley at 55F, but when it warms up to 65F I see KR again, so I have to add more fuel. What I've done is create a tune for every 5 change (I know, it sounds crazy). I'll probably end up using the "warmest" tune for everyday driving, but for the track I'll want it more optimized.
2) With a given SC pulley size, as ambient temps rise you'll find that adding fuel either doesn't remove the KR, or the mix just gets so rich that it hurts performance. At a certain temp, you can tell you've reached the limit when your O2 values go up past the 980 range. At this point, it's time to move up a pulley size (lower boost). My car currently likes a 3.2" under 55F, a 3.3" up to 75F, and a 3.4" above that.
3) 3.1" and smaller pulleys require bigger injectors, and probably more mods. You must tune for the injectors, and you should get a stronger fuel pump w/ bigger wiring to provide the added fuel pressure. In the above case, I think he had ported/polished heads, ported/polished/wrapped exhaust manis, cam, very cool plugs, and a PCM tune in order to go down to the 3.0".
4) Fuel/octane must be consistent. When you push the SC pulley size envelope, you are so close to knocking that just dropping from 93 to 92 octane can make a difference. Also, bad gas from an unknown source can screw up everything. For this reason, I try to use 94 octane gas from the same station, even from the same pump if I can.
5) Most with experience tuning their cars will tell you that a car with a SC pulley too large for its mods can be tuned to outperform a car with a pulley too small for its mods. Boost is not the answer in making power, it's flow that's the key.
6) An intercooler fixes a lot of the above concerns. It's expensive, but it's the safest and easiest way to run smaller SC pulleys, imo.
