 unconnected sensor ??
3 posters
mdg642rf
unconnected sensor ?? Empty
PostSubject: unconnected sensor ??   unconnected sensor ?? EmptyFri Jan 09, 2015 3:59 pm
hello...have 98 riv. looking for a leak under the main pulley axle area and I noticed a unconnected sensor. the plug in is right behind the pulley..have no idea what this for..or how long this has been unconnected any help would be appreciated...thanks
PostSubject: Re: unconnected sensor ??   unconnected sensor ?? EmptyFri Jan 09, 2015 4:13 pm
Ummm....that's the Crank Sensor, and no idea how your car is running without it plugged in.
PostSubject: Re: unconnected sensor ??   unconnected sensor ?? EmptyFri Jan 09, 2015 4:38 pm
Down there, could be the oil pressure or knock sensor as well. There is also a connector for some of the variable assist power steering systems in that area.
PostSubject: Re: unconnected sensor ??   unconnected sensor ?? EmptyFri Jan 09, 2015 5:11 pm
"right behind the pulley"....that's what I'm going by lol
» FAQ: P0341 Camshaft Position Sensor (Cam Sensor / Timing Chain)
» MAF sensor and crankshaft sensor
» O2 sensor
» O2 sensor or MAP sensor?
Riv Performance ::   Turbocharged V6 Tech :: 3.8L V6 Turbo Engine & Transmission-
